MQTT Sample code is not connecting
The sample code at ncs/nrf/samples/nrf9160/mqtt_simple is not connecting. I dod not make any changes to the ode. I am using NB-IoT. LTE is connected. The link monitor, LTE is in green. The error code is ERROR: mqtt_connect -60
Kindly advice to resolve this
  • What is CloudMQTT
    CloudMQTT are managed Mosquitto servers in the cloud which provides lightweight methods of carrying out messaging using a publish/subscribe message queueing model.  -- This I have found in their website. For more details, please check  at https://www.cloudmqtt.com/docs/faq.html
  • You can contact them and ask specifically. That website didn't list any info related to ipv6.
    If you do a dns lookup on the mqtt broker nameserver, you should see if it supports IPv6 or not, provided that you have a ipv6 connection on your end.
    Håkon
  • Your guess is correct. CloudMQTT did not support ipv6
  • Still I am not able to connect
    5 NRF_REGULATORS       Non-SecureOKSPM: NS image at 0xc000SPM: NS MSP at 0x20025e80SPM: NS reset vector at 0x10295SPM: prepare to jump to Non-Secure image.*** Booting Zephyr OS build v2.4.0-ncs1  ***The MQTT simple sample startedLTE Link Connecting ...[00:00:00.201,629] [1;33m<wrn> net_dns_resolve: Cannot initialize DNS resolver (-22)[0m[00:00:00.232,543] [0m<inf> lte_lc: Using legacy LTE PCO mode...[0m+CEREG: 2,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"+CEREG: 0,"FFFE","FFFFFFFF",7,0,0,"11100000","11100000"[00:10:00.265,472] [0m<inf> lte_lc: Network connection attempt timed out[0m[00:10:00.280,212] [0m<inf> lte_lc: Using fallback network mode[0m+CEREG: 2,"C0D8","003AC006",9,0,0,"11100000","11100000"+CSCON: 1+CEREG: 5,"C0D8","003AC006",9,,,"11100000","11100000"LTE Link Connected!attempting to connect: ERROR: getaddrinfo failed -11hellomqtt_connect -47ERROR: getaddrinfo failed -11hellomqtt_connect -47ERROR: getaddrinfo failed -11hellomqtt_connect -47ERROR: getaddrinfo failed -11hellomqtt_connect -47ERROR: getaddrinfo failed -11hellomqtt_connect -47ERROR: getaddrinfo failed -11hellomqtt_connect -47ERROR: getaddrinfo failed -11hello
    mqtt_simple_reconnect.zip to server other than mosquitto. I am  sharing the code and error log. Kindly check.
    As mentioned, the broker must also support ipv6, as your nb-iot network only supports ipv6. Can you please ensure that you are connecting to a broker that also supports ipv6?
    Håkon
