Hello!
I have this interesting bug with the twim driver.
It works perfectly with the NRFX_TWIM_XFER_TXRX transfer type: I see the transaction go out on the bus lines and the interrupt calls my handler when the transfer is complete.
When I switch the xfer type to NRFX_TWIM_XFER_TX, however, I get the following:
1) The transaction occurs successfully: I see the start and stop bits and all the bits in between are as expected.
2) My handler is never called.
3) If I poll wait using 'nrfx_twim_is_busy', it never leaves the while loop.
4) If I use the NRFX_TWIM_FLAG_NO_XFER_EVT_HANDLER flag, the data goes out on the pins, the handler is never called (as expected) BUT 'nrfx_twim_is_busy' eventually
returns 'false'.
What am I missing? I see that I have to enable EasyDMA on the active Twim instance for the project to compile but I don't have any easy DMA code setup.
