Interfacing nRF52832 with ds18b20
Hello guys,
                 I'm trying to interface nrf52832 with ds18b20 temperature sensor and I'm using this code https://github.com/sigurdnev/Nordic-DS18B20 and I'm getting the output value but sometimes I'm getting temperature value as -0.063 and sometimes some random values I'm completely new to nRF so I don't know what I'm doing wrong
  • Ok this is what I have tried, and this is my main.c
     * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "app_timer.h"
    #include "nrf_drv_clock.h"
    #include <stdio.h>
    #include "ds18b20.h"
    //Datasheet: https://datasheets.maximintegrated.com/en/ds/DS18B20.pdf
    static float temp = 0;
    static void lfclk_request(void)
        ret_code_t err_code = nrf_drv_clock_init();
    APP_TIMER_DEF(m_repeated_timer_id);//ADDED
    /*static void repeated_timer_handler(void * p_context)
        nrf_drv_gpiote_out_toggle(LED_1);
    static void timers_init(void)
    /*static void app_create_timers()
        ret_code_t err_code;
        // Create timers
        err_code = app_timer_create(&m_repeated_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    ds18b20_get_temp_method_2);
        return;
    void main()
        while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
        lfclk_request();
        timers_init();
        ds18b20_setResolution(12);
       //temp = ds18b20_get_temp_method_2();
       //printf("Temperature: %.3f \r\n", temp);
        while(1)
            nrf_delay_ms(2000);
            timers_init();
            temp =app_timer_start(&m_repeated_timer_id, APP_TIMER_MODE_REPEATED,ds18b20_get_temp_method_2);
            //ret_code_t err_code =app_timer_start(&m_repeated_timer_id, APP_TIMER_MODE_REPEATED,ds18b20_get_temp_method_2);
            APP_ERROR_CHECK(temp);
            //temp = app_timer_stop(&m_repeated_timer_id, APP_TIMER_MODE_REPEATED,ds18b20_get_temp_method_2);
            //temp = app_timer_start(m_repeated_timer_id,APP_TIMER_TICKS(0),NULL); // timer for 3secs
            //APP_ERROR_CHECK(temp);
            //temp = ds18b20_get_temp();
  • And this is my ds18b20.c
    #define DS_PIN 26
    // Commands
    #define STARTCONVO      0x44
    #define READSCRATCH     0xBE
    #define WRITESCRATCH    0x4E
    // Scratchpad locations
    #define TEMP_LSB        0
    #define TEMP_MSB        1
    // Device resolution
    #define TEMP_9_BIT  0x1F //  9 bit
    #define TEMP_10_BIT 0x3F // 10 bit
    #define TEMP_11_BIT 0x5F // 11 bit
    #define TEMP_12_BIT 0x7F // 12 bit
    typedef uint8_t ScratchPad[9];
    /**@brief Function for sending one bit to bus.
    void ds18b20_send(char bit)
        nrf_gpio_cfg_output(DS_PIN);
        nrf_gpio_pin_clear(DS_PIN);
        nrf_delay_us(5);
        if(bit==1)
            nrf_gpio_pin_set(DS_PIN);
        nrf_delay_us(80);
    /**@brief Function for reading one bit from bus.
    unsigned char ds18b20_read(void)
        unsigned char presence=0;
        nrf_delay_us(2);
        nrf_gpio_pin_set(DS_PIN);;
        nrf_delay_us(15);
        nrf_gpio_cfg_input(DS_PIN,NRF_GPIO_PIN_NOPULL);
        if(nrf_gpio_pin_read(DS_PIN))
            presence = 1;
            presence = 0;
        return presence;
    /**@brief Function for sending one byte to bus.
    void ds18b20_send_byte(char data)
        unsigned char i;
        unsigned char x;
        for(i=0;i<8;i++)
          x = data>>i;
          x &= 0x01;
          ds18b20_send(x);
        nrf_delay_us(100);
    /**@brief Function for reading one byte from bus.
    unsigned char ds18b20_read_byte(void)
        unsigned char i;
        unsigned char data = 0;
        for (i=0;i<8;i++)
            if(ds18b20_read()) data|=0x01<<i;
            nrf_delay_us(15);
        return(data);
    /**@brief Function for sending reset pulse.
    unsigned char ds18b20_reset(void)
      unsigned char presence;
      nrf_delay_us(500);
      nrf_gpio_cfg_input(DS_PIN,NRF_GPIO_PIN_NOPULL); // usikkert p? pull her. m? sjekkes
      nrf_delay_us(30);
        if(nrf_gpio_pin_read(DS_PIN) == 0)
            presence = 1;
            presence = 0;
        nrf_delay_us(470);
        if(nrf_gpio_pin_read(DS_PIN) == 1)
            presence = 1;
            presence = 0;
      return presence;
    /**@brief Function for reading temperature.
    float ds18b20_get_temp(void)
        unsigned char check;
        char temp1=0, temp2=0;
        check=ds18b20_reset();
        if(check)
            ds18b20_send_byte(0xCC);
            ds18b20_send_byte(0x44);
            nrf_delay_ms(600UL);
            ds18b20_send_byte(0xBE);
            temp1=ds18b20_read_byte();
            temp2=ds18b20_read_byte();
            float temp=0;
            temp=(float)(temp1+(temp2*256))/16;
            return temp;
          return 0;
    /**@brief Function for reading bit.
    uint8_t OneWire_read_bit(void)
        uint8_t r;
        nrf_delay_us(3);
        nrf_delay_us(10);
        r =nrf_gpio_pin_read(DS_PIN);
        nrf_delay_us(53);
        return r;
    /**@brief Function for reading.
    uint8_t OneWire_read()
        uint8_t bitMask;
        uint8_t r = 0;
        for (bitMask = 0x01; bitMask; bitMask <<= 1) {
    	if ( OneWire_read_bit()) r |= bitMask;
        return r;
    /**@brief Function for reading scratchpad value
    void ds18b20_readScratchPad(uint8_t *scratchPad, uint8_t fields)
        ds18b20_reset();
        ds18b20_send_byte(READSCRATCH);
        for(uint8_t i=0; i < fields; i++)
            scratchPad[i] = OneWire_read();
        ds18b20_reset();
    /**@brief Function for request temperature reading
    void ds18b20_requestTemperatures(void)
        ds18b20_reset();
        ds18b20_send_byte(STARTCONVO);
    /**@brief Function for reading temperature method 2
    float ds18b20_get_temp_method_2(void)
        ds18b20_requestTemperatures();
        ScratchPad scratchPad;
        ds18b20_readScratchPad(scratchPad, 2);
        int16_t rawTemperature = (((int16_t)scratchPad[TEMP_MSB]) << 8) | scratchPad[TEMP_LSB];
        float temp = 0.0625 * rawTemperature;
        return temp;
    /**@brief Function for setting temperature resolution
    void ds18b20_setResolution(uint8_t resolution)
        ds18b20_reset();
        ds18b20_send_byte(WRITESCRATCH);
        // two dummy values for LOW & HIGH ALARM
        ds18b20_send_byte(0);
        ds18b20_send_byte(100);
        switch (resolution)
            case 12:
                ds18b20_send_byte(TEMP_12_BIT);
            case 11:
                ds18b20_send_byte(TEMP_11_BIT);
            case 10:
                ds18b20_send_byte(TEMP_10_BIT);
            case 9:
                ds18b20_send_byte(TEMP_9_BIT);
        ds18b20_reset();
     * Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
    #ifndef SDK_CONFIG_H
    #define SDK_CONFIG_H
    // <<< Use Configuration Wizard in Context Menu >>>\n
    #ifdef USE_APP_CONFIG
    #include "app_config.h"
    // <h> nRF_Libraries
    // <e> NRF_BALLOC_ENABLED - nrf_balloc - Block allocator module
    #ifndef NRF_BALLOC_ENABLED
    #define NRF_BALLOC_ENABLED 0
    // <e> NRF_BALLOC_CONFIG_DEBUG_ENABLED - Enables debug mode in the module.
    #ifndef NRF_BALLOC_CONFIG_DEBUG_ENABLED
    #define NRF_BALLOC_CONFIG_DEBUG_ENABLED 0
    // <o> NRF_BALLOC_CONFIG_HEAD_GUARD_WORDS - Number of words used as head guard.  <0-255>
    #ifndef NRF_BALLOC_CONFIG_HEAD_GUARD_WORDS
    #define NRF_BALLOC_CONFIG_HEAD_GUARD_WORDS 1
    // <o> NRF_BALLOC_CONFIG_TAIL_GUARD_WORDS - Number of words used as tail guard.  <0-255>
    #ifndef NRF_BALLOC_CONFIG_TAIL_GUARD_WORDS
    #define NRF_BALLOC_CONFIG_TAIL_GUARD_WORDS 1
    // <q> NRF_BALLOC_CONFIG_BASIC_CHECKS_ENABLED  - Enables basic checks in this module.
    #ifndef NRF_BALLOC_CONFIG_BASIC_CHECKS_ENABLED
    #define NRF_BALLOC_CONFIG_BASIC_CHECKS_ENABLED 0
    // <q> NRF_BALLOC_CONFIG_DOUBLE_FREE_CHECK_ENABLED  - Enables double memory free check in this module.
    #ifndef NRF_BALLOC_CONFIG_DOUBLE_FREE_CHECK_ENABLED
    #define NRF_BALLOC_CONFIG_DOUBLE_FREE_CHECK_ENABLED 0
    // <q> NRF_BALLOC_CONFIG_DATA_TRASHING_CHECK_ENABLED  - Enables free memory corruption check in this module.
    #ifndef NRF_BALLOC_CONFIG_DATA_TRASHING_CHECK_ENABLED
    #define NRF_BALLOC_CONFIG_DATA_TRASHING_CHECK_ENABLED 0
    // <q> NRF_BALLOC_CLI_CMDS  - Enable CLI commands specific to the module
    #ifndef NRF_BALLOC_CLI_CMDS
    #define NRF_BALLOC_CLI_CMDS 0
    // </e>
    // </e>
    // <q> NRF_MEMOBJ_ENABLED  - nrf_memobj - Linked memory allocator module
    #ifndef NRF_MEMOBJ_ENABLED
    #define NRF_MEMOBJ_ENABLED 0
    // <q> NRF_STRERROR_ENABLED  - nrf_strerror - Library for converting error code to string.
    #ifndef NRF_STRERROR_ENABLED
    #define NRF_STRERROR_ENABLED 1
    // </h>
    // <h> nRF_Log
    // <h> nrf_log - Logger
    // <e> NRF_LOG_ENABLED - Logging module for nRF5 SDK
    #ifndef NRF_LOG_ENABLED
    #define NRF_LOG_ENABLED 0
    // <e> NRF_LOG_USES_COLORS - If enabled then ANSI escape code for colors is prefixed to every string
    #ifndef NRF_LOG_USES_COLORS
    #define NRF_LOG_USES_COLORS 0
    // <o> NRF_LOG_COLOR_DEFAULT  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_LOG_COLOR_DEFAULT
    #define NRF_LOG_COLOR_DEFAULT 0
    // <o> NRF_LOG_ERROR_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_LOG_ERROR_COLOR
    #define NRF_LOG_ERROR_COLOR 2
    // <o> NRF_LOG_WARNING_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_LOG_WARNING_COLOR
    #define NRF_LOG_WARNING_COLOR 4
    // </e>
    // <o> NRF_LOG_DEFAULT_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_LOG_DEFAULT_LEVEL
    #define NRF_LOG_DEFAULT_LEVEL 3
    // <q> NRF_LOG_DEFERRED  - Enable deffered logger.
    // <i> Log data is buffered and can be processed in idle.
    #ifndef NRF_LOG_DEFERRED
    #define NRF_LOG_DEFERRED 1
    // <o> NRF_LOG_BUFSIZE  - Size of the buffer for storing logs (in bytes).
    // <i> Must be power of 2 and multiple of 4.
    // <i> If NRF_LOG_DEFERRED = 0 then buffer size can be reduced to minimum.
    // <128=> 128
    // <256=> 256
    // <512=> 512
    // <1024=> 1024
    // <2048=> 2048
    // <4096=> 4096
    // <8192=> 8192
    // <16384=> 16384
    #ifndef NRF_LOG_BUFSIZE
    #define NRF_LOG_BUFSIZE 1024
    // <q> NRF_LOG_ALLOW_OVERFLOW  - Configures behavior when circular buffer is full.
    // <i> If set then oldest logs are overwritten. Otherwise a
    // <i> marker is injected informing about overflow.
    #ifndef NRF_LOG_ALLOW_OVERFLOW
    #define NRF_LOG_ALLOW_OVERFLOW 1
    // <e> NRF_LOG_USES_TIMESTAMP - Enable timestamping
    // <i> Function for getting the timestamp is provided by the user
    #ifndef NRF_LOG_USES_TIMESTAMP
    #define NRF_LOG_USES_TIMESTAMP 0
    // <o> NRF_LOG_TIMESTAMP_DEFAULT_FREQUENCY - Default frequency of the timestamp (in Hz)
    #ifndef NRF_LOG_TIMESTAMP_DEFAULT_FREQUENCY
    #define NRF_LOG_TIMESTAMP_DEFAULT_FREQUENCY 32768
    // </e>
    // <q> NRF_LOG_FILTERS_ENABLED  - Enable dynamic filtering of logs.
    #ifndef NRF_LOG_FILTERS_ENABLED
    #define NRF_LOG_FILTERS_ENABLED 0
    // <q> NRF_LOG_CLI_CMDS  - Enable CLI commands for the module.
    #ifndef NRF_LOG_CLI_CMDS
    #define NRF_LOG_CLI_CMDS 0
    // <h> Log message pool - Configuration of log message pool
    // <o> NRF_LOG_MSGPOOL_ELEMENT_SIZE - Size of a single element in the pool of memory objects.
    // <i> If a small value is set, then performance of logs processing
    // <i> is degraded because data is fragmented. Bigger value impacts
    // <i> RAM memory utilization. The size is set to fit a message with
    // <i> a timestamp and up to 2 arguments in a single memory object.
    #ifndef NRF_LOG_MSGPOOL_ELEMENT_SIZE
    #define NRF_LOG_MSGPOOL_ELEMENT_SIZE 20
    // <o> NRF_LOG_MSGPOOL_ELEMENT_COUNT - Number of elements in the pool of memory objects
    // <i> If a small value is set, then it may lead to a deadlock
    // <i> in certain cases if backend has high latency and holds
    // <i> multiple messages for long time. Bigger value impacts
    // <i> RAM memory usage.
    #ifndef NRF_LOG_MSGPOOL_ELEMENT_COUNT
    #define NRF_LOG_MSGPOOL_ELEMENT_COUNT 8
    // </h>
    // </e>
    // <h> nrf_log module configuration
    // <h> nrf_log in nRF_Core
    // <e> NRF_MPU_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_MPU_CONFIG_LOG_ENABLED
    #define NRF_MPU_CONFIG_LOG_ENABLED 0
    // <o> NRF_MPU_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_MPU_CONFIG_LOG_LEVEL
    #define NRF_MPU_CONFIG_LOG_LEVEL 3
    // <o> NRF_MPU_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_MPU_CONFIG_INFO_COLOR
    #define NRF_MPU_CONFIG_INFO_COLOR 0
    // <o> NRF_MPU_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_MPU_CONFIG_DEBUG_COLOR
    #define NRF_MPU_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_STACK_GUARD_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_STACK_GUARD_CONFIG_LOG_ENABLED
    #define NRF_STACK_GUARD_CONFIG_LOG_ENABLED 0
    // <o> NRF_STACK_GUARD_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_STACK_GUARD_CONFIG_LOG_LEVEL
    #define NRF_STACK_GUARD_CONFIG_LOG_LEVEL 3
    // <o> NRF_STACK_GUARD_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_STACK_GUARD_CONFIG_INFO_COLOR
    #define NRF_STACK_GUARD_CONFIG_INFO_COLOR 0
    // <o> NRF_STACK_GUARD_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_STACK_GUARD_CONFIG_DEBUG_COLOR
    #define NRF_STACK_GUARD_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> TASK_MANAGER_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef TASK_MANAGER_CONFIG_LOG_ENABLED
    #define TASK_MANAGER_CONFIG_LOG_ENABLED 0
    // <o> TASK_MANAGER_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef TASK_MANAGER_CONFIG_LOG_LEVEL
    #define TASK_MANAGER_CONFIG_LOG_LEVEL 3
    // <o> TASK_MANAGER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef TASK_MANAGER_CONFIG_INFO_COLOR
    #define TASK_MANAGER_CONFIG_INFO_COLOR 0
    // <o> TASK_MANAGER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef TASK_MANAGER_CONFIG_DEBUG_COLOR
    #define TASK_MANAGER_CONFIG_DEBUG_COLOR 0
    // </e>
    // </h>
    // <h> nrf_log in nRF_Drivers
    // <e> CLOCK_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef CLOCK_CONFIG_LOG_ENABLED
    #define CLOCK_CONFIG_LOG_ENABLED 0
    // <o> CLOCK_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef CLOCK_CONFIG_LOG_LEVEL
    #define CLOCK_CONFIG_LOG_LEVEL 3
    // <o> CLOCK_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef CLOCK_CONFIG_INFO_COLOR
    #define CLOCK_CONFIG_INFO_COLOR 0
    // <o> CLOCK_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef CLOCK_CONFIG_DEBUG_COLOR
    #define CLOCK_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> COMP_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef COMP_CONFIG_LOG_ENABLED
    #define COMP_CONFIG_LOG_ENABLED 0
    // <o> COMP_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef COMP_CONFIG_LOG_LEVEL
    #define COMP_CONFIG_LOG_LEVEL 3
    // <o> COMP_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef COMP_CONFIG_INFO_COLOR
    #define COMP_CONFIG_INFO_COLOR 0
    // <o> COMP_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef COMP_CONFIG_DEBUG_COLOR
    #define COMP_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> GPIOTE_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef GPIOTE_CONFIG_LOG_ENABLED
    #define GPIOTE_CONFIG_LOG_ENABLED 0
    // <o> GPIOTE_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef GPIOTE_CONFIG_LOG_LEVEL
    #define GPIOTE_CONFIG_LOG_LEVEL 3
    // <o> GPIOTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef GPIOTE_CONFIG_INFO_COLOR
    #define GPIOTE_CONFIG_INFO_COLOR 0
    // <o> GPIOTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef GPIOTE_CONFIG_DEBUG_COLOR
    #define GPIOTE_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> LPCOMP_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef LPCOMP_CONFIG_LOG_ENABLED
    #define LPCOMP_CONFIG_LOG_ENABLED 0
    // <o> LPCOMP_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef LPCOMP_CONFIG_LOG_LEVEL
    #define LPCOMP_CONFIG_LOG_LEVEL 3
    // <o> LPCOMP_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef LPCOMP_CONFIG_INFO_COLOR
    #define LPCOMP_CONFIG_INFO_COLOR 0
    // <o> LPCOMP_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef LPCOMP_CONFIG_DEBUG_COLOR
    #define LPCOMP_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> PDM_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef PDM_CONFIG_LOG_ENABLED
    #define PDM_CONFIG_LOG_ENABLED 0
    // <o> PDM_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef PDM_CONFIG_LOG_LEVEL
    #define PDM_CONFIG_LOG_LEVEL 3
    // <o> PDM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef PDM_CONFIG_INFO_COLOR
    #define PDM_CONFIG_INFO_COLOR 0
    // <o> PDM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef PDM_CONFIG_DEBUG_COLOR
    #define PDM_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> PPI_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef PPI_CONFIG_LOG_ENABLED
    #define PPI_CONFIG_LOG_ENABLED 0
    // <o> PPI_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef PPI_CONFIG_LOG_LEVEL
    #define PPI_CONFIG_LOG_LEVEL 3
    // <o> PPI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef PPI_CONFIG_INFO_COLOR
    #define PPI_CONFIG_INFO_COLOR 0
    // <o> PPI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef PPI_CONFIG_DEBUG_COLOR
    #define PPI_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> PWM_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef PWM_CONFIG_LOG_ENABLED
    #define PWM_CONFIG_LOG_ENABLED 0
    // <o> PWM_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef PWM_CONFIG_LOG_LEVEL
    #define PWM_CONFIG_LOG_LEVEL 3
    // <o> PWM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef PWM_CONFIG_INFO_COLOR
    #define PWM_CONFIG_INFO_COLOR 0
    // <o> PWM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef PWM_CONFIG_DEBUG_COLOR
    #define PWM_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> QDEC_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef QDEC_CONFIG_LOG_ENABLED
    #define QDEC_CONFIG_LOG_ENABLED 0
    // <o> QDEC_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef QDEC_CONFIG_LOG_LEVEL
    #define QDEC_CONFIG_LOG_LEVEL 3
    // <o> QDEC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef QDEC_CONFIG_INFO_COLOR
    #define QDEC_CONFIG_INFO_COLOR 0
    // <o> QDEC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef QDEC_CONFIG_DEBUG_COLOR
    #define QDEC_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> RNG_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef RNG_CONFIG_LOG_ENABLED
    #define RNG_CONFIG_LOG_ENABLED 0
    // <o> RNG_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef RNG_CONFIG_LOG_LEVEL
    #define RNG_CONFIG_LOG_LEVEL 3
    // <o> RNG_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef RNG_CONFIG_INFO_COLOR
    #define RNG_CONFIG_INFO_COLOR 0
    // <o> RNG_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef RNG_CONFIG_DEBUG_COLOR
    #define RNG_CONFIG_DEBUG_COLOR 0
    // <q> RNG_CONFIG_RANDOM_NUMBER_LOG_ENABLED  - Enables logging of random numbers.
    #ifndef RNG_CONFIG_RANDOM_NUMBER_LOG_ENABLED
    #define RNG_CONFIG_RANDOM_NUMBER_LOG_ENABLED 0
    // </e>
    // <e> RTC_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef RTC_CONFIG_LOG_ENABLED
    #define RTC_CONFIG_LOG_ENABLED 0
    // <o> RTC_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef RTC_CONFIG_LOG_LEVEL
    #define RTC_CONFIG_LOG_LEVEL 3
    // <o> RTC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef RTC_CONFIG_INFO_COLOR
    #define RTC_CONFIG_INFO_COLOR 0
    // <o> RTC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef RTC_CONFIG_DEBUG_COLOR
    #define RTC_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> SAADC_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef SAADC_CONFIG_LOG_ENABLED
    #define SAADC_CONFIG_LOG_ENABLED 0
    // <o> SAADC_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef SAADC_CONFIG_LOG_LEVEL
    #define SAADC_CONFIG_LOG_LEVEL 3
    // <o> SAADC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef SAADC_CONFIG_INFO_COLOR
    #define SAADC_CONFIG_INFO_COLOR 0
    // <o> SAADC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef SAADC_CONFIG_DEBUG_COLOR
    #define SAADC_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> SPIS_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef SPIS_CONFIG_LOG_ENABLED
    #define SPIS_CONFIG_LOG_ENABLED 0
    // <o> SPIS_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef SPIS_CONFIG_LOG_LEVEL
    #define SPIS_CONFIG_LOG_LEVEL 3
    // <o> SPIS_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef SPIS_CONFIG_INFO_COLOR
    #define SPIS_CONFIG_INFO_COLOR 0
    // <o> SPIS_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef SPIS_CONFIG_DEBUG_COLOR
    #define SPIS_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> SPI_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef SPI_CONFIG_LOG_ENABLED
    #define SPI_CONFIG_LOG_ENABLED 0
    // <o> SPI_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef SPI_CONFIG_LOG_LEVEL
    #define SPI_CONFIG_LOG_LEVEL 3
    // <o> SPI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef SPI_CONFIG_INFO_COLOR
    #define SPI_CONFIG_INFO_COLOR 0
    // <o> SPI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef SPI_CONFIG_DEBUG_COLOR
    #define SPI_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef TIMER_CONFIG_LOG_ENABLED
    #define TIMER_CONFIG_LOG_ENABLED 0
    // <o> TIMER_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef TIMER_CONFIG_LOG_LEVEL
    #define TIMER_CONFIG_LOG_LEVEL 3
    // <o> TIMER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef TIMER_CONFIG_INFO_COLOR
    #define TIMER_CONFIG_INFO_COLOR 0
    // <o> TIMER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef TIMER_CONFIG_DEBUG_COLOR
    #define TIMER_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> TWIS_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef TWIS_CONFIG_LOG_ENABLED
    #define TWIS_CONFIG_LOG_ENABLED 0
    // <o> TWIS_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef TWIS_CONFIG_LOG_LEVEL
    #define TWIS_CONFIG_LOG_LEVEL 3
    // <o> TWIS_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef TWIS_CONFIG_INFO_COLOR
    #define TWIS_CONFIG_INFO_COLOR 0
    // <o> TWIS_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef TWIS_CONFIG_DEBUG_COLOR
    #define TWIS_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> TWI_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef TWI_CONFIG_LOG_ENABLED
    #define TWI_CONFIG_LOG_ENABLED 0
    // <o> TWI_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef TWI_CONFIG_LOG_LEVEL
    #define TWI_CONFIG_LOG_LEVEL 3
    // <o> TWI_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef TWI_CONFIG_INFO_COLOR
    #define TWI_CONFIG_INFO_COLOR 0
    // <o> TWI_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef TWI_CONFIG_DEBUG_COLOR
    #define TWI_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> UART_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef UART_CONFIG_LOG_ENABLED
    #define UART_CONFIG_LOG_ENABLED 0
    // <o> UART_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef UART_CONFIG_LOG_LEVEL
    #define UART_CONFIG_LOG_LEVEL 3
    // <o> UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef UART_CONFIG_INFO_COLOR
    #define UART_CONFIG_INFO_COLOR 0
    // <o> UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef UART_CONFIG_DEBUG_COLOR
    #define UART_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> USBD_CONFIG_LOG_ENABLED - Enable logging in the module
    #ifndef USBD_CONFIG_LOG_ENABLED
    #define USBD_CONFIG_LOG_ENABLED 0
    // <o> USBD_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef USBD_CONFIG_LOG_LEVEL
    #define USBD_CONFIG_LOG_LEVEL 3
    // <o> USBD_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef USBD_CONFIG_INFO_COLOR
    #define USBD_CONFIG_INFO_COLOR 0
    // <o> USBD_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef USBD_CONFIG_DEBUG_COLOR
    #define USBD_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> WDT_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef WDT_CONFIG_LOG_ENABLED
    #define WDT_CONFIG_LOG_ENABLED 0
    // <o> WDT_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef WDT_CONFIG_LOG_LEVEL
    #define WDT_CONFIG_LOG_LEVEL 3
    // <o> WDT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef WDT_CONFIG_INFO_COLOR
    #define WDT_CONFIG_INFO_COLOR 0
    // <o> WDT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef WDT_CONFIG_DEBUG_COLOR
    #define WDT_CONFIG_DEBUG_COLOR 0
    // </e>
    // </h>
    // <h> nrf_log in nRF_Libraries
    // <e> APP_TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef APP_TIMER_CONFIG_LOG_ENABLED
    #define APP_TIMER_CONFIG_LOG_ENABLED 0
    // <o> APP_TIMER_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef APP_TIMER_CONFIG_LOG_LEVEL
    #define APP_TIMER_CONFIG_LOG_LEVEL 3
    // <o> APP_TIMER_CONFIG_INITIAL_LOG_LEVEL  - Initial severity level if dynamic filtering is enabled.
    // <i> If module generates a lot of logs, initial log level can
    // <i> be decreased to prevent flooding. Severity level can be
    // <i> increased on instance basis.
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef APP_TIMER_CONFIG_INITIAL_LOG_LEVEL
    #define APP_TIMER_CONFIG_INITIAL_LOG_LEVEL 3
    // <o> APP_TIMER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef APP_TIMER_CONFIG_INFO_COLOR
    #define APP_TIMER_CONFIG_INFO_COLOR 0
    // <o> APP_TIMER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef APP_TIMER_CONFIG_DEBUG_COLOR
    #define APP_TIMER_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> APP_USBD_CDC_ACM_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef APP_USBD_CDC_ACM_CONFIG_LOG_ENABLED
    #define APP_USBD_CDC_ACM_CONFIG_LOG_ENABLED 0
    // <o> APP_USBD_CDC_ACM_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef APP_USBD_CDC_ACM_CONFIG_LOG_LEVEL
    #define APP_USBD_CDC_ACM_CONFIG_LOG_LEVEL 3
    // <o> APP_USBD_CDC_ACM_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef APP_USBD_CDC_ACM_CONFIG_INFO_COLOR
    #define APP_USBD_CDC_ACM_CONFIG_INFO_COLOR 0
    // <o> APP_USBD_CDC_ACM_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef APP_USBD_CDC_ACM_CONFIG_DEBUG_COLOR
    #define APP_USBD_CDC_ACM_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> APP_USBD_DUMMY_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef APP_USBD_DUMMY_CONFIG_LOG_ENABLED
    #define APP_USBD_DUMMY_CONFIG_LOG_ENABLED 0
    // <o> APP_USBD_DUMMY_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef APP_USBD_DUMMY_CONFIG_LOG_LEVEL
    #define APP_USBD_DUMMY_CONFIG_LOG_LEVEL 3
    // <o> APP_USBD_DUMMY_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef APP_USBD_DUMMY_CONFIG_INFO_COLOR
    #define APP_USBD_DUMMY_CONFIG_INFO_COLOR 0
    // <o> APP_USBD_DUMMY_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef APP_USBD_DUMMY_CONFIG_DEBUG_COLOR
    #define APP_USBD_DUMMY_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> APP_USBD_MSC_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef APP_USBD_MSC_CONFIG_LOG_ENABLED
    #define APP_USBD_MSC_CONFIG_LOG_ENABLED 0
    // <o> APP_USBD_MSC_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef APP_USBD_MSC_CONFIG_LOG_LEVEL
    #define APP_USBD_MSC_CONFIG_LOG_LEVEL 3
    // <o> APP_USBD_MSC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef APP_USBD_MSC_CONFIG_INFO_COLOR
    #define APP_USBD_MSC_CONFIG_INFO_COLOR 0
    // <o> APP_USBD_MSC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef APP_USBD_MSC_CONFIG_DEBUG_COLOR
    #define APP_USBD_MSC_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_ENABLED
    #define APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_ENABLED 0
    // <o> APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_LEVEL
    #define APP_USBD_NRF_DFU_TRIGGER_CONFIG_LOG_LEVEL 3
    // <o> APP_USBD_NRF_DFU_TRIGGER_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_INFO_COLOR
    #define APP_USBD_NRF_DFU_TRIGGER_CONFIG_INFO_COLOR 0
    // <o> APP_USBD_NRF_DFU_TRIGGER_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef APP_USBD_NRF_DFU_TRIGGER_CONFIG_DEBUG_COLOR
    #define APP_USBD_NRF_DFU_TRIGGER_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_ATFIFO_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_ATFIFO_CONFIG_LOG_ENABLED
    #define NRF_ATFIFO_CONFIG_LOG_ENABLED 0
    // <o> NRF_ATFIFO_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_ATFIFO_CONFIG_LOG_LEVEL
    #define NRF_ATFIFO_CONFIG_LOG_LEVEL 3
    // <o> NRF_ATFIFO_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_ATFIFO_CONFIG_LOG_INIT_FILTER_LEVEL
    #define NRF_ATFIFO_CONFIG_LOG_INIT_FILTER_LEVEL 3
    // <o> NRF_ATFIFO_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_ATFIFO_CONFIG_INFO_COLOR
    #define NRF_ATFIFO_CONFIG_INFO_COLOR 0
    // <o> NRF_ATFIFO_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_ATFIFO_CONFIG_DEBUG_COLOR
    #define NRF_ATFIFO_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_BALLOC_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_BALLOC_CONFIG_LOG_ENABLED
    #define NRF_BALLOC_CONFIG_LOG_ENABLED 0
    // <o> NRF_BALLOC_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_BALLOC_CONFIG_LOG_LEVEL
    #define NRF_BALLOC_CONFIG_LOG_LEVEL 3
    // <o> NRF_BALLOC_CONFIG_INITIAL_LOG_LEVEL  - Initial severity level if dynamic filtering is enabled.
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_BALLOC_CONFIG_INITIAL_LOG_LEVEL
    #define NRF_BALLOC_CONFIG_INITIAL_LOG_LEVEL 3
    // <o> NRF_BALLOC_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_BALLOC_CONFIG_INFO_COLOR
    #define NRF_BALLOC_CONFIG_INFO_COLOR 0
    // <o> NRF_BALLOC_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_BALLOC_CONFIG_DEBUG_COLOR
    #define NRF_BALLOC_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED
    #define NRF_CLI_BLE_UART_CONFIG_LOG_ENABLED 0
    // <o> NRF_CLI_BLE_UART_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_CLI_BLE_UART_CONFIG_LOG_LEVEL
    #define NRF_CLI_BLE_UART_CONFIG_LOG_LEVEL 3
    // <o> NRF_CLI_BLE_UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_CLI_BLE_UART_CONFIG_INFO_COLOR
    #define NRF_CLI_BLE_UART_CONFIG_INFO_COLOR 0
    // <o> NRF_CLI_BLE_UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_CLI_BLE_UART_CONFIG_DEBUG_COLOR
    #define NRF_CLI_BLE_UART_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED
    #define NRF_CLI_LIBUARTE_CONFIG_LOG_ENABLED 0
    // <o> NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL
    #define NRF_CLI_LIBUARTE_CONFIG_LOG_LEVEL 3
    // <o> NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR
    #define NRF_CLI_LIBUARTE_CONFIG_INFO_COLOR 0
    // <o> NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR
    #define NRF_CLI_LIBUARTE_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_CLI_UART_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_CLI_UART_CONFIG_LOG_ENABLED
    #define NRF_CLI_UART_CONFIG_LOG_ENABLED 0
    // <o> NRF_CLI_UART_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_CLI_UART_CONFIG_LOG_LEVEL
    #define NRF_CLI_UART_CONFIG_LOG_LEVEL 3
    // <o> NRF_CLI_UART_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_CLI_UART_CONFIG_INFO_COLOR
    #define NRF_CLI_UART_CONFIG_INFO_COLOR 0
    // <o> NRF_CLI_UART_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_CLI_UART_CONFIG_DEBUG_COLOR
    #define NRF_CLI_UART_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_LIBUARTE_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_LIBUARTE_CONFIG_LOG_ENABLED
    #define NRF_LIBUARTE_CONFIG_LOG_ENABLED 0
    // <o> NRF_LIBUARTE_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_LIBUARTE_CONFIG_LOG_LEVEL
    #define NRF_LIBUARTE_CONFIG_LOG_LEVEL 3
    // <o> NRF_LIBUARTE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_LIBUARTE_CONFIG_INFO_COLOR
    #define NRF_LIBUARTE_CONFIG_INFO_COLOR 0
    // <o> NRF_LIBUARTE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_LIBUARTE_CONFIG_DEBUG_COLOR
    #define NRF_LIBUARTE_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_MEMOBJ_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_MEMOBJ_CONFIG_LOG_ENABLED
    #define NRF_MEMOBJ_CONFIG_LOG_ENABLED 0
    // <o> NRF_MEMOBJ_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_MEMOBJ_CONFIG_LOG_LEVEL
    #define NRF_MEMOBJ_CONFIG_LOG_LEVEL 3
    // <o> NRF_MEMOBJ_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_MEMOBJ_CONFIG_INFO_COLOR
    #define NRF_MEMOBJ_CONFIG_INFO_COLOR 0
    // <o> NRF_MEMOBJ_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_MEMOBJ_CONFIG_DEBUG_COLOR
    #define NRF_MEMOBJ_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_PWR_MGMT_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_PWR_MGMT_CONFIG_LOG_ENABLED
    #define NRF_PWR_MGMT_CONFIG_LOG_ENABLED 0
    // <o> NRF_PWR_MGMT_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_PWR_MGMT_CONFIG_LOG_LEVEL
    #define NRF_PWR_MGMT_CONFIG_LOG_LEVEL 3
    // <o> NRF_PWR_MGMT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_PWR_MGMT_CONFIG_INFO_COLOR
    #define NRF_PWR_MGMT_CONFIG_INFO_COLOR 0
    // <o> NRF_PWR_MGMT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_PWR_MGMT_CONFIG_DEBUG_COLOR
    #define NRF_PWR_MGMT_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_QUEUE_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_QUEUE_CONFIG_LOG_ENABLED
    #define NRF_QUEUE_CONFIG_LOG_ENABLED 0
    // <o> NRF_QUEUE_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_QUEUE_CONFIG_LOG_LEVEL
    #define NRF_QUEUE_CONFIG_LOG_LEVEL 3
    // <o> NRF_QUEUE_CONFIG_LOG_INIT_FILTER_LEVEL  - Initial severity level if dynamic filtering is enabled
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_QUEUE_CONFIG_LOG_INIT_FILTER_LEVEL
    #define NRF_QUEUE_CONFIG_LOG_INIT_FILTER_LEVEL 3
    // <o> NRF_QUEUE_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_QUEUE_CONFIG_INFO_COLOR
    #define NRF_QUEUE_CONFIG_INFO_COLOR 0
    // <o> NRF_QUEUE_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_QUEUE_CONFIG_DEBUG_COLOR
    #define NRF_QUEUE_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_SDH_ANT_LOG_ENABLED - Enable logging in SoftDevice handler (ANT) module.
    #ifndef NRF_SDH_ANT_LOG_ENABLED
    #define NRF_SDH_ANT_LOG_ENABLED 0
    // <o> NRF_SDH_ANT_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_SDH_ANT_LOG_LEVEL
    #define NRF_SDH_ANT_LOG_LEVEL 3
    // <o> NRF_SDH_ANT_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_SDH_ANT_INFO_COLOR
    #define NRF_SDH_ANT_INFO_COLOR 0
    // <o> NRF_SDH_ANT_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_SDH_ANT_DEBUG_COLOR
    #define NRF_SDH_ANT_DEBUG_COLOR 0
    // </e>
    // <e> NRF_SDH_BLE_LOG_ENABLED - Enable logging in SoftDevice handler (BLE) module.
    #ifndef NRF_SDH_BLE_LOG_ENABLED
    #define NRF_SDH_BLE_LOG_ENABLED 0
    // <o> NRF_SDH_BLE_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_SDH_BLE_LOG_LEVEL
    #define NRF_SDH_BLE_LOG_LEVEL 3
    // <o> NRF_SDH_BLE_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_SDH_BLE_INFO_COLOR
    #define NRF_SDH_BLE_INFO_COLOR 0
    // <o> NRF_SDH_BLE_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_SDH_BLE_DEBUG_COLOR
    #define NRF_SDH_BLE_DEBUG_COLOR 0
    // </e>
    // <e> NRF_SDH_LOG_ENABLED - Enable logging in SoftDevice handler module.
    #ifndef NRF_SDH_LOG_ENABLED
    #define NRF_SDH_LOG_ENABLED 0
    // <o> NRF_SDH_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_SDH_LOG_LEVEL
    #define NRF_SDH_LOG_LEVEL 3
    // <o> NRF_SDH_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_SDH_INFO_COLOR
    #define NRF_SDH_INFO_COLOR 0
    // <o> NRF_SDH_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_SDH_DEBUG_COLOR
    #define NRF_SDH_DEBUG_COLOR 0
    // </e>
    // <e> NRF_SDH_SOC_LOG_ENABLED - Enable logging in SoftDevice handler (SoC) module.
    #ifndef NRF_SDH_SOC_LOG_ENABLED
    #define NRF_SDH_SOC_LOG_ENABLED 0
    // <o> NRF_SDH_SOC_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_SDH_SOC_LOG_LEVEL
    #define NRF_SDH_SOC_LOG_LEVEL 3
    // <o> NRF_SDH_SOC_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_SDH_SOC_INFO_COLOR
    #define NRF_SDH_SOC_INFO_COLOR 0
    // <o> NRF_SDH_SOC_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_SDH_SOC_DEBUG_COLOR
    #define NRF_SDH_SOC_DEBUG_COLOR 0
    // </e>
    // <e> NRF_SORTLIST_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_SORTLIST_CONFIG_LOG_ENABLED
    #define NRF_SORTLIST_CONFIG_LOG_ENABLED 0
    // <o> NRF_SORTLIST_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_SORTLIST_CONFIG_LOG_LEVEL
    #define NRF_SORTLIST_CONFIG_LOG_LEVEL 3
    // <o> NRF_SORTLIST_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_SORTLIST_CONFIG_INFO_COLOR
    #define NRF_SORTLIST_CONFIG_INFO_COLOR 0
    // <o> NRF_SORTLIST_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_SORTLIST_CONFIG_DEBUG_COLOR
    #define NRF_SORTLIST_CONFIG_DEBUG_COLOR 0
    // </e>
    // <e> NRF_TWI_SENSOR_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef NRF_TWI_SENSOR_CONFIG_LOG_ENABLED
    #define NRF_TWI_SENSOR_CONFIG_LOG_ENABLED 0
    // <o> NRF_TWI_SENSOR_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef NRF_TWI_SENSOR_CONFIG_LOG_LEVEL
    #define NRF_TWI_SENSOR_CONFIG_LOG_LEVEL 3
    // <o> NRF_TWI_SENSOR_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_TWI_SENSOR_CONFIG_INFO_COLOR
    #define NRF_TWI_SENSOR_CONFIG_INFO_COLOR 0
    // <o> NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR
    #define NRF_TWI_SENSOR_CONFIG_DEBUG_COLOR 0
    // </e>
    // </h>
    // <h> nrf_log in nRF_Serialization
    // <e> SER_HAL_TRANSPORT_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef SER_HAL_TRANSPORT_CONFIG_LOG_ENABLED
    #define SER_HAL_TRANSPORT_CONFIG_LOG_ENABLED 0
    // <o> SER_HAL_TRANSPORT_CONFIG_LOG_LEVEL  - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef SER_HAL_TRANSPORT_CONFIG_LOG_LEVEL
    #define SER_HAL_TRANSPORT_CONFIG_LOG_LEVEL 3
    // <o> SER_HAL_TRANSPORT_CONFIG_INFO_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef SER_HAL_TRANSPORT_CONFIG_INFO_COLOR
    #define SER_HAL_TRANSPORT_CONFIG_INFO_COLOR 0
    // <o> SER_HAL_TRANSPORT_CONFIG_DEBUG_COLOR  - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef SER_HAL_TRANSPORT_CONFIG_DEBUG_COLOR
    #define SER_HAL_TRANSPORT_CONFIG_DEBUG_COLOR 0
    // </e>
    // </h>
    // </h>
    // </h>
    // </h>
    // <<< end of configuration section >>>
    #endif //SDK_CONFIG_H
    And this is my sdk.h
  • Arun0498 said:
    Its not printing
     Over UART or Segger RTT debug terminal?
    Were you able to get it working with the original code ?
    If you are getting garbage values with the original code, then I suspect there is some HW issue with your setup. As previously mentioned, please check the wiring to the sensor, and make sure all wires are properly connected. If you have a spare sensor, then try to replace the one you are using now.
