nrfutil dfu ble timeout
I'm attempting to use nrfutil with a nRF52 DK to perform dfu over BLE. The command I'm using and the result I get is:
% nrfjprog --eraseall
Erasing user available code and UICR flash areas.
Applying system reset.
% nrfutil dfu ble -ic NRF52 -pkg app_dfu_package_1_1.0.0.zip
No target selected. Default device name: DfuTarg is used.
Please select connectivity serial port:
	0 : /dev/tty.usbmodem0006821181671 - 000682118167
Enter your choice: : 0
  File "/Library/Frameworks/Python.framework/Versions/3.8/bin/nrfutil", line 11, in <module>
    load_entry_point('nrfutil==6.1.0', 'console_scripts', 'nrfutil')()
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/click/core.py", line 829, in __call__
    return self.main(*args, **kwargs)
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/click/core.py", line 782, in main
    rv = self.invoke(ctx)
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/click/core.py", line 1259, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/click/core.py", line 1066, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/click/core.py", line 610, in invoke
    return callback(*args, **kwargs)
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/nordicsemi/__main__.py", line 1197, in ble
    dfu.dfu_send_images()
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/nordicsemi/dfu/dfu.py", line 115, in dfu_send_images
    self._dfu_send_image(self.manifest.softdevice_bootloader)
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/nordicsemi/dfu/dfu.py", line 88, in _dfu_send_image
    self.dfu_transport.open()
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/nordicsemi/dfu/dfu_transport_ble.py", line 473, in open
    self.dfu_adapter.open()
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/nordicsemi/dfu/dfu_transport_ble.py", line 103, in open
    self.adapter.driver.open()
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/pc_ble_driver_py/ble_driver.py", line 103, in wrapper
    raise NordicSemiException(
pc_ble_driver_py.exceptions.NordicSemiException: Failed to open. Error code: NRF_ERROR_TIMEOUT
This is with the latest nrfutil 6.1.0, on windows or mac, the result is the same.
  • Could you try to disable MSD in the Jlink driver and test again? You can follow this instruction: https://docs.zephyrproject.org/1.12.0/tools/nordic_segger.html#disabling-the-mass-storage-device-functionality
    We have a similar case here and here that you may want to have a look.
    -Amanda H.
  • Thanks. It now works if I use a DFU zip only containing an App. But if the zip also contains BL and SD which don't have higher versions, it fails with an error instead of skipping these like the DFU libraries do. I can't see an option to control this behaviour. This and the need to specify the serial number seem like bugs.
     % nrfutil -vvvv dfu ble -ic NRF52 -pkg output/3.0.0-b.3_release_BT500S6_BL_SD_APP.zip  -f -snr 000682118167 --name "AirTurn D96D"
    Board already flashed with connectivity firmware.
    2021-01-26 12:40:13,382 Using connectivity board at serial port: /dev/tty.usbmodem0006821181671
    2021-01-26 12:40:13,386 Sending SoftDevice+Bootloader image.
    2021-01-26 12:40:16,795 Successfully opened /dev/tty.usbmodem0006821181671. Baud rate: 1000000. Flow control: none. Parity: none.
    2021-01-26 12:40:16,796 evt> severity(20) message(Successfully opened /dev/tty.usbmodem0006821181671. Baud rate: 1000000. Flow control: none. Parity: none.)
    2021-01-26 12:40:16,796 RpcAppStatus.resetPerformed: Target Reset performed
    2021-01-26 12:40:16,796 evt> status code(RpcAppStatus.resetPerformed) message(Target Reset performed)
    2021-01-26 12:40:18,000 RpcAppStatus.connectionActive: Connection active
    2021-01-26 12:40:18,001 evt> status code(RpcAppStatus.connectionActive) message(Connection active)
    2021-01-26 12:40:18,007 BLE: Scanning for AirTurn D96D
    2021-01-26 12:40:18,019 evt> adv_report conn(65535)
     peer_addr(E6:21:97:15:02:0F)
     rssi(-31)
     adv_type(BLEGapAdvType.connectable_undirected)
    2021-01-26 12:40:18,019 Received advertisement report, address: 0xE6219715020F, device_name: AirTurn D96D
    2021-01-26 12:40:18,019 BLE: Found target advertiser, address: 0xE6219715020F, name: AirTurn D96D
    2021-01-26 12:40:18,019 BLE: Connecting to 0xE6219715020F
    2021-01-26 12:40:18,019 Unknown address type: {self.addr_type)
    2021-01-26 12:40:18,021 evt> adv_report conn(65535)
     rssi(-30)
     adv_type(None)
    2021-01-26 12:40:18,022 Received advertisement report, address: 0xE6219715020F, device_name:
    2021-01-26 12:40:18,022 BLE: Found target advertiser, address: 0xE6219715020F, name:
    2021-01-26 12:40:18,022 BLE: Connecting to 0xE6219715020F
    2021-01-26 12:40:18,055 BLE: Connected to [230, 33, 151, 21, 2, 15]
    2021-01-26 12:40:18,056 evt> conn_param_update_request conn(0)
     conn_params(
      min_conn_interval_ms(15.0)
      max_conn_interval_ms(15.0)
      slave_latency(0))
     conn_params(
      slave_latency(0))
    2021-01-26 12:40:19,057 Successfully Connected
    2021-01-26 12:40:19,057 BLE: Service Discovery
    2021-01-26 12:40:19,106 evt> on_gattc_evt_prim_srvc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Service uuid(0x1800) start handle(1) end handle(9)
     Service uuid(0x1801) start handle(10) end handle(13)
     Service uuid(0xFE59) start handle(14) end handle(19)
    2021-01-26 12:40:19,166 evt> on_gattc_evt_prim_srvc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Service uuid(0x180A) start handle(20) end handle(65535)
    2021-01-26 12:40:19,227 evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Characteristic uuid(0x2A00) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=1, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(2) value handle(3)
     Characteristic uuid(0x2A01) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=0, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(4) value handle(5)
     Characteristic uuid(0x2A04) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=0, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(6) value handle(7)
    2021-01-26 12:40:19,286 evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Characteristic uuid(0x2AA6) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=0, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(8) value handle(9)
    2021-01-26 12:40:19,346 evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.attribute_not_found) conn(0)
    2021-01-26 12:40:19,406 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x2A00) handle(3)
    2021-01-26 12:40:19,466 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x2A01) handle(5)
    2021-01-26 12:40:19,526 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x2A04) handle(7)
    2021-01-26 12:40:19,586 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x2AA6) handle(9)
    2021-01-26 12:40:19,646 evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Characteristic uuid(0x2A05) properties(BLECharProperties(broadcast=0, read=0, write_wo_resp=0, write=0, notify=0, indicate=1, auth_signed_wr=0)) declaration handle(11) value handle(12)
    2021-01-26 12:40:19,706 evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.attribute_not_found) conn(0)
    2021-01-26 12:40:19,766 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x2A05) handle(12)
     Descriptor uuid(0x2902 (Standard.cccd)) handle(13)
    2021-01-26 12:40:19,826 evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Characteristic uuid(0x0002) properties(BLECharProperties(broadcast=0, read=0, write_wo_resp=1, write=0, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(15) value handle(16)
    2021-01-26 12:40:19,886 evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Characteristic uuid(0x0001) properties(BLECharProperties(broadcast=0, read=0, write_wo_resp=0, write=1, notify=1, indicate=0, auth_signed_wr=0)) declaration handle(17) value handle(18)
    2021-01-26 12:40:19,946 evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.attribute_not_found) conn(0)
    2021-01-26 12:40:20,006 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x0002) handle(16)
    2021-01-26 12:40:20,066 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x0001) handle(18)
    2021-01-26 12:40:20,126 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x2902 (Standard.cccd)) handle(19)
    2021-01-26 12:40:20,186 evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Characteristic uuid(0x2A29) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=0, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(21) value handle(22)
     Characteristic uuid(0x2A24) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=0, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(23) value handle(24)
     Characteristic uuid(0x2A25) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=0, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(25) value handle(26)
    2021-01-26 12:40:20,246 evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Characteristic uuid(0x2A27) properties(BLECharProperties(broadcast=0, read=1, write_wo_resp=0, write=0, notify=0, indicate=0, auth_signed_wr=0)) declaration handle(27) value handle(28)
    2021-01-26 12:40:20,306 evt> on_gattc_evt_char_disc_rsp status(BLEGattStatusCode.attribute_not_found) conn(0)
    2021-01-26 12:40:20,366 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x2A29) handle(22)
    2021-01-26 12:40:20,426 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x2A24) handle(24)
    2021-01-26 12:40:20,486 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x2A25) handle(26)
    2021-01-26 12:40:20,546 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.success) conn(0)
     Descriptor uuid(0x2A27) handle(28)
    2021-01-26 12:40:20,606 evt> on_gattc_evt_desc_disc_rsp status(BLEGattStatusCode.attribute_not_found) conn(0)
    2021-01-26 12:40:20,606 BLE: Enabling longer ATT MTUs
    2021-01-26 12:40:20,666 ATT MTU exchanged: conn_handle=0 att_mtu=247
    2021-01-26 12:40:20,666 New ATT MTU is 247
    2021-01-26 12:40:20,667 BLE: Enabling longer Data Length
    2021-01-26 12:40:20,786 New Data Length is 251
    2021-01-26 12:40:20,786 BLE: Enabling Notifications
    2021-01-26 12:40:20,846 evt> on_gattc_evt_write_rsp conn(0)
     error_handle(0)
     attr_handle(19)
     write_op(BLEGattWriteOperation.write_req)
     offset(0)
     data([])
    2021-01-26 12:40:20,846 BLE: Set Packet Receipt Notification 0
    2021-01-26 12:40:20,906 evt> on_gattc_evt_write_rsp conn(0)
     error_handle(0)
     attr_handle(18)
     offset(0)
     data([])
    2021-01-26 12:40:20,907 evt> on_gattc_evt_hvx status(BLEGattStatusCode.success) conn(0)
     error_handle(0)
     attr_handle(18)
     hvx_type(BLEGattHVXType.notification)
     data([96, 2, 1])
    2021-01-26 12:40:20,907 Sending init packet...
    2021-01-26 12:40:20,908 BLE: Selecting Object: type:1
    2021-01-26 12:40:20,966 evt> on_gattc_evt_write_rsp conn(0)
     error_handle(0)
     attr_handle(18)
     offset(0)
     data([])
    2021-01-26 12:40:20,967 evt> on_gattc_evt_hvx status(BLEGattStatusCode.success) conn(0)
     error_handle(0)
     attr_handle(18)
     data([96, 6, 1, 0, 2, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0])
    2021-01-26 12:40:20,967 BLE: Object selected: max_size:512 offset:0 crc:0
    2021-01-26 12:40:21,026 evt> on_gattc_evt_write_rsp conn(0)
     error_handle(0)
     attr_handle(18)
     offset(0)
     data([])
    2021-01-26 12:40:21,027 evt> on_gattc_evt_hvx status(BLEGattStatusCode.success) conn(0)
     error_handle(0)
     attr_handle(18)
     data([96, 1, 1])
    2021-01-26 12:40:21,027 BLE: Streaming Data: len:151 offset:0 crc:0x00000000
    2021-01-26 12:40:21,031 Call ble_gattc_write: response(None) write_params(Write Params write_op(BLEGattWriteOperation.write_cmd) flags(BLEGattExecWriteFlag.prepared_cancel) handle(16) offset(0) data([18, 148, 1, 10, 78, 8, 1, 18, 74, 8, 2, 16, 52, 26, 4, 129, 2, 183, 1, 32, 3, 40, 236, 146, 9, 48, 176, 202, 1, 56, 0, 66, 36, 8, 3, 18, 32, 93, 60, 58, 188, 99, 232, 117, 234, 69, 89, 31, 247, 86, 172, 52, 16, 199, 174, 103, 94, 114, 242, 166, 121, 95, 72, 161, 240, 51, 7, 224, 180, 72, 0, 82, 4, 8, 0, 18, 0, 82, 4, 8, 1, 18, 0, 16, 0, 26, 64, 115, 14, 195, 115, 98, 246, 234, 157, 226, 50, 189, 205, 81, 74, 3, 92, 139, 245, 59, 59, 239, 233, 216, 45, 199, 233, 48, 108, 139, 134, 57, 105, 74, 66, 244, 253, 176, 190, 140, 178, 211, 135, 21, 48, 109, 152, 94, 2, 119, 58, 238, 19, 16, 48, 33, 93, 90, 189, 52, 205, 70, 142, 0, 217]))
    2021-01-26 12:40:21,057 evt> gattc_evt_write_cmd_tx_complete conn(0)
     count(1)
    2021-01-26 12:40:21,116 evt> on_gattc_evt_write_rsp conn(0)
     error_handle(0)
     attr_handle(18)
     offset(0)
     data([])
    2021-01-26 12:40:21,117 evt> on_gattc_evt_hvx status(BLEGattStatusCode.success) conn(0)
     error_handle(0)
     attr_handle(18)
     data([96, 3, 1, 151, 0, 0, 0, 120, 75, 102, 162])
    2021-01-26 12:40:21,176 evt> on_gattc_evt_write_rsp conn(0)
     error_handle(0)
     attr_handle(18)
     offset(0)
     data([])
    2021-01-26 12:40:21,296 evt> on_gattc_evt_hvx status(BLEGattStatusCode.success) conn(0)
     error_handle(0)
     attr_handle(18)
     data([96, 4, 11, 5])
      File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/nordicsemi/__main__.py", line 1199, in ble
      File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/nordicsemi/dfu/dfu.py", line 95, in _dfu_send_image
        self.dfu_transport.send_init_packet(data)
      File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/nordicsemi/dfu/dfu_transport_ble.py", line 525, in send_init_packet
        self.__execute()
      File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/nordicsemi/dfu/dfu_transport_ble.py", line 606, in __execute
        self.__get_response(DfuTransportBle.OP_CODE['Execute'])
      File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/nordicsemi/dfu/dfu_transport_ble.py", line 681, in __get_response
        raise NordicSemiException('Extended Error 0x{:02X}: {}'.format(resp[3], data))
    pc_ble_driver_py.exceptions.NordicSemiException: Extended Error 0x05: The firmware version is too low. For an application, the version must be greater than or equal to the current application. For a bootloader, it must be greater than the current version. This requirement prevents downgrade attacks.
  • Hi Nick,
    Good to know it can work now.
    The util reflects this as the error message indicates
    As for the serial number, the second log indicates that Board not found: {}".format(serial_port or snr). It is hard to say why the serial_port doesn't work on your MAC but the serial number could. Sorry, I don't familiar with MacOS.
    -Amanda H.
  • it fails with an error instead of skipping these like the DFU libraries do.
    I saw the error but the DFU libraries just skip bootloader and SD if they are the same version instead of failing with error, which is helpful as you don’t need to know if they are the same version in advance as use a package with only App.
    as for the serial number issue it works fine on Windows so would seem like a bug on the macos version.
  • Thanks for the feedback. I will report to the internal.
    -Amanda H.
