1NCE Onboarding SIM Card
I try to do the Onboarding workflow for 1NCE SIM Cards with the NRF91 Module: 1nce.com/.../
So the solution is to send a GET Request to a special endpoint and you get all your certificates. At the moment I´m confused. In the documentation it says you need to access the endpoint via HTTPS. If I do so, the server answers:
GOT HTTP/1.1 400 Bad Request
Server: awselb/2.0
Date: Thu, 14 Jan 2021 20:48:00 GMT
Content-Type: text/html
Content-Length: 220
Connection: close
<html>
<head><title>400 The plain HTTP request was sent to HTTPS port</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
<center>The plain HTTP request was sent to HTTPS port</center>
</body>
</html>
So what could be the solution? There is nothing about any certificate in the documentation. My Code is a modified one from the "https_client" sample.
https://pastebin.com/yuTTaD4k
Thanks for your help end best regards.
  • okay, sounds good. I will talk to 1nce in this case. Also its still strange that also the HEAD request returns Content-length:0 also with 200 OK. Thanks for your help here!
  • Hi Daniel,
    Thanks for sharing your experience. I am Jan, Product Manager IoT at 1NCE and responsible for the Connectivity Suite which you have been using.
    We are aware of this constraint already for a while. Unfortunately at the moment, we do not have a direct workaround. The response for the Onboarding call is too big and will not fit into the 2kb which are supported by the device. Even when using txt/csv as response type it will be too big.
    Therefore we have already planned an additional feature that will allow the onboarding call to be split into multiple responses. It will be a Query Parameter that will allow you to only request the individual fields in the response body. That way each response message is under 2kb and they can be used locally then. Since this has now been requested by a customer I will try to get the development done in our next Development sprint which would allow us to release this feature in the next 2 weeks.
    I am hoping for your understanding. I will update this thread here with more details directly from the Development Team as soon as I get them.
    We hope that we can count you in to be the first tester of this new feature as soon as available.
    Jan
    Product Manager IoT @1NCE
    Mobile: +49 175 552 4825 | [email protected] | www.1nce.com
  • Hi Jan,
    thanks for your mail and your feedback. It´s great to hear that we can find a solution here. Let me know if I can give you feedback for the planned API.
    I will post some code here if I get the deployment to work with our devices.
    Best regards
    Daniel
  • Hi Daniel,
    Sorry for the slight delay in response.
    It took a week longer the originally planned to get this feature request implemented on our side.
    But I am happy to announce that we are now offering response splitting using HTTP range requests for the Devie API/Onboarding call you have been using.
    In the following, I will explain this new feature (final documentation on the 1NCE website is still outstanding). I hope you can test it and hopefully, this will provide you everything you need.
    I would love to hear some feedback and further suggestions if you have any.
    Thanks a lot,
    Jan
    Range requests - Documentation
    Some of our API’s support splitting the response body into smaller chunks. This can be especially useful for devices with a small TLS buffer. This is done using a HTTP range request as defined by RFC-7233.
    This documentation is applicable for all our API’s that contain an Accept-Ranges: bytes header in the response. This can be checked by executing a normal GET or HEAD request on this endpoint. It will also be explicitly stated in the API definition of that endpoint.
    In general, only GET endpoints can support HTTP range requests.
    If the endpoint supports range requests, the client can request this using specific headers. If the request is successful and would normally return status 200 OK, it will return status 206 Partial Content instead, with only the requested byte range in the response body.
    Please note that errors do not have status 200 OK, so the range request will not be applied and the response body may be larger than expected!
    There are a couple of known limitations. Please check the segment “Known limitations“ for more info.
    Headers
    Request
    Name
    Located in
    Description
    Required
    Schema
    Range
    request header
    The Range request HTTP header advertises which bytes the client wants to receive in the response body.
    Default: no range request
    Format: bytes=<range-start>-<range-end>
    range-start: An integer indicating the beginning of the request range. The index is 0-based.
    range-end: An optional integer indicating the end of the request range. The end is inclusive, so bytes=0-4 would return 5 bytes: 0, 1, 2, 3 and 4.
    If omitted, the end of the response body is taken as the end of the range.
    No
    (Yes, for response splitting)
    string
    Response
    Name
    Located in
    Description
    Required
    Schema
    Content-Range
    response header
    The Content-Range response header advertises which bytes the server has sent in the response body.
    Format: bytes <range-start>-<range-end>/<size>
    range-end: An integer indicating the end of the request range. The end is inclusive, so bytes 0-4/100 would return 5 bytes: 0, 1, 2, 3 and 4.
    size: The total byte length of the original response.
    Example: Content-Range: bytes 1024-2047/3629
    Yes when status is 206;
    No otherwise
    string
    Content-Length
    response header
    In the context of range requests, the Content-Length response header always reflects the actual sent response body length in bytes.
    Example:
    The client request Range: bytes=0-1023.
    The server responds with Content-Length: 1024 and Content-Range: bytes 0-1023/3629
    Yes
    number
    Accept-Ranges
    response header
    The Accept-Ranges response header advertises whether this endpoint accepts HTTP range requests. The value indicatates the supported unit to define a range.
    Only the unit bytes is supported.
    If the Accept-Ranges response header is present, but its value is none, range requests are not supported.
    No
    string
    Examples
    The following cURL command demonstrates how HTTP range requests could be used:
    curl -i --request GET \
    --url device.dev.connectivity-suite.cloud/.../onboarding \
    --header 'Accept: application/json' \
    --header 'Range: bytes=0-1023'
    This gives the following response:
    HTTP/2 206
    server: awselb/2.0
    date: Mon, 08 Feb 2021 13:13:54 GMT
    content-type: application/json; charset=utf-8
    content-length: 1024
    etag: W/"400-xWQvmq9+I96lV5hagdjlteB5l2o"
    content-range: bytes 0-1023/3163
    access-control-allow-origin: *
    x-powered-by: Express
    {"certificate":"-----BEGIN CERTIFICATE-----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\nM9DFuYV7ABryfYb3jB0BHpw6L3NfTCtBvpXupyqHFZwEnope3ApWHwk
    Errors
    Malformed Range header
    If the request Range header is not in the correct format, the server will respond with a 400 Bad Request status and the message “Malformed Range header“.
    curl --request GET \
    --header 'Range: bytes=yikes'
    Response:
    400 Bad Request
    "statusCode": 400,
    "statusText": "Bad Request",
    "errors": [
    "message": "Malformed Range header: yikes"
    Unsatisfiable Range header
    If both the range-start and range-end values of the requestRange header are outside the available range, the server will respond with a 416 Range Not Satisfiable status and the message “Unsatisfiable Range header“.
    --header 'Range: bytes=10000-10999'Response:
    "statusCode": 416,
    "statusText": "Range Not Satisfiable",
    "errors": [
    "message": "Unsatistiable Range header: bytes=10000-10999"
    Known limitations
    Multipart ranges
    Multipart ranges are not supported and will return the original complete response.
    Conditional range requests
    Conditional range requests using an If-Range header is not supported and will be ignored.
    HEAD requests
    Currently, HEAD requests will always have a Content-Length response header of 0, so they can not be used to retrieve the total byte length of the response beforehand.
    Workaround
    As a workaround, the total response byte length can be retrieved from the response Content-Range header when doing an HTTP range request. The total byte length is the value after the slash.
    For example: In the response header Content-Range: bytes 0-1023/4298 the value 4298 would be the total response byte length.
    References
    https://developer.mozilla.org/en-US/docs/Web/HTTP/Range_requests
    https://tools.ietf.org/html/rfc7233
  • Hi Jan, the Range Request works like it should and I am now able to get data from your endpoint. I will do the complete implementation the next days but this should be straight from this point. https://pastebin.com/BBnFu3gz
