Increase TX beacon power
How can I increase the TX power on nRF5_SDK_15.3.0?
  • I tryed declared the m_advertising struct without success...
    I compared the advertising_start() function of ble_app_beacon and ble_app_proximity examples...
    ble_app_proximity example:
    static void advertising_start(bool erase_bonds)
        if (erase_bonds == true){
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCEEDED event.
    The parameter used in ble_advertising_start is m_advertising.
    ble_app_beacon example:
        ret_code_t err_code;
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    The parameter used in sd_ble_gap_adv_start is m_adv_handle.
    So i changed the handle parameter of sd_ble_gap_tx_power_set function to m_adv_handle and works good!
    uint32_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_adv_handle, 4);
    I don't know if what i did is correct but i can measure the difference on power TX...
    Can i keep this modification?
    What is the difference of ble_advertising_start and sd_ble_gap_adv_start?
    PTS.: I also find in main() of ble_app_beacon example:
    static uint8_t      m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
    Thanks
     It should be alright. It's effectively the same, ble_advertising_start() calls sd_ble_gap_adv_start(), see the definition of the function.
    regards
    Jared
  • Very good, Jared!
    Many thanks to spend your time to help me!
    Regards
