HID endpoint clarification (feature reports)
I'm trying to wrap my head around the APP_USBD driver, but I'm running into a mental block.  I am implementing a report descriptor for the Battery System usage page, and all of the characteristics are features.  So would I use an in or out endpoint? or both?  I'm in the middle of trying this now and I'm not getting an error, but I'm not seeing the endpoint on the host either - so I'm not sure if this is caused by the endpoint definition or the report.
It has also lead me down a bit of a rabbit hole.  I actually have a composite device with two endpoints working nicely (joystick and keyboard).  When I was adding on this third piece, I remembered that the default keyboard descriptor from the example has an output in it, but there is only an in endpoint.  So this has me feeling like I don't understand what's going on.  Shouldn't there also have to be an out endpoint for the keyboard to get the output from the host?  I thought I would try it, but when I added an out endpoint, the GLOBAL_DEF macro didn't like it and I'm not sure why:
#define HID_KEYBOARD_EPIN       NRF_DRV_USBD_EPIN(2)
#define HID_KEYBOARD_EPOUT       NRF_DRV_USBD_EPOUT(1)
#define ENDPOINT_LIST_KEYBOARD() \
        HID_KEYBOARD_EPIN,  \
        HID_KEYBOARD_EPOUT  \
APP_USBD_HID_KBD_GLOBAL_DEF(m_app_hid_keyboard,
                            HID_KEYBOARD_INTERFACE,
                            ENDPOINT_LIST_KEYBOARD(),
                            hid_kbd_user_ev_handler,
                            APP_USBD_HID_SUBCLASS_NONE);
gives an "initializer element is not constant" error:
7> Compiling ‘main.c’
7> In file included from ../../../../../../components/libraries/usbd/class/hid/kbd/app_usbd_hid_kbd.h:58,
7>                  from C:\some_path\main.c:96:
7> ../../../../../../components/libraries/usbd/class/hid/kbd/app_usbd_hid_kbd_internal.h:116:1: error: initializer element is not constant
7> ../../../../../../components/libraries/util/app_util.h:712:37: note: in expansion of macro 'APP_USBD_HID_KBD_INTERVAL'
7> ../../../../../../components/libraries/util/nordic_common.h:118:31: note: in expansion of macro 'MACRO_MAP_1'
7> ../../../../../../components/libraries/util/app_util.h:700:29: note: in expansion of macro 'MACRO_MAP_N_'
7> ../../../../../../components/libraries/util/app_util.h:679:25: note: in expansion of macro 'MACRO_MAP_N'
7> ../../../../../../components/libraries/util/app_util.h:678:24: note: in expansion of macro 'MACRO_MAP_'
7> ../../../../../../components/libraries/usbd/class/hid/kbd/app_usbd_hid_kbd_internal.h:167:52: note: in expansion of macro 'MACRO_MAP'
7> ../../../../../../components/libraries/usbd/class/hid/kbd/app_usbd_hid_kbd.h:233:9: note: in expansion of macro 'APP_USBD_HID_KBD_GLOBAL_DEF_INTERNAL'
7> C:\some_path\main.c:619:1: note: in expansion of macro 'APP_USBD_HID_KBD_GLOBAL_DEF'
7> ../../../../../../components/libraries/usbd/class/hid/kbd/app_usbd_hid_kbd_internal.h:116:1: note: (near initialization for 'm_app_hid_keyboard_ep')
7> In file included from ../../../../../../components/libraries/usbd/app_usbd.h:46,
7>                  from C:\some_path\main.c:92:
7> ../../../../../../components/libraries/usbd/app_usbd_class_base.h:463:18: error: initializer element is not constant
7> ../../../../../../components/libraries/util/app_util.h:747:41: note: in expansion of macro 'APP_USBD_CLASS_IFACE_EP_EXTRACT_1__'
7> ../../../../../../components/libraries/util/nordic_common.h:118:31: note: in expansion of macro 'MACRO_MAP_REC_1'
7> ../../../../../../components/libraries/util/app_util.h:708:33: note: in expansion of macro 'MACRO_MAP_REC_N_'
7> ../../../../../../components/libraries/util/app_util.h:687:29: note: in expansion of macro 'MACRO_MAP_REC_N'
7> ../../../../../../components/libraries/util/app_util.h:686:28: note: in expansion of macro 'MACRO_MAP_REC_'
7> ../../../../../../components/libraries/usbd/app_usbd_class_base.h:460:17: note: in expansion of macro 'MACRO_MAP_REC'
7> ../../../../../../components/libraries/usbd/app_usbd_class_base.h:457:17: note: in expansion of macro 'APP_USBD_CLASS_IFACE_EP_EXTRACT_1_'
7> ../../../../../../components/libraries/util/nordic_common.h:118:31: note: in expansion of macro 'APP_USBD_CLASS_IFACE_EP_EXTRACT_1'
7> ../../../../../../components/libraries/util/nordic_common.h:116:31: note: in expansion of macro 'CONCAT_2_'
7> ../../../../../../components/libraries/usbd/app_usbd_class_base.h:440:9: note: in expansion of macro 'CONCAT_2'
7> ../../../../../../components/libraries/util/app_util.h:712:37: note: in expansion of macro 'APP_USBD_CLASS_IFACE_EP_EXTRACT_'
7> ../../../../../../components/libraries/usbd/app_usbd_class_base.h:583:5: note: in expansion of macro 'MACRO_MAP'
7> ../../../../../../components/libraries/usbd/app_usbd_class_base.h:811:29: note: in expansion of macro 'APP_USBD_CLASS_IFACES_EP_EXTRACT'
7> ../../../../../../components/libraries/usbd/app_usbd_class_base.h:946:9: note: in expansion of macro 'APP_USBD_CLASS_INSTANCE_INITVAL'
7> ../../../../../../components/libraries/usbd/class/hid/kbd/app_usbd_hid_kbd_internal.h:169:5: note: in expansion of macro 'APP_USBD_CLASS_INST_GLOBAL_DEF'
7> ../../../../../../components/libraries/usbd/app_usbd_class_base.h:463:18: note: (near initialization for 'm_app_hid_keyboard.specific.iface.ep[0].address')
Build failed
which I don't understand.  How could it not be constant?  I got the endpoints the same way I did when there was only one of them.
Anyway, I think maybe I have asked too many questions here, but I'm not 100% if I'm asking the right things so I'm hoping that there is an answer that kind of gets everything since they are related.  If this is wrong, I can always break this into different questions.  Then I can also make another one for my confusion about what the interface parameter does... :-P
  • Hey Ovrebekk, very much appreciated!  On our end we don't have the host software yet - we were waiting on this piece first.  Specifically, we are waiting to test the functionality against the generic windows HID battery driver (so the battery part of the device would be listed similarly to a UPS battery or laptop battery) as well as the results from USBlyzer before deciding whether we need to include anything beyond what Windows is capable of with its generic drivers.  You can see from the report descriptor I am trying to use above that the only capability I am trying to include is the capacity, insertion, and whether the battery is charging.  This is because these are the functions that seem to already be included in Windows.  When you have a battery from, say, a UPS, you get a charge percentage indicator, a charging indicator, and a battery inserted indicator without needing a custom minidriver/application.  We are hoping to leverage this.
    Your help and time are very much appreciated - especially since the only examples of Battery Systems we can find are attached to larger Power Devices like UPS, and since we are trying to attach this to something that isn't a UPS, those aren't particularly helpful.  Incidentally, I think we learned why our wireless mice and keyboards don't indicate battery level... :-P
  • Hi
    Looking into the Usage Tables for Power Devices document I realize that adding support for the Battery Systems class is a bit more work than expected ;)
    What I will try to do instead is to configure the usbd example in the SDK to set up one more interface with a simple descriptor demonstrating how to set/get feature reports, and then you should be able to extend the example from there depending on which features from the Battery System device you need.
    I will do my best to provide you an example some time next week.
    Best regards
    Torbjørn
  • That would be great!  Thanks so much, Torbjørn!  I was a little scared for you when you said you would try to implement it, that Power Devices spec is a little dense :-P
  • Hi
    It took me some time to figure out how to get the second endpoints running properly, but my modified example seems to enumerate properly now.
    Please note that I only define a simple custom HID descriptor that allows you to send 64 bytes in each direction, and I configure EPIN2 and EPOUT2 for this report.
    It should be possible to modify the report descriptor if you want to integrate the Battery System device instead.
    Please note that you need to manually change the USBD_CUSTOM_REPORT_DESCRIPTOR_SIZE define based on the length of the USBD_CUSTOM_REPORT_DESCRIPTOR definition.
    You can find my modified example here:
    https://github.com/too1/nrf52-usbd-custom-hid-ep
    If you have any problems getting it to work just let me know.
    Best regards
    Torbjørn
    thank you very much for the example. Is helping me a lot.
    Could you edit the example and make it also for the keyboard?
    Alberto
