Getting x,y,z values from BMX055 using i2C
So, I am quite beginer with programming and working with this sensors and nrf, So I need your guys help.
I am trying to get the x,y,z values from the accelerometer of BMX055 IMU sensor. So, I did not used BMX055 drivers. But the issue here is that I am not getting any output on Putty. I have set the putty according to https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_nrf5_v17.0.2%2Flib_cli.html&anchor=lib_cli_terminal_settings . It does give results of the addresses of the imu sensor when using TWI scanner example. But when I run my own code, there is no output.
I followed the guide of https://devzone.nordicsemi.com/f/nordic-q-a/38794/procedure-for-using-twi-for-i2c-between-the-nrf52dk-bmx055
Can someone please guide me where is the fault. I think there is small fault which I am unable to catch as of now.
This is my code in bmx.c file :
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nrf_drv_twi.h"
#include "bma2x2.h"
//Initializing TWI0 instance
#define TWI_INSTANCE_ID 0
// A flag to indicate the transfer state
static volatile bool m_xfer_done = false;
// Create a Handle for the twi communication
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
//Event Handler
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
//Check the event to see what type of event occurred
switch (p_event->type)
//If data transmission or receiving is finished
case NRF_DRV_TWI_EVT_DONE:
m_xfer_done = true;//Set the flag
// do nothing
//Initialize the TWI as Master device
void twi_master_init(void)
ret_code_t err_code;
// Configure the settings for twi communication
const nrf_drv_twi_config_t twi_config = {
.scl = TWI_SCL_M, //SCL Pin
.sda = TWI_SDA_M, //SDA Pin
.frequency = NRF_DRV_TWI_FREQ_400K, //Communication Speed
.interrupt_priority = APP_IRQ_PRIORITY_HIGH, //Interrupt Priority(Note: if using Bluetooth then select priority carefully)
.clear_bus_init = false //automatically clear bus
//A function to initialize the twi communication
err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
//Enable the TWI Communication
nrf_drv_twi_enable(&m_twi);
A function to write a Single Byte to bmx's internal Register
bool bmxme_register_write(uint8_t register_address, uint8_t value)
uint8_t tx_buf[BMA2x2_GEN_READ_WRITE_LENGTH+1];
//Write the register address and data into transmit buffer
tx_buf[0] = register_address;
tx_buf[1] = value;
//Set the flag to false to show the transmission is not yet completed
//Transmit the data over TWI Bus
err_code = nrf_drv_twi_tx(&m_twi, BMA2x2_I2C_ADDR1, tx_buf, BMA2x2_GEN_READ_WRITE_LENGTH+1, false);
//Wait until the transmission of the data is finished
while (m_xfer_done == false)
// if there is no error then return true else return false
if (NRF_SUCCESS != err_code)
return false;
return true;
A Function to verify the product id
(its a basic test to check if we are communicating with the right slave, every type of I2C Device has
a special WHO_AM_I register which holds a specific value, we can read it from the MPU6050 or any device
to confirm we are communicating with the right device)
bool bmxme_verify_product_id(void)
uint8_t who_am_i; // create a variable to hold the who am i value
if (bmxme_register_read(I_AM_BMX055_ACC, &who_am_i, 1))
if (who_am_i != I_AM_BMX055_ACC)
return false;
return true;
return false;
Function to initialize the bmx055
bool bmxme_init(void)
bool transfer_succeeded = true;
//Check the id to confirm that we are communicating with the right device
transfer_succeeded &= bmxme_verify_product_id();
if(bmxme_verify_product_id() == false)
return false;
// Set the registers with the required values, see the datasheet to get a good idea of these values
(void)bmxme_register_write(BMA2x2_MODE_CTRL_ADDR , 0x00);
(void)bmxme_register_write(BMA2x2_LOW_NOISE_CTRL_ADDR , 0x00);
(void)bmxme_register_write(BMA2x2_DATA_CTRL_ADDR , 0x40);
(void)bmxme_register_write(BMA2x2_BW_SELECT_ADDR , 0x08);
(void)bmxme_register_write(BMA2x2_RANGE_SELECT_ADDR , 0x08);
return transfer_succeeded;
A Function to read data from the bmx055
bool bmxme_register_read(uint8_t register_address, uint8_t * destination, uint8_t number_of_bytes)
//Set the flag to false to show the receiving is not yet completed
// Send the Register address where we want to write the data
err_code = nrf_drv_twi_tx(&m_twi, BMA2x2_I2C_ADDR1 , &register_address, 1, true);
//Wait for the transmission to get completed
while (m_xfer_done == false){}
// If transmission was not successful, exit the function with false as return value
return false;
//set the flag again so that we can read data from the bmx055's internal register
// Receive the data from the bmx055
err_code = nrf_drv_twi_rx(&m_twi, BMA2x2_I2C_ADDR1, destination, number_of_bytes);
//wait until the transmission is completed
// if data was successfully read, return true else return false
return false;
return true;
A Function to read accelerometer's values from the internal registers of MPU6050
bool bmxme_ReadAcc( int16_t *pACC_X , int16_t *pACC_Y , int16_t *pACC_Z )
uint8_t xaxis_buf[2];
uint8_t yaxis_buf[2];
uint8_t zaxis_buf[2];
bool ret = false;
if(bmxme_register_read(BMA2x2_X_AXIS_LSB_ADDR, xaxis_buf[0], 1) & bmxme_register_read(BMA2x2_X_AXIS_MSB_ADDR, xaxis_buf[1], 1) == true)
bmxme_register_read(BMA2x2_X_AXIS_LSB_ADDR, xaxis_buf[0], 1);
bmxme_register_read(BMA2x2_X_AXIS_MSB_ADDR, xaxis_buf[1], 1);
*pACC_X = (xaxis_buf[1] << 8) | xaxis_buf[0];
if(*pACC_X & 0x8000) *pACC_X-=65536;
ret = true;
if(bmxme_register_read(BMA2x2_Y_AXIS_LSB_ADDR, yaxis_buf[0], 1) & bmxme_register_read(BMA2x2_Y_AXIS_MSB_ADDR, yaxis_buf[1], 1) == true)
bmxme_register_read(BMA2x2_Y_AXIS_LSB_ADDR, yaxis_buf[0], 1);
bmxme_register_read(BMA2x2_Y_AXIS_MSB_ADDR, yaxis_buf[1], 1);
*pACC_Y= (yaxis_buf[1] << 8) | yaxis_buf[0];
if(*pACC_Y & 0x8000) *pACC_Y-=65536;
ret = true;
if(bmxme_register_read(BMA2x2_Z_AXIS_LSB_ADDR, zaxis_buf[0], 1) & bmxme_register_read(BMA2x2_Z_AXIS_MSB_ADDR, zaxis_buf[1], 1) == true)
bmxme_register_read(BMA2x2_Z_AXIS_LSB_ADDR, zaxis_buf[0], 1);
bmxme_register_read(BMA2x2_Z_AXIS_MSB_ADDR, zaxis_buf[1], 1);
*pACC_Z= (zaxis_buf[1] << 8) | zaxis_buf[0];
if(*pACC_Z & 0x8000) *pACC_Z-=65536;
ret = true;
return ret;
and my main.c is :
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "bma2x2.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
// initialize the logger
NRF_LOG_INFO("TWI accelerometer reading started.");
// create arrays which will hold x,y & z co-ordinates values of acc
static int16_t AccValue[3];
bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS); // initialize the leds and buttons
twi_master_init(); // initialize the twi
nrf_delay_ms(1000); // give some delay
bmxme_init();
while(bmxme_init() == false) // wait until bm055 sensor is successfully initialized
NRF_LOG_INFO("BMX_055 initialization failed!!!"); // if it failed to initialize then print a message
nrf_delay_ms(1000);
NRF_LOG_INFO("BMX055 Initialization Successful!!!");
NRF_LOG_INFO("Reading Values from ACC"); // display a message to let the user know that the device is starting to read the values
nrf_delay_ms(2000);
while (true)
if(bmxme_ReadAcc(&AccValue[0], &AccValue[1], &AccValue[2]) == true) // Read acc value from bmx055 internal registers and save them in the array
NRF_LOG_INFO("ACC Values: x = %d y = %d z = %d", AccValue[0], AccValue[1], AccValue[2]); // display the read values
NRF_LOG_INFO("Reading ACC values Failed!!!"); // if reading was unsuccessful then let the user know about it
nrf_delay_ms(100); // give some delay
  • well now the output is showing in NRF log. the deferred was to be disabled.
    But now i am stuck in Reading the x,y,z values from BMX055 sensor.
    It just goes till
    line 42 : NRF_LOG_INFO("Reading Values from ACC");
    but the verification and initialization is successful. It means that my read and write functions of i2c are working fine. But to read values, that function is having some issue.
    Can you have a look, Your support would highly be appreciated
  • You should change this code in bmxme_register_read() and bmxme_register_write():
        return false;
    You need to check the error before waiting for the flag. With the current code, if there is an error preventing the transfer from starting, your application will block waiting for the event indicating that the transfer completed, before it is able to detect that the transfer never started.
