嗨,
我正在测试NRF9160,但找不到SIM卡。而且我发现SIM_1V8的引脚为低。我怎样才能打开它?它由3V3供电。
嗨,
Hi ,
I had tried. But it seems can't make sense.
Information regarding SIM interface:
https://infocenter.nordicsemi.com/topic/nwp_034/WP/nwp_034/nwp_034_uicc_interface.html?cp=2_0_7_1_2_3
https://infocenter.nordicsemi.com/topic/nwp_037/WP/nwp_037/uicc_if.html?cp=2_0_7_0_3_9
https://infocenter.nordicsemi.com/topic/nwp_037/WP/nwp_037/uicc_if_esd.html?cp=2_0_7_0_3_9_0
https://infocenter.nordicsemi.com/topic/nwp_037/WP/nwp_037/uicc_if_pcb.html?cp=2_0_7_0_3_9_1
ESD filtering is recommended, see ref design:
It is possible to use discrete components to filter.
Discrete ESD protection can consist of the following components:
• Bypass capacitors in the range of ≤ 22 pF to SIM_RST, SIM_DET, SIM_CLK, SIM_IO, and SIM_1V8.
• A separate supply capacitor ranging from 100 nF to 220 nF connected to SIM_1V8 can be considered.
• Low capacitance type ESD diodes to SIM_RST, SIM_DET, SIM_CLK, SIM_IO, and SIM_1V8.
• Multichannel ESD diodes are commonly used and recommended.
• Some multichannel diode components incorporate EMI filtering. This type is recommended if the product integrates an LTE antenna or an external antenna is located close to the SIM holder.
Is the SIM holder placed close to any RF components?
If you want you can share the PCB files and i can look at the layout. If you dont want the PCB files to be public then you can make a new private ticket or we can make this ticket private.
Can you cut\disconnect SIM_DET ?
R4, R5 and R22 should not be there or changed to 0 Ohm, the impedance should be as low as possible.
Can you share what nano-SIM card holder you are using ?
Jonathan
