Two UART example for the nRF52833 DK with SDK17.0.2 for Keil uVision
I am looking for an example where I can enable UARTE0 and UARTE1 on the nRF52833 DK.  I am using nRF5_SDK_17.0.2 with Keil uVision V5.  I am successful with the loopback example in examples > peripheral > uart > pca10100, and looking in the forums I understand that I need to use examples > peripheral > libuarte for the two UART configuration.  Could I get some guidance on how to modify the pca10056 example to work for the pca10100, and ultimately modified to enable the second UART port?  Thank you very much.
  • Hi
    Please check your sdk_config.h file and make sure that NRF_LOG_BACKEND_RTT_ENABLED to 1 and the NRF_LOG_BACKEND_UART_ENABLED to 0.
    Simon
  • Hi Simon,
    NRF_LOG_BACKEND_RTT_ENABLED is currently set to 1, and there is no entry for NRF_LOG_BACKEND_UART_ENABLED in sdk_config.h.  I am running the example from SDK 17.0.2.  Do I need to make some modifications?
    Wilbur
  • No, that should be fine. Can you upload the debug log you're seeing in the J-Link RTT viewer. If you don't see any data in the RTT viewer, please edit the NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED define in your sdk_config.h file to see if that changes anything.
    Simon
  • Hi Simon,
    I modified the libuarte example for a second UART port (second UART on P0.17 and P0.19) based on information from this post:
    devzone.nordicsemi.com/.../running-two-libuarte---rx-not-working-on-libuarte0
    I also inserted additional log commands for viewing when the initialization is done, and when data is received on the UART pins. My sdk_config.h originally had NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 1. The manual log statements I inserted in the code show up in the RTT viewer in this format for the terminal window:
    00> <info> app: Init0 err_code: 0
    00>
    00>
    00> <info> app: Init1 err_code: 0
    00>
    00>
    00> <info> app: Finished init
    00>
    00> <info> app: Received data0
    00>
    00>
    00>
    00>
    00>
    Changing it to NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 0, the behavior is changed to show the following:
    00>
    00>
    The window below the terminal window in the J-Link RTT Viewer V6.88a shows additional messages when connecting, which appears to be the same immediately after the flash download (with the program not running) and after running nrfjprog -r (when the program is running). When the program is running, the terminal shows the messages I inserted as well as the LEDs on the DK is illuminated, otherwise there is no activity.
    LOG: J-Link RTT Viewer V6.88a: Logging started.
    LOG: Terminal 0 added.
    LOG: Connecting to J-Link via USB...
    LOG: Device "NRF52833_XXAA" selected.
    LOG: InitTarget() start
    LOG: InitTarget() end
    LOG: Found SW-DP with ID 0x2BA01477
    LOG: DPIDR: 0x2BA01477
    LOG: Scanning AP map to find all available APs
    LOG: AP[2]: Stopped AP scan as end of AP map has been reached
    LOG: AP[0]: AHB-AP (IDR: 0x24770011)
    LOG: AP[1]: JTAG-AP (IDR: 0x02880000)
    LOG: Iterating through AP map to find AHB-AP to use
    LOG: AP[0]: Core found
    LOG: AP[0]: AHB-AP ROM base: 0xE00FF000
    LOG: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
    LOG: Found Cortex-M4 r0p1, Little endian.
    LOG: FPUnit: 6 code (BP) slots and 2 literal slots
    LOG: CoreSight components:
    LOG: ROMTbl[0] @ E00FF000
    LOG: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    LOG: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
    LOG: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
    LOG: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    LOG: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
    LOG: ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    LOG: RTT Viewer connected.
    To verify there is no issue with my DK board, I downloaded the blinky examples and the program starts running immediately after downloading. Is there perhaps a setting that prevents the program from running immediately after downloading the flash? Comparing the projects nothing seems to be different. Is the above log what you were looking for?
    Wilbur
  • Hi
    It seems like the RTT viewer code is only starting up here, and not outputting any log information. How have you set up the connection to the J-Link on your end? What target device, target interface, and speed have you set? Also, if you have enabled DEBUG in the preprocessor definitions I would expect some debug messages in addition to the <info> in your log.
    Simon
