Dear Members,
Where can I find from software development kit the example for writing and reading from I2C EEPROM ?
Thanks
Dear Members,
Thanks
Is it conflict
As always, it's important to start simple; solve one problem at a time - don't leap straight into a whole pile of potential problems!
https://www.avrfreaks.net/forum/help-it-doesnt-work
So start with just the EEPROM on the bus - nothing else.
I can write it,
but it's not complete , is it related with timing ?
The output when reading
nfo> app: 7E0:
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: 07
nfo> app: AD
I want to write al 0xAD but only the end is AD ??
Code :
* Function uses the TWI interface to write data into EEPROM memory.
* @param addr Start address to write.
* @param[in] pdata Pointer to data to send.
* @param size Byte count of data to send.
* @attention Maximum number of bytes that may be written is @ref EEPROM_SEQ_WRITE_MAX.
* In sequential write, all data must be in the same page
* (higher address bits do not change).
* @return NRF_SUCCESS or reason of error.
* @attention If you wish to communicate with real EEPROM memory chip, check its readiness
* after writing the data.
static ret_code_t eeprom_write(uint16_t addr, uint8_t const * pdata, size_t size)
ret_code_t ret;
/* Memory device supports only a limited number of bytes written in sequence */
if (size > (EEPROM_SEQ_WRITE_MAX_BYTES))
return NRF_ERROR_INVALID_LENGTH;
/* All written data must be in the same page */
if ((addr / (EEPROM_SEQ_WRITE_MAX_BYTES)) != ((addr + size - 1) / (EEPROM_SEQ_WRITE_MAX_BYTES)))
return NRF_ERROR_INVALID_ADDR;
do
nrf_delay_ms(25);
uint8_t buffer[EEPROM_ADDRESS_LEN_BYTES + EEPROM_SEQ_WRITE_MAX_BYTES]; /* Addr + data */
memcpy(buffer, &addr, EEPROM_ADDRESS_LEN_BYTES);
memcpy(buffer + EEPROM_ADDRESS_LEN_BYTES, pdata, size);
ret = nrf_drv_twi_tx(&m_twi_master, EEPROM_ADDR, buffer, size + EEPROM_ADDRESS_LEN_BYTES, false);
}while (0);
return ret;
void eeprom_cmd_clear()
uint8_t clear_val = 0xAD;
size_t addr;
for (addr = 0; addr <EEPROM_SIZE; ++addr)
ret_code_t err_code;
err_code = eeprom_write(addr, &clear_val, 1);
if (NRF_SUCCESS != err_code)
NRF_LOG_INFO("communication error 24C16 By Rixtronix LAB.\r\n");
NRF_LOG_INFO("Error code %u",err_code);
return;
NRF_LOG_INFO("CLEARING 24C16 By Rixtronix LAB...\r\n");
NRF_LOG_INFO("FINISHED CLEARING 24C16 By Rixtronix LAB.\r\n");
What do I miss here ?
Thanks
#define EEPROM_SEQ_WRITE_MAX_BYTES 200 #define EEPROM_ADDR 0x50 #define EEPROM_ADDRESS_LEN_BYTES 2 #define EEPROM_SIZE (2048u) //!< 24C16 EEPROM size. #define MASTER_TWI_INST 0 //!< TWI interface used as a master accessing EEPROM memory. #define IN_LINE_PRINT_CNT (16u) //!< Number of data bytes printed in a single line.
i am also facing this issue now how would i solve
