Unable to receive notification in a laptop with nRF Connect for Desktop and nRF52840 dongle
When I use Texas Instruments CC2650 MODA (using Bluetooth 4.2) as the the transmitter, a smartphone (iPhone or an Android phone) that has nRF Connect app as a receiver can receive streamed data after enabling notification.
However, when using different laptops (MacBook Pro, Windows 7 or Windows 10) with a nRF52840 dongle inserted and have nRF Connect for Desktop installed, I can read and write but cannot stream data after enabling notification.
I wonder if anyone encounters this issue? Is there a solution to receive notification from a laptop with a nRF52840 dongle and nRF Connect for Desktop installed?
Note that the same MacBook Pro with LightBlue software can receive notification from CC2650MODA, with no need of a dongle.
The following table summarizes the results using different receivers
Type of receiver nRF Connect
iPhone
nRF Connect app
 Notification works
Android
nRF Connect app
 Notification works
MacBook Pro
with nRF82840 dongle
 Can write
 Can read
 Notification does not work
Laptop with Windows 7
 Can write
 Can read
Laptop with Windows 10
 Can write
 Can read
Raspberry Pi 3B+
 Can write
 Can read
Philex
  • Hi again
    Thank you for sharing that video. From the log file you attached in your last reply it doesn't seem like the peripheral nor the nRFConnect Desktop central is updating the MTU/data length at any point. Can you try to do so manually in nRFConnect once connected to the device?
    Does your send function on the peripheral side have any return value at all, and if so, what does it return after the notifications have been enabled?
    Simon
  • Hi Simon,
    Thank you so much for the suggestion.
    1. When MTU/data length (default 23 bytes) is updated to 28 bytes (my packet length), notification does not work. But if MTU/data length changes to a larger number (40 bytes in my case) notification works (please see the video I upload here). Any idea why MTU/data length=28 does not work but 40 works?
    2. Can nRF Connect be installed in Raspberry Pi 3B+ or 4?
  • Hi
    I'm not able to play the latest video you uploaded. Please upload it in the same format as your first video.
    1. Is 28 bytes the full packet, including overhead, etc. as well? I assume the amount of data sent is just above 28 bytes.
    2. It should be possible to build the Python version of the pc-ble-driver for ARM architecture, but you have to build this from source.
    Simon
