BLE fails to pair with Windows 8.1
I'm unable to pair my device with Windows 8.1. Pairing with Android works just fine whereas when I try to do it on my computer it just tells me that the device is no longer discoverable. Also, at the end of pairing with Android I seem to be geting 24 and 23 events (no idea what those are), when pairing with Windows I only get 23.
I've read it's a known problem and somebody suggested to add the following code to GAP initialization:
ble_gap_addr_t bleAddress;
sd_ble_gap_address_get(&bleAddress);
sd_ble_gap_address_set(BLE_GAP_ADDR_CYCLE_MODE_NONE, &bleAddress);
It didn't change anything though, both of those functions return NRF_SUCCESS. I'm using device manager as suggested, also here's my event handler for BLE:
void bleEventHandler(ble_evt_t *event)
    uint32_t errorCode;
    bleServiceEventHandler(drSmartService, event);
    switch(event->header.evt_id)
        case BLE_GAP_EVT_TIMEOUT:
            debugOut("Advertising timeout\r\n");
        case BLE_GAP_EVT_CONNECTED:
            connectionHandle = event->evt.gap_evt.conn_handle;
            debugOut("Connection estabilished\r\n");
            debugOut("Providing security parameters\r\n");
            securityKeyset.keys_periph.p_enc_key = NULL;
            if((errorCode = sd_ble_gap_sec_params_reply(connectionHandle, BLE_GAP_SEC_STATUS_SUCCESS, &securityParams, &securityKeyset)) != NRF_SUCCESS)
                debugOut("Error %lu: security params reply failed\r\n", errorCode);
        case BLE_GAP_EVT_SEC_INFO_REQUEST:
            debugOut("Providing security information\r\n");
            connectionHandle = BLE_CONN_HANDLE_INVALID;
            debugOut("Disconnected.. Resuming advertising\r\n");
            if((errorCode = bleAdvertisingStart()) != NRF_SUCCESS)
                debugOut("Error %lu: failed to resume advertising\r\n", errorCode);
            debugOut("Setting system attribute access\r\n");
            if((errorCode = sd_ble_gatts_sys_attr_set(connectionHandle, NULL, 0, 0)) != NRF_SUCCESS)
                debugOut("Error %lu: failed to set sys attr access\r\n", errorCode);
        case BLE_GATTC_EVT_TIMEOUT:
            debugOut("Client connection timeout..\r\n");
        case BLE_GATTS_EVT_TIMEOUT:
            debugOut("Server connection timeout. Terminating..\r\n");
            if((errorCode = sd_ble_gap_disconnect(connectionHandle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION)) != NRF_SUCCESS)
                debugOut("Error %lu: failed to terminate connection\r\n", errorCode);
            debugOut("Unknown event: %d\r\n", event->header.evt_id);
Thank you
