How to enable indication and get CCCD value to check
Hi All,
I want to use DFU to update the firmware from master to peripheral over BLE ,  both master and peripheral are nrf52840. My purpose is that the master sends a command to make the peripheral enter bootloader.Therefore I need enable indication and write 0x01 to peripheral. "nrf connect" can do it.
But the problem is that I don't kown if the indication is enable on peripheral.I referred to other answers but failed becuase I can't excuess sd_ble_gatts_value_get() and  sd_ble_gatts_hvx() correctly, my programs are below.
//enable indication
static uint32_t cccd_configure(ble_hrs_c_t * p_ble_hrs_c, bool enable)
    NRF_LOG_INFO("Configuring CCCD. CCCD Handle = %x, Connection Handle = %x",
                  p_ble_hrs_c->peer_hrs_db.hrm_cccd_handle,
                  p_ble_hrs_c->conn_handle);
    nrf_ble_gq_req_t hrs_c_req;
    uint8_t          cccd[BLE_CCCD_VALUE_LEN];
    uint16_t         cccd_val = enable ? BLE_GATT_HVX_INDICATION : 0;
    cccd[0] = LSB_16(cccd_val);
    cccd[1] = MSB_16(cccd_val);
    memset(&hrs_c_req, 0, sizeof(hrs_c_req));
    hrs_c_req.type                        = NRF_BLE_GQ_REQ_GATTC_WRITE;
    hrs_c_req.error_handler.cb            = gatt_error_handler;
    hrs_c_req.error_handler.p_ctx         = p_ble_hrs_c;
    hrs_c_req.params.gattc_write.handle   = p_ble_hrs_c->peer_hrs_db.hrm_cccd_handle;
    hrs_c_req.params.gattc_write.len      = BLE_CCCD_VALUE_LEN;
	hrs_c_req.params.gattc_write.offset   = 0;
    hrs_c_req.params.gattc_write.p_value  = cccd;
    hrs_c_req.params.gattc_write.write_op = BLE_GATT_OP_WRITE_REQ;
	hrs_c_req.params.gattc_write.flags    = BLE_GATT_EXEC_WRITE_FLAG_PREPARED_WRITE;
    return nrf_ble_gq_item_add(p_ble_hrs_c->p_gatt_queue, &hrs_c_req, p_ble_hrs_c->conn_handle);
ble_hrs_c_handles_assign
uint32_t ble_hrs_c_handles_assign(ble_hrs_c_t    * p_ble_hrs_c,
                                  uint16_t         conn_handle,
                                  const hrs_db_t * p_peer_hrs_handles)
    VERIFY_PARAM_NOT_NULL(p_ble_hrs_c);
    p_ble_hrs_c->conn_handle = conn_handle;
    if (p_peer_hrs_handles != NULL)
        //p_ble_hrs_c->peer_hrs_db = *p_peer_hrs_handles;
		NRF_LOG_INFO("In handles assign");
		p_ble_hrs_c->peer_hrs_db.hrm_cccd_handle = p_peer_hrs_handles->hrm_cccd_handle;
		p_ble_hrs_c->peer_hrs_db.hrm_handle = p_peer_hrs_handles->hrm_handle;
    return nrf_ble_gq_conn_handle_register(p_ble_hrs_c->p_gatt_queue, conn_handle);
when find the service and characteristics
static void hrs_c_evt_handler(ble_hrs_c_t * p_hrs_c, ble_hrs_c_evt_t * p_hrs_c_evt)
    ret_code_t err_code;
	bool       is_indication_enabled = true;
    switch (p_hrs_c_evt->evt_type)
        case BLE_HRS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("dfu service discovered.");
            err_code = ble_hrs_c_handles_assign(p_hrs_c,
                                                p_hrs_c_evt->conn_handle,
                                                &p_hrs_c_evt->params.peer_db);
			err_code = cccd_configure(p_hrs_c,true);
			ble_gatts_value_t gatt_value;
			uint8_t cccd_value;
			gatt_value.len = 2;
			gatt_value.p_value = &cccd_value;
			gatt_value.offset = 0;
			err_code = sd_ble_gatts_value_get(p_hrs_c_evt->conn_handle, p_hrs_c->peer_hrs_db.hrm_cccd_handle, &gatt_value);
        } break;
connection handle : 0, characteristics handle:0x16, cccd handle:0x17
sd_ble_gatts_value_get() returned error 5
I have no idea where is wrong , please give me some advice
Steven
  • Yes. Does it return NRF_SUCCESS (0x00)? And do you see the callback later?
    Yes, the return is NRF_SUCCESS(0x00). I read the value of cccd(0x0002) as you said.
    However,I met another question:
    I failed to write 0x01 to the characteristic based on ble_nus_c_string_send() because the peripheral didn't have any logs.But I can read the characteristic (Buttonless DFU without bonds:0x03) :
    BLE_GATTC_EVT_READ_RSP,len:3
    value[0]:20
    value[1]:1
    value[2]:1
    and I change the array from {0x01} to {0x04} , the peripheral has logs as below:
    <error> app : Request to send a response to client failed.
    <error> app : Request to enter bootloader mode failed asynchroneously.
    I can also read the characteristic (Buttonless DFU without bonds:0x03) :
    value[0]:20
    value[1]:4
    value[2]:2
    Bluetooth master connects to the peripheral periodically(if I don't write a byte to the characteristic, the master will not be disconnected). Logs are below:
    Disconnected. conn_handle: 0x0, reason: 0x13
    When reconnected and written 0x04(if the written byte is 0x01,there is no logs below) ,the peripheral show logs:
    I wonder where is wrong?
    More details:
    write characteristic:
    uint32_t ble_dfu_c_string_send(ble_hrs_c_t * p_ble_dfu_c, uint8_t * p_string, uint16_t length)
        VERIFY_PARAM_NOT_NULL(p_ble_dfu_c);
        nrf_ble_gq_req_t write_req;
        memset(&write_req, 0, sizeof(nrf_ble_gq_req_t));
        if (length > NRF_SDH_BLE_GATT_MAX_MTU_SIZE - 3)
            NRF_LOG_WARNING("Content too long.");
            return NRF_ERROR_INVALID_PARAM;
        if (p_ble_dfu_c->conn_handle == BLE_CONN_HANDLE_INVALID)
            NRF_LOG_WARNING("Connection handle invalid.");
        write_req.type                        = NRF_BLE_GQ_REQ_GATTC_WRITE;
        write_req.error_handler.cb            = gatt_error_handler;
        write_req.error_handler.p_ctx         = p_ble_dfu_c;
        write_req.params.gattc_write.handle   = p_ble_dfu_c->peer_hrs_db.hrm_handle;
        write_req.params.gattc_write.len      = length;
        write_req.params.gattc_write.offset   = 0;
        write_req.params.gattc_write.p_value  = p_string;
        write_req.params.gattc_write.write_op = BLE_GATT_OP_WRITE_CMD;
    	NRF_LOG_INFO("ble_dfu_c_string_send write.handle:%x",p_ble_dfu_c->peer_hrs_db.hrm_handle);
        return nrf_ble_gq_item_add(p_ble_dfu_c->p_gatt_queue, &write_req, p_ble_dfu_c->conn_handle);
    read characteristic:
    uint32_t ble_dfu_ch_read(ble_hrs_c_t * p_ble_dfu_c,uint16_t chara_handle)
        nrf_ble_gq_req_t read_req;
        memset(&read_req, 0, sizeof(nrf_ble_gq_req_t));
            NRF_LOG_INFO("Connection handle invalid.");
    	NRF_LOG_INFO("In ch_read.handle:%x.",chara_handle);
        read_req.type                        = NRF_BLE_GQ_REQ_GATTC_READ;
        read_req.error_handler.cb            = gatt_error_handler;
        read_req.error_handler.p_ctx         = p_ble_dfu_c;
        read_req.params.gattc_read.handle   = chara_handle;
        read_req.params.gattc_read.offset   = 0;
        return nrf_ble_gq_item_add(p_ble_dfu_c->p_gatt_queue, &read_req, p_ble_dfu_c->conn_handle);
    main
    //uint8_t arr={0x01}, and can be changed by uart
    err_code = ble_dfu_c_string_send(&m_hrs_c, arr, 1);
    err_code = ble_dfu_ch_read(&m_hrs_c,m_hrs_c.peer_hrs_db.hrm_handle);
    Steven
    It looks like you are reading the CCCD of the characteristic, which is 0x0200 (indication enabled). Try reading the value handle instead.
     It is expected that they will disconnect. When you write 0x01 to the buttonless DFU characteristic, the device should reboot in bootloader mode.
    It looks, based on your log message "Request to enter bootloader mode failed asynchroneously" that it failed to do so. Have you tried to debug to figure out why the BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED event was generated?
    Edvin
  • Hello Edvin,
    I tried to debug the peripheral and found that BLE_GATTS_EVT_HVC event was not generated in ble_dfu_buttonless_on_ble_evt().
    In "nrf_connect" app, if I enable indications and write 0x01 to the characteristic(Buttonless DFU without bonds:0x03), BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST and BLE_GATTS_EVT_HVC will be generated.
    The result is that I can only recieve {0x20,0x01,0x01}  when writing 0x01 to the characteristic(Buttonless DFU without bonds:0x03) and the peripheral can not enter bootloarder.
    I wonder if I need to do something else after writing 0x01 to the characteristc?
    Steven
  • I have not tried to write to this application from an application running on the nRF (only with a phone or nRF Connect for Desktop). Can you please zip the project folder and upload it here, so that I can have a look at what you are doing? It is very hard to say whats wrong based on this discussion only.
    If you do upload the zipped project folder, please specify what SDK version and IDE you are using.
    Edvin
  • Hello Edvin,
    Thanks for your patient replies this week, I figured out  why BLE_GATTS_EVT_HVC event was not generated.
    Because the peripheral is responding to the Enter Bootloader request with a handle value indication which should be confirmed by the master. This confirmation will generate the BLE_GATTS_EVT_HVC event.
    I add the code to send a Handle Value Confirmation to the GATT Server in the master side before on_hvx():
    void ble_hrs_c_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
        ble_hrs_c_t * p_ble_hrs_c = (ble_hrs_c_t *)p_context;
        if ((p_ble_hrs_c == NULL) || (p_ble_evt == NULL))
            return;
            case BLE_GATTC_EVT_HVX:
    			//Send a Handle Value Confirmation to the GATT Server
    			sd_ble_gattc_hv_confirm(p_ble_evt->evt.common_evt.conn_handle,p_ble_evt->evt.gattc_evt.params.hvx.handle);
                on_hvx(p_ble_hrs_c, p_ble_evt);
                on_disconnected(p_ble_hrs_c, p_ble_evt);
    Reference:
    https://devzone.nordicsemi.com/f/nordic-q-a/52470/create-ble_dfu_c---triggering-enter-bootloader-doesn-t-work/211297#211297
    https://devzone.nordicsemi.com/f/nordic-q-a/22743/no-ble_gatts_evt_hvc-event-generating-when-using-s140-for-bluetooth-5
    Steven
