ppk2 ampere meter measure error.not correct
hi nordic,
when ppk2 entry Ampere meter.
the measure current not correct.(it seem the scale and offset error ,but can be enable/disable output)
(test circuit only vdd(3.3 extern power)->resistor5.1k->ppk2(in)-->ppk2(out)-->gnd(ppk2 gnd)
it should be 0.6mA,but the ppk2 only 60uA.? and other case it get error value(nrf52840 dk blinkly example  same issue*1)
when ppk2 entry soure meter.it be work
it is right value.
(it test use nrf52840 dk ,blinkly example)
https://i.imgur.com/pMqRzEY.png
measure example(error):
https://i.imgur.com/o41SGHp.png
app version:
https://i.imgur.com/TlxZCIo.png
ppk2 F.W version:
15:37:32.160 Validating firmware for device with s/n D55B03750145
15:37:32.177 Opening device with s/n D55B03750145
os:
# nRFConnect System Report - 2020-12-30T10-21-15.621Z
- System:     xxxx
- BIOS:       xxxx
- CPU:        1 x IntelRegistered CoreTm i5-8265U 1.60 GHz 8 cores (4 physical)
- Memory:     1.2 GB free of 7.9 GB total
- Filesystem: C: (NTFS) 120 GB 94.9% used
- OS:         Microsoft Windows 10 Pro (10.0.19041) win32 ia32
- Versions
    - kernel: 10.0.19041
    - git: 2.21.0.windows.1
    - node: 12.13.0
    - python: 2.7.13
    - python3:
*1:
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_ppk2%2FUG%2Fppk%2Fmeasure_current_ampere_meter.html
2020-12-30T02:18:09.168Z INFO Deselecting device
2020-12-30T02:18:27.807Z INFO Validating firmware for device with s/n D55B03750145
2020-12-30T02:18:27.814Z INFO Opening device with s/n D55B03750145
2020-12-30T02:18:28.606Z INFO PPK started
2020-12-30T02:18:28.624Z INFO PPK opened
2020-12-30T02:18:36.925Z INFO DUT ON
2020-12-30T02:18:40.149Z INFO Sampling started
2020-12-30T02:18:51.021Z INFO Sampling stopped
2020-12-30T02:18:59.541Z INFO DUT OFF
2020-12-30T02:19:54.636Z INFO Deselecting device
2020-12-30T02:19:54.698Z INFO PPK closed
2020-12-30T02:19:58.355Z INFO Validating firmware for device with s/n D55B03750145
2020-12-30T02:19:58.362Z INFO Opening device with s/n D55B03750145
2020-12-30T02:19:58.729Z INFO PPK started
2020-12-30T02:19:58.748Z INFO PPK opened
2020-12-30T02:20:06.226Z INFO DUT ON
2020-12-30T02:20:07.538Z INFO Sampling started
2020-12-30T02:20:14.812Z INFO Sampling stopped
2020-12-30T02:20:15.640Z INFO DUT OFF
