Flashed PCB doesn't boot to app (stays in bootloader)
I am trying to port my working application from a nrf52811/s112 to nrf52832/s132, both with SDK 16.0.0.
I'm at the end at the process, it builds fine on nrf52932, I just can't get my app to boot.
It stays in bootloader, very probably because it doesn't launch the app. It advertises as 'DfuTarg'.
I suspected a CRC issue, so I have tried setting NO_CHECKS when building the bootloader, without luck.
Here is my build process (note that I use the same process to flash the same application to nrf52811/s112) :
# Build
emBuild -config 'Release' sdk16.0.0/projet/dfu/secure_bootloader/dfu_boks/ses/secure_bootloader_ble_52832_s132.emProject
emBuild -config 'Release' sdk16.0.0/projet/app/app_boks/s132/ses/soft_my_app_52832_s132.emProject
# Settings.hex generate
nrfutil settings generate --application <my_app>_52832_s132.hex --application-version-string 2.4.2 --family NRF52 --bootloader-version 2 --bl-settings-version 2 --app-boot-validation VALIDATE_GENERATED_CRC settings.hex
# Merge hex
mergehex -m my_app_52832_s132.hex bootloader_52832_s132.hex settings.hex -o tmp.hex
mergehex -m tmp.hex s132_nrf52_7.0.1_softdevice.hex -o app_bootloader_settings_softdevice.hex
# Program
nrfjprog --eraseall
nrfjprog --program app_bootloader_settings_softdevice.hex
nrjprog --reset
Here is my bootloader placement settings, copied from the SDK example (using default flash_placement.xml from the SDK example) :
linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x80000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x10000;FLASH_START=0x26000;FLASH_SIZE=0x5a000;RAM_START=0x20002220;RAM_SIZE=0xdde0"
linker_section_placements_segments="FLASH RX 0x0 0x80000;RAM RWX 0x20000000 0x10000;uicr_bootloader_start_address RX 0x10001014 0x4;bootloader_settings_page RX 0x0007F000 0x1000;uicr_mbr_params_page RX 0x10001018 0x4;mbr_params_page RX 0x0007E000 0x1000"
Here is my app placement settings, copied from the SDK example (using default flash_placement.xml from the SDK example) :
linker_section_placements_segments="FLASH RX 0x0 0x80000;RAM RWX 0x20000000 0x10000"
Here is the generated settings.hex :
Bootloader DFU Settings:
* File: settings.hex
* Family: nRF52
* Start Address: 0x0007F000
* CRC: 0xBEC1BE15
* Settings Version: 0x00000002 (2)
* App Version: 0x00004FB2 (20402)
* Bootloader Version: 0x00000002 (2)
* Bank Layout: 0x00000000
* Current Bank: 0x00000000
* Application Size: 0x0000C1A0 (49568 bytes)
* Application CRC: 0x00061612
* Bank0 Bank Code: 0x00000001
* Softdevice Size: 0x00000000 (0 bytes)
* Boot Validation CRC: 0x52CA2133
* SD Boot Validation Type: 0x00000000 (0)
* App Boot Validation Type: 0x00000001 (1)
What am I missing ? Thanks !
