Scanning for ANT+ Heart Rate Monitor Noticeably Impacts Existing BLE Peripheral Connection Performance
I am configuring the ANT+ scan on two separate channels with the following parameters:
ROMDATA_T ant_search_config_t aprfant_dynastream_search_config =
.channel_number = APRFANT_HRM_DYNASTREAM_SCAN_CHANNEL_NUMBER,
.low_priority_timeout = ANT_LOW_PRIORITY_TIMEOUT_DISABLE,
.high_priority_timeout = ANT_HIGH_PRIORITY_SEARCH_DISABLE,
.search_sharing_cycles = 64, //ANT_SEARCH_SHARING_CYCLES_DISABLE,
.search_priority = ANT_SEARCH_PRIORITY_DEFAULT,
.waveform = ANT_WAVEFORM_DEFAULT,
ROMDATA_T ant_search_config_t aprfant_suunto_search_config =
.channel_number = APRFANT_HRM_SUUNTO_SCAN_CHANNEL_NUMBER,
While the scan is active, an existing BLE peripheral connection (with notifications being sent every 250msec) is substantially impacted resulting in "bursty" delivery of notifications. Additionally, trying to establish a BLE peripheral connection while the scan is active works sometimes and not other times (this depends on the central device behavior).
I see other posts on the forum talking about BLE heart monitor scanning strategy related to reducing the scan window/interval to minimize the impact on an existing connection. I also see the same impact when scanning for a BLE heart rate monitor with an existing BLE peripheral connection.  I am currently using a 50 msec window and a 100 msec interval. I assume I should reduce both the lessen the impact on the BLE peripheral connection.
Could someone please suggest reasonable parameters for ANT+ and BLE scanning that will reduce the impact on the BLE peripheral connection while still giving good performance?
