Can device name support multi-language
We have a device needs to support user change the device name. We already finished this function. The changed device name can be store in internal flash, and broadcast from next advertising. My question is: whether the device name can support multi-language. The user scenario as below,
  1. User set their favorite name through Android or iOS App, the name may be in Chinese, Japanese, German,...or any other country language.
  2. nRF51822 store the new name in the internal flash.
  3. Next advertising, user can see their setting name on App correctly.
Please give me any your advice to achieve this function. Thanks for any coming information.
  • RK, sorry for late reply. You are right, we modified our App to encode and decode with UTF-8. We don't need to modify FW code too mch.
    Thank you. I close this issue.
  • Hello. We are using a medium dot "·" on the device name. All tests on different phones shows the name correctly, and it is well accepted. When sniffing with the nordic sniffer, it shows two characters instead of one medium dot. I think it is because the code page used, but just for confirmation: It is safe to use "special" characters on the device name like "·" ":" "|" ? Thank you
  • 'sniffing with the nordic sniffer'. That doesn't really mean anything, it just sniffs bytes and passes them to probably wireshark for display. Wireshark (in my experience) just shows bytes and if each individual byte represents an ASCII character, it shows that. Wireshark doesn't try to interpret sequences of bytes as UTF-8 or anything else. This is no different from encoding a 32bit integer, wireshark just shows 4 bytes of data and if it shows characters at all, it just shows the ASCII version of each byte.
    You need to stop conflating a sequence of bytes with how a particular app might interpret them. The nordic sniffer is a byte-based raw sniffer, it's not going to have a clue that the bytes represent unicode.
