Publishing MQTT data to multiple topics in Thingy91
Hi Dev Team,
I am running a program that is publishing data over MQTT using a particular topic and broker on the Thingy91.
I wanted to know a way in which I could send different data to different topics and how it could be configured in the mqtt example.
For instance, I need to send different sensor values to different topics : (home/living/temp for temperature), (home/living/humid for humidity value).
I don't see an option of configuring more than 1 topic in the mqtt example.
For now, I have defined it as : CONFIG_MQTT_PUB_TOPIC "home/living" in the autoconf.h file.
Could you let me know how to configure multiple topics in the program ?
Adeel.
  • Adeel said:
    Could you let me know if there can be another method for doing this ?
     You can't use the data_publish() as it is, because the publish topic is hard coded. But you can just change the value of param.message.topic.topic.utf8 to something else.
  • Hi Hakon,
    Yeah I understand this now.
    I added another function : data_publish1() like this :
    /**@brief Function to publish data on the configured topic
    static int data_publish(struct mqtt_client *c, enum mqtt_qos qos,
    	u8_t *data, size_t len)
    	struct mqtt_publish_param param;
    	param.message.topic.qos = qos;
    	param.message.topic.topic.utf8 = CONFIG_MQTT_PUB_TOPIC;
    	param.message.topic.topic.size = strlen(CONFIG_MQTT_PUB_TOPIC);
    	param.message.payload.data = data;
    	param.message.payload.len = len;
    	param.message_id = sys_rand32_get();
    	param.dup_flag = 0;
    	param.retain_flag = 0;
    	data_print("Publishing: ", data, len);
    	printk("to topic: %s len: %u\n",
    		CONFIG_MQTT_PUB_TOPIC,
    		(unsigned int)strlen(CONFIG_MQTT_PUB_TOPIC));
    	return mqtt_publish(c, &param);
    static int data_publish1(struct mqtt_client *c, enum mqtt_qos qos,
    	param.message.topic.topic.utf8 = CONFIG_MQTT_PUB_TOPIC_1;
    	param.message.topic.topic.size = strlen(CONFIG_MQTT_PUB_TOPIC_1);
    	param.dup_flag = 0;
    		CONFIG_MQTT_PUB_TOPIC_1,
    		(unsigned int)strlen(CONFIG_MQTT_PUB_TOPIC_1));
    In the autoconf.h file, I added :
    #define CONFIG_MQTT_PUB_TOPIC "sensorstest1/nrf352656101119801/pressure"
    #define CONFIG_MQTT_PUB_TOPIC_1 "sensorstest1/nrf352656101119801/humidity"
    In the MQTT_EVENT_PUBLISH: , i added :
    case MQTT_EVT_PUBLISH: {
    		const struct mqtt_publish_param *p = &evt->param.publish;
    		printk("[%s:%d] MQTT PUBLISH result=%d len=%d\n", __func__,
    		       __LINE__, evt->result, p->message.payload.len);
    		err = publish_get_payload(c, p->message.payload.len);
    		if (err >= 0) {
    			data_print("Received: ", payload_buf,
    			/* Echo back received data */
    			data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE,
    				payload_buf, p->message.payload.len);
                            data_publish1(&client, MQTT_QOS_1_AT_LEAST_ONCE,
    This made it work as I am able to publish on different topic.
    Is it possible to have just one data_publish function wherein I can publish to various topics ? (only if possible, otherwise the above mentioned method is working :) ).
    Adeel.
     Yes, it should be possible to use the same function if you just change the content of param.message.topic.topic.utf8 between each time you call mqtt_publish(). No need to have two separate functions, just change the publish topic inside the data_publish() function. Does that make sense?
  • Hi Hakon,
    Yes, makes sense. I understood what you mean here. This helps Slight smile.
    Thanks for the help :) .
    Adeel.
