How to use Power Config Cluster
Hello Nordic!
I want to control the battery level, and set alarms... I know that there is a cluster callled PowerConfig cluster and I have been reading it, but I acan't figure out how declare it.
I have the following code (it is written in Spanish, sorry):
typedef  struct contexto_alimentacion_s
    zb_uint8_t battery_voltage; // Atributo 3.3.2.2.3.1
    zb_uint8_t battery_size; // Atributo 3.3.2.2.4.2
    zb_uint8_t battery_quantity; // Atributo 3.3.2.2.4.4
    zb_uint8_t battery_rated_voltage; // Atributo 3.3.2.2.4.5
    zb_uint8_t battery_alarm_mask; // Atributo 3.3.2.2.4.6
    zb_uint8_t battery_voltage_min_threshold; // Atributo 3.3.2.2.4.7
} contexto_alimentacion_t;
static contexto_alimentacion_t contexto_alimentacion;
ZB_ZCL_DECLARE_POWER_CONFIG_ATTRIB_LIST(lista_atributos_alimentacion,
                                        &contexto_alimentacion.battery_voltage,
                                        &contexto_alimentacion.battery_size,
                                        &contexto_alimentacion.battery_quantity,
                                        &contexto_alimentacion.battery_rated_voltage,
                                        &contexto_alimentacion.battery_alarm_mask,
                                        &contexto_alimentacion.battery_voltage_min_threshold);
This is part of a bigger code which is using doorlock cluster too. Ithink that I have to use what is asked in this older post, am I right?
Anyway, can someone point me in the right direcction? Where can I find some examples of the Power Config cluster?
Thank you very much!
    Great to hear that you managed to implement it, and thank you for sharing your implementation so that others can see it as well!
    Marte
  • Hello Mazis,
    did you have to modify something in power config? Because I had to add
    #define ZB_ZCL_CLUSTER_ID_POWER_CONFIG_SERVER_ROLE_INIT ((zb_zcl_cluster_init_t)NULL)
    at the end of the zb_zcl_power_config,h
    Otherwise it won't compile.
    But I still can't read or report the battery voltage. Is there something special I have to set in main.c in the Zigbee Device Callback?
    Thanks
    Krystof
  • Hello!
    I didn't changed the #define line you are saying... I have that line as follows:
    zb_void_t zb_zcl_power_config_init_server(void);
    zb_void_t zb_zcl_power_config_init_client(void);
    #define ZB_ZCL_CLUSTER_ID_POWER_CONFIG_SERVER_ROLE_INIT zb_zcl_power_config_init_server
    #define ZB_ZCL_CLUSTER_ID_POWER_CONFIG_CLIENT_ROLE_INIT zb_zcl_power_config_init_client
    About the battery report. If you look the Zigbee reference, (I think that) the only reportable attribute is the remaining battery percentage. I don't know which coordinator are you using but to enable attribute reporting in mine, I had to bind and cofigure reporting for that attribute. If you are using the CLI example, the documentation is pretty good, I would take a look at it. What I do in my code to get the report of the attribute is this:
        UNUSED_RETURN_VALUE(zb_zcl_set_attr_val(MY_DOOR_LOCK_ENDPOINT,
                                                ZB_ZCL_CLUSTER_ID_DOOR_LOCK,
                                                ZB_ZCL_CLUSTER_SERVER_ROLE,
                                                ZB_ZCL_ATTR_POWER_CONFIG_BATTERY_PERCENTAGE_REMAINING_ID,
                                                &batteryLevel,
                                                ZB_FALSE));
    I hope this helps!
  • Hello Mazis,
    Thanks for reply, I was trying to get the reporting to work for almost a week now.
    I got myself second nrf52840 DK now, so I use the CLI example on that.
    I can already see the power config in the device cluster list in CLI coordinator
    But I can't set the battery remaining value. It always gives me error 135 which is invalid Value
    I am trying to set value 0x64 which is 100 which should correspond to 50% of battery.
    6087.zb_ha_window_covering.h
    zb_zcl_power_config.h
    zb_zcl_window_covering.h
    Here are my files, could you maybe take a look? How do yours zb_zcl_power_config.h, zb_zcl_door_lock.h and zb_ha_door_lock.h files look like?
    Here is my implemenation in main.c:
        battery_percentage = 0x64;
        zcl_status = zb_zcl_set_attr_val(HA_WINDOW_COVERING_ENDPOINT,
                                         ZB_ZCL_CLUSTER_ID_POWER_CONFIG,
                                         &battery_percentage,
                                         ZB_FALSE);
        if(zcl_status != ZB_ZCL_STATUS_SUCCESS)
            NRF_LOG_INFO("Set battery remaining percentage value fail. zcl_status: %d,", zcl_status);
    in zcl_device_cb so when I send a command to the device it reports me battery.
    battery_percentage here is type zb_uint8_t.
    Thank you!
    Krystof Vydra
  • Hi Krystof!
    I am so sorry but I didn't find anything wrong in your code... All the sensible code is modified, and it looks correct to me. The 0x64 is valid, and the attribute type indeed, is zb_uint8_t.
    The only things that I think might be wrong are:
    - The number of ZB_HA_WINDOW_COVERING_IN_CLUSTER_NUM or ZB_HA_WINDOW_COVERING_OUT_CLUSTER_NUM might be wrong. Take a look and change them if necessary.
    - I also had a issue declaring the cluster. I had to use the extended Macro to declare the attribute list of the power config. Are you using
    ZB_ZCL_DECLARE_POWER_CONFIG_BATTERY_ATTRIB_LIST_EXT?
    - When I wwas reviewing your code I found what might be a bug in my code. When you call zb_zcl_set_attr_val() and give it the ZB_ZCL_CLUSTER_ID_POWER_CONFIG as parameter, can you try to use the corresponding CLUSTER_ID for the window covering? Just like I am doing, although it seems wrong in my code.
    - I would also try setting any other attribute to see if the problem is the parameters you are giving to the function zb_zcl_set_attr_val(). I would also change the cluster.
    I hope this helps...
    Cheers!
