nrf5280 re-config TRACEDATA pin as general gpio for pulse generation
hello Nordic
i am using nrf52840, sdk 16.0, working base on the peripheral app_ble_blinky example
i wish to use the p0_11 pin for pulse generation (not pwm), but when i try to config that pin as nrf_drv_gpiote_out_init(), i get err_code = 8 (NRF_ERROR_INVALID_STATE )
i looked into the data sheet and the forum for a bit and understood this is TRACEDATA2 pin but that it can also be configured as gpio, so the question is how to reconfigure it as gpiote (timer will generate a pulse with ppi to this pin) ?
also, since i understood the TRACEDATA has something to do with debugging, does configuring the pin as gpiote will have any affect on debugging with development board or in the future with a programmer via j-link connection to a PCB to be ?
also, i am using TRACDATA 1 (p0_12) as MOSI pin in an SPI comm and i did not get any problem there, so why is there a difference ?
best regard
Ziv
  • hi Vidar
    the problem is that if i change setting in the pca10056.h file then it will be changed for all other projects using that board, same if i add another custom board since i allready have one
    #elif defined(BOARD_CUSTOM)
      #include "bl652_sa_01.h"
      #include "audio_sticker.h"
    #else
    #error "Board is not defined"
    i have 2 includes there
    is there a way to corelate a specific board.h for each project ?
    hope to read from you soon
    best regards
    Ziv
  • Hi Ziv,
    You can just change the LEDBUTTON_BUTTON assigment in main.c to a different button.
    Vidar
  • hi Vidar
    well i actually solved it differently eventually, changed the boards.h file like so:
    elif defined (BOARD_D52DK1)
      #include "d52_starterkit.h"
    #elif defined (BOARD_ARDUINO_PRIMO)
      #include "arduino_primo.h"
    #elif defined (CUSTOM_BOARD_INC)
      #include STRINGIFY(CUSTOM_BOARD_INC.h)
    #elif defined(REDENT_NOVA_BOARD)
    #elif defined(AUDIO_STICKER_BOARD)
    #else
    if you think it might cause some problems please inform
    Best regards
    Ziv
  • Hi Ziv,
    It's perfectly ok to change board file as well. I don't see any problem with it.
    Vidar
  • hi Vidar
    unfortunately my problems did not finish with this pin
    i had in my code the "button_init()" function left from the 'app_ble_blinky' example, when i comment it then for some reason when trying to config that pin (p0_11) i get an error 'NRFX_ERROR_INVALID_STATE' here:
    nrfx_err_t nrfx_gpiote_out_init(nrfx_gpiote_pin_t                pin,
                                    nrfx_gpiote_out_config_t const * p_config)
        NRFX_ASSERT(pin < NUMBER_OF_PINS);
        NRFX_ASSERT(m_cb.state == NRFX_DRV_STATE_INITIALIZED);
        NRFX_ASSERT(p_config);
        nrfx_err_t err_code = NRFX_SUCCESS;
        if (pin_in_use(pin))
            err_code = NRFX_ERROR_INVALID_STATE;
    my pin configuration looks like that:
     // init pin task for ppi use:
        nrf_drv_gpiote_out_config_t pin_toggle_config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
        err_code = nrf_drv_gpiote_out_init(HYDRATION_FREQ_OUTPUT_PIN, &pin_toggle_config);
    any idea what i am doing wrong ?
    in the "custom_board.h" file i commented all the build in defines with that pin
    best regards
    Ziv
