Stream data over TWI with start signal only in the beginning of the frame, and one stop at the end of the frame
I am working on a sensor which requires data transfer over with data length over 255 bytes. I am using nRF52832 uC and and from what I see from nordic infocenter by using the following portion of code:
ret_code_t nrf_drv_twi_tx(nrf_drv_twi_t const * p_instance,
                          uint8_t               address,
                          uint8_t const *       p_data,
                          uint8_t               length,
                          bool                  no_stop);
I can send up to 255 bytes and it is possible to set no_stop to true to not send a stop signal. However as you know, the simple write burst operation has a message similar to this message,  , but that case isn't true, when Data Frame xxx is bigger than 255, since after each data frame, no start signal is resent.
