All interrupt seems to be triggered twice ?
I noticed at least using pwr_mgmt we are calling two times nrf_pwr_mgmt_run for every interrupts !
All interrupt seems to be triggered twice ! Or wakes from idle state 2 times !
Why ?
In my case, it is the case for every app_timer interrupt, IO port interrupt, and every SPI interrupt. With not any concurrent interrupt.
I have done a test starting with pwr_mgmt example of SDK 17.0.2.
Main file is modified to :
 * Copyright (c) 2016 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdbool.h>
#include <stdint.h>
#include "boards.h"
#include "bsp.h"
#include "bsp_nfc.h"
#include "app_timer.h"
#include "nordic_common.h"
#include "app_error.h"
#include "nrf_drv_clock.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#if NRF_PWR_MGMT_CONFIG_USE_SCHEDULER
#include "app_scheduler.h"
#define APP_SCHED_MAX_EVENT_SIZE    0   /**< Maximum size of scheduler events. */
#define APP_SCHED_QUEUE_SIZE        4   /**< Maximum number of events in the scheduler queue. */
#endif // NRF_PWR_MGMT_CONFIG_USE_SCHEDULER
#define BTN_ID_READY                0   /**< ID of the button used to change the readiness to sleep. */
#define BTN_ID_SLEEP                1   /**< ID of the button used to put the application into sleep/system OFF mode. */
#define BTN_ID_WAKEUP               1   /**< ID of the button used to wake up the application. */
#define BTN_ID_RESET                2   /**< ID of the button used to reset the application. */
static volatile bool m_stay_in_sysoff;  /**< True if the application should stay in system OFF mode. */
static volatile bool m_is_ready;        /**< True if the application is ready to enter sleep/system OFF mode. */
static volatile bool m_sysoff_started;  /**< True if the application started sleep preparation. */
/**@brief Handler for shutdown preparation.
bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    uint32_t err_code;
    if (m_is_ready == false)
        m_sysoff_started = true;
        return false;
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_SYSOFF:
            NRF_LOG_INFO("NRF_PWR_MGMT_EVT_PREPARE_SYSOFF");
            err_code = bsp_buttons_disable();
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            NRF_LOG_INFO("NRF_PWR_MGMT_EVT_PREPARE_WAKEUP");
            // Suppress NRF_ERROR_NOT_SUPPORTED return code.
            UNUSED_VARIABLE(err_code);
            err_code = bsp_wakeup_button_enable(BTN_ID_WAKEUP);
            err_code = bsp_nfc_sleep_mode_prepare();
        case NRF_PWR_MGMT_EVT_PREPARE_DFU:
            NRF_LOG_ERROR("Entering DFU is not supported by this example.");
            APP_ERROR_HANDLER(NRF_ERROR_API_NOT_IMPLEMENTED);
        case NRF_PWR_MGMT_EVT_PREPARE_RESET:
            NRF_LOG_INFO("NRF_PWR_MGMT_EVT_PREPARE_RESET");
    err_code = app_timer_stop_all();
    return true;
/**@brief Register application shutdown handler with priority 0. */
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, 0);
/**@brief Function for initializing low-frequency clock.
static void lfclk_config(void)
    ret_code_t err_code = nrf_drv_clock_init();
static uint32_t sleep_count=0;
void timer_handler(void * p_context)
	static uint32_t timer_handler_count=0;
	timer_handler_count++;
	if (timer_handler_count%100==0) {
		NRF_LOG_INFO("sleep_count / timer_handler_count = %u%%", (100 * sleep_count / timer_handler_count) );
		sleep_count=0;
APP_TIMER_DEF(m_app_timer_id);                   /**< measurement timer. */
 * @brief Function for application main entry.
    NRF_LOG_INFO("Power Management example");
	// init timers module
    lfclk_config();
    uint32_t err_code = app_timer_init();
	// Create timers.
    err_code = app_timer_create(&m_app_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                timer_handler);
    // Start application timers.
    err_code = app_timer_start(m_app_timer_id, APP_TIMER_TICKS(10), NULL);
    APP_SCHED_INIT(APP_SCHED_MAX_EVENT_SIZE, APP_SCHED_QUEUE_SIZE);
//    bsp_configuration();
    ret_code_t ret_code = nrf_pwr_mgmt_init();
    APP_ERROR_CHECK(ret_code);
    while (true)
        app_sched_execute();
			// goes to sleep !
			sleep_count++;
            nrf_pwr_mgmt_run();
Output gives :
<info> app: sleep_count / timer_handler_count = 202%
<info> pwr_mgmt: CPU Usage: 0%
<info> app: sleep_count / timer_handler_count = 200%
Any explanation why ?
Matt
