DFU from external flash using SPI NOR
I am attempting to get the zephyr usb dfu sample located at ncs/zephyr/samples/usb/dfu to work using external flash. I am using the nrf52833 on a custom board in combination with mx25r32 flash chip on ncs version 2.4.0.
Firstly, I have been able to get the dfu working with no issues when I don't configure the project to use external flash. I build the project with the default usb device name, flash it and see that it shows up as a usb device. Then I change the name, rebuild the project and use dfu-util to send app_update.bin to the image 1 slot of the device. I reboot the device, it swaps in the new image and I see my newly named usb device show up. Unfortunately, I need the extra internal flash space as my application is larger than 250 kb.
I then make the following changes to the prj.conf file located at ncs/bootloader/mcuboot/boot/zephyr/prj.conf
CONFIG_MULTITHREADING=y
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_PM_EXTERNAL_FLASH=y
CONFIG_PM_EXTERNAL_FLASH_DEV_NAME="MX25R32"
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_SIZE=0x73000
I then make the following change to the pm.yml located at the same place
mcuboot_secondary:
    region: external_flash
I also add the following to the prj.conf file in the usb dfu sample
CONFIG_SPI=y
CONFIG_SPI_NOR=y
Once I make these changes, everything builds fine and I see the new application size is basically doubled, which to me means that it is in fact configured correctly for storing the secondary image on external flash. I repeat the steps to get a new image on the device just as a I did before and everything seems to work fine. However, when I reboot the device the new usb device is never seen. I see the bootloader try to swap the new image in but it then says that there is no valid firmware image in the primary slot.
I also run into the same issue when I use SMP over BLE. The image is successfully added and the mcumgr image list command even shows that there are two firmware images on the device. But when I reboot, the bootloader tries to swap in the new image but then fails to validate it.
Am I doing something wrong or is this only supposed to work with QSPI?
The external flash works fine on its own as I have the NVS system stored there and I am able to use it without any issues.
  • There was quite much work required to get your sample to run on the nrf52840dk, so I just modified my simplifed sample to use spi_nor instead of nrf_qspi_nor, and I was actually able to make it work. I successfully performed a dfu using external flash and spi_nor.
    I'll upload the sample here. Try modifying it to work with your external flash and your particular board. I think this is what you need to change:
    • mcuboot_conf and prj.conf: "MX25R64" to "MX25R32"
    • Change the name of the overlay file (nrf52840dk_nrf52840.overlay) to your board name
    • Change mx25r64 with mx25r32 in the overlay file
    There might be more you have to change that I'm not aware of.
    Also remember to change mcuboot.c as described earlier in this ticket.
    Build the application two times, after the first build, flash it to the chip. Then change the text
    "Application version 1.0.0\n" to v2.0.0, build it again and transfer the file app_update.bin to the phone.
    Then download nRF Connect Device Manager, and transfer the .bin file
    You need to bond with the device (open Termite to see logging/instructions) in order to perform the update.
    If you're not able to make this work, I'll get ahold of an nRF52833 and and external flash and try to make it work with that.
    5807.peripheral_uart_spi_nor_dfu.zip
    Its been a while but my teammate has finally gotten both ble dfu and usb dfu working on the smp_svr sample. We were under the impression that we didn't have to configure the board file at all because the partition manager is supposed to take care of everything. I guess this was a mistake as when we made the following changes to our board file, the DFU just started working.
    &flash0 {
    	partitions {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		boot_partition: partition@0 {
    			label = "mcuboot";
    			reg = <0x000000000 0xC000>;
    		slot0_partition: partition@c000 {
    			label = "image-0";
    			reg = <0x0000C000 0x35000>;
    &mx25r32 {
        partitions {
            #size-cells = <1>;
            slot1_partition: partition@0 {
                label = "image-1";
                reg = <0x00000000 0x000073000>;
            scratch_partition: partition@73000 {
                label = "image-scratch";
                reg = <0x000073000 0x000073000>;
    We didn't have to make any of the changes discussed earlier in the thread and we're basically working from a fresh zephyr install. We did update to NCS v1.5.0 where I was previously testing on NCS v.1.4.0.
  • Hmm.. That's interesting. I thought that the Partition Manager decided the partitions (and DTS partitions would get ignored) when your application included child-images, like mcuboot. As stated in the PM documentation:
    "The Partition Manager is activated for all multi-image builds, regardless of which build strategy is used for the child image."
    Apparently this is not the case for you. Maybe my understanding is wrong, or there have been some updates to NCS how this is handled.
    To make it clear, you do see the folder <sample>/build/zephyr/mcuboot in your application?
  • Yes, I see that folder. Anything in here I should be looking for?
