FDS and write/erase flash cycles
Hi!
I've read a bit about the limitation of write/read cycles with the nRF52840. I the ~10,000 write/read cycles limit means after this many erases, the flash is no longer guaranteed to 'work properly'.
I have a few questions regarding this:
1. What does 'work properly' mean? will there be a problem with write operations, read operations or both? What kind of problems can be expected? (will I write 0xAB and sometimes the flash will contain 0xAC, or will the flash most likely contain 0xAB, but my read operation will return 0xAC?)
2. If the problem is with the flash read, rather than the flash write, does the FDS not 'deal' with this in any way? Meaning that if the CRC of the read data mismatches with the CRC of the flash data, will the FDS not -re-read the flash to get the 'correct value'?
3. Is there any way of knowing that my flash has started to deterioration? is there a count of 'erase' cycles kept somewhere which I can read to get an idea of how far I am from 10,000 writes?
4. Does the FDS guarantee a 'reasonably' equal distribution of write/erase cycles throughout the flash? meaning that if one flash segment has reached the 10,000 limit, the other flash segments are very close to the limit as well?
Thank you!
