Hi.
I am working on nRF52832. I want to store a structure with 492kb I am getting heap is too large error. So how can I tell the complier to store my variable in flash instead of RAM by changing the settings in segger please let me kindly
Hi.
I am getting the .bss is too large to fit in RAM memory . After I am changing the heap size and stack size in makefile . Even i am sharing my code too . please have a look
Sorry for slow download. I had checked your heap & stack size 8192. I think that it's working in your zip package. And the map file is no error. Are you fixed your problems?
struct sensor_data
char timestamp[41];
int sensor_value;
struct sensor_data sensordata_array[12000];
Why do you need so large memory?
Can you use the malloc() function and release memory with free() ,if the structure is processed..
Or use the spi nor-flash interface to storage the data .if it real need to keep.
no I am getting the error while compiling , .bss is too large to fit in RAM memory and .heap stack overflows stack . you didn't get this
ok....Because it's the resource problems. You have to reduce the memory size first. The NRF52832 RAM size is only 64K Bytes.
how to resolve this ? please guide me
