Blinky not working on custom nrf5340 board
Hi
Migrating from NCS1.3.1 to NCS1.4.1, the Blinky sample stops working on my custom nrf5340 board. No compile error, but not running. I also have a nRF5340PDK. Works fine on this! Note that Blinky also works fine on my custom board when using NCS1.3.1.
How can I debug this?
Since Blinky works fine with NCS1.3.1 and not with NCS1.4.1  it's no HW fail !?
But since Blinky works fine with both versions on the PDK, there's no SW fail !?
note: initially I had this trouble: Case ID: 256874 https://devzone.nordicsemi.com/f/nordic-q-a/66280/blinky-non-secure-sample-not-running (maybe they are the same)
  • just added it -> no compile error. Both LEDS are blinking on the PDK.
  • Ok. Now that I think of it that makes sense as you're using the same DTS-file. I believe your error may be related to changes in the DTS file between the NCS versions. Looking into that now.
    Carl Richard
  • Hi again!
    Apologies for the slow progress of this issue. I have not managed to reproduce it here and I'm awaiting answers from the developers on possible issues. Please try out the attached .hex-files on your devices, so that we can rule out any environment issues. One is compiled for the PDK and the other for the DK.
    DK: 5126.blinky_dk.hex
    PDK: 2063.blinky_pdk.hex
    In addition, could you try to step through again and copy the full register values here when it crashes? Press the button as shown in the picture below:
    Carl Richard
  • Hi
    I first read the registers (see below). Then I tested the two images first on the PDK and then on the custom board. The pdk variant functioned well on the PDK (led blinking). No led blink with dk version. On Custom Board neither blinked.
    Sadly, after doing these exercises, the JLink interface is broken! Cannot connect to target anymore. Any tips?
    EDIT: Reboot fixed the latter issue. JLink working again.
    Registers when it crashes:
    CPU - Current Context
    r0 0x00009244
    r1 0x00009244
    r2 0x00009244
    r3 0x00009244
    r4 0x00009244
    r5 0x00009244
    r6 0x00009244
    r7 0x00009244
    r8 0x00009244
    r9 0x00009244
    r10 0x00009244
    r11 0x00009244
    r12 0x00009244
    sp(r13) 0x200015b8
    lr(r14) 0xffffffbd
    pc(r15) 0x000017e4
    apsr 0x01000007
    V 0
    C 0
    Z 0
    N 0
    CPU
    r0 0x00009244
    r1 0x00009244
    r2 0x00009244
    r3 0x00009244
    r4 0x00009244
    r5 0x00009244
    r6 0x00009244
    r7 0x00009244
    r8 0x00009244
    r9 0x00009244
    r10 0x00009244
    r11 0x00009244
    r12 0x00009244
    sp(r13) 0x200015b8
    lr(r14) 0xffffffbd
    pc(r15) 0x000017e4
    xpsr 0x01000007
    ISR 7
    IT[7:2] 0x00
    GE 0x0
    T 1
    IT[1:0] 0x0
    Q 0
    V 0
    C 0
    Z 0
    N 0
    msp 0x200015b8
    psp 0x20000b98
    cfbp 0x00000000
    PRIMASK 0
    BASEPRI 0x00
    FAULTMASK 0
    nPRIV 0
    SPSEL 0
    FPCA 0
    SFPA 0
    msp_ns 0x200086a0
    psp_ns 0x00000000
    msp_s 0x200015b8
    psp_s 0x20000b98
    msplim_s 0x20000db8
    psplim_s 0x20000878
    msplim_ns 0x00000000
    psplim_ns 0x00000000
    cfbp_s 0x00000000
    PRIMASK 0
    BASEPRI 0x00
    FAULTMASK 0
    nPRIV 0
    SPSEL 0
    FPCA 0
    SFPA 0
    cfbp_ns 0x00000000
    PRIMASK 0
    BASEPRI 0x00
    FAULTMASK 0
    nPRIV 0
    SPSEL 0
    FPCA 0
    SFPA 0
    internal 0x00000001
    mode 1
    state 0
  • Thanks for the registers. The JLink-interface should be restored if you call "nrfjprog --recover" on the command line. Please report back if that does not work!
    We can now rule out that this is an environment issue at least.
    Carl Richard
