nRF52832 GPIO irreversible pin damage in application when used as a momentary switch sense input
In my product I use certain GPIO pins configured as input with the pull up activated to act as sense inputs connected to momentary switches to control the application firmware.
Recently I had several incidents from my customers and fellow developers where GPIOs became irreversibly damaged.
In each case a GPIO involved was connected to a momentary switch (i.e. a mechanical switch between GPIO pin and GND).
The application worked fine until the point of breakdown, which means the GPIO was correctly configured as input with a pull-up.
After the damage the pin is stuck to GND. The devices affected have an increased current consumption (normal deep sleep current is ~150uA, which goes up to several tens of mAs for damaged chips.
In the application we use one or two momentary switches. On the one the momentary switch is depressed approx. 1% of the time in active mode. The other is depressed 10% of the time. Latter is more prone to an earlier breakdown, i.e. the degradation happens during the on state of the momentary switch, until the point of breakdown.
As using a momentary or latching switch on a GPIO is a standard use case for microcontrolllers, I would like to understand what could possible cause such damage.
The incident is unlikely related to my product and is also reproducible on a reference device (Adafruit nRF52 Bluefruit), therefore dependency on layout of board or influence of additional peripherals I can rule out at this stage.
  • Dear hmolesworth, thanks for your suggestion, it's not a long shot at all, although I do not have so much experience with inductive flyback as you appearently have, this was also our first guess considering a pure external influence. In case the board controls a programmable LED string the most common use case has the GND wire running parallel to the power wire, with the data line in between. It would be quite a challange to twist supply and GND, our customers would not accept such a requirement. It is also not known to us that other chips have similar problems, we used 8-bit microcontrollers from other vendors for similar applications in the past.
    As to the inductive flyback, we considered a bit different scenario: suppose the two wires leading to the switch form a loop/circle and the LED string connector gets inside this loop, then during fast power transients voltage could be induced in the loop formed by the switch wires. This could happen considering that in the majority of cases the wiring of the LED strings and the swicthes go in the same direction for a certain lenght.
    We tried to replicate this scenario but again it's a game of chances trying to reproduce it as long as we just guess at the root cause.
    Nevertheless now having your valuable input I personally would narrow down the search scope to:
    1. External influence: inductive flyback external to the board/chip
    2. Internal influence: GPIO port logic where both input and output directions are enabled. Here I clearly wait for feedback from a Nordic engineer to help us figure out if such a situation where both input comparator and output push/pull stages are enabled could happen.
    Generally speaking I'm amazed how many good inputs are coming from the community. I would be even happier if engineers from Nordic could take a more active role in the search for a potential root cause.
  • I'm seriously disappointed in how this issue is supported by the Nordic team. Having been working for more than 20 years in the semiconductor industry, among others as Quality Manager, I have extensive experience on how companies serious about their product quality handle systematic issues like this. Doing everything possible to get back samples where such damages are observed and subjecting them to an in-depth failure analysis to be able to assess the root cause is a bare minimum requirement of customers I've been working with.
    While other users offered explanations, none was forthcoming from Nordic.
    Since the last few messages where we discussed a potential voltage spike due to inductive flyback, several other customers have reported same incidents. Inductive flyback now seems less probable, as the breakdown happened in application too where:
    - the wires leading to the momentary switches were twisted
    - either no LEDs were used whose wires ran parellel to those of the switch or the used LEDs were of different kind and number, drawing considerably less current.
    This so far leaves a design weakness and/or an EOS purely coming from repeatedly changing input voltage on the GPIO pin.
  • I have followed the case from time to time, but the case looked to be a more of a product design issue where you wanted suggestions on how to avoid flyback spikes to exceed the maximum electrical specifications stated in the product specifications. I thought using shotkey diodes seemed like a good suggestion, if you want us to perform a failure analysis on the chip to confirm where damage have occurred this is something we can do (I did also suggest this in my reply a month ago). We will need you to fill out a customer failure report before we can issue a return material authorization. Please create a new confidential case where you start with "Hi Kennneth" and link to this case.
    Kenneth
