HI sir i was trying to interface pdm microphone. i followed the existing ticket PDM Driver for Zephyr on nrf52840. i had modified the proj.conf as below
CONFIG_PRINTK=y CONFIG_I2C=y CONFIG_I2S=y CONFIG_GPIO=y #CONFIG_LED=y #CONFIG_LP3943=y CONFIG_AUDIO=y CONFIG_AUDIO_DMIC=y CONFIG_AUDIO_MPXXDTYY=y # When on-board microphone is used the DMA must run w/o things # that could slow it down. So DMA logging must be completely # disabled and DMA interrupts must run at maximum priority. CONFIG_DMA=y CONFIG_DMA_0_IRQ_PRI=0 CONFIG_HEAP_MEM_POOL_SIZE=1024 CONFIG_TRUSTED_EXECUTION_NONSECURE=y
but during the loading process i got the error as below
Creating solution microphone.emProject
cmake -GNinja -DBOARD=nrf9160dk_nrf9160ns -DBOARD_DIR=/home/kadal/Nordic-Tools/ncs/zephyr/boards/arm/nrf9160dk_nrf9160 -B/home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns -S/home/kadal/Nordic-Tools/projects/microphone -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/home/kadal/Nordic-Tools/GNUarm9 -DDTC_OVERLAY_FILE=/home/kadal/Nordic-Tools/projects/microphone/nrf9160dk_nrf9160ns.overlay -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=/home/kadal/Nordic-Tools/Segger/arm_segger_embedded_studio_v530a_linux_x64_nordic/html/configure_nordic_project_menuconfig.py
-- Application: /home/kadal/Nordic-Tools/projects/microphone
-- Zephyr version: 2.4.0 (/home/kadal/Nordic-Tools/ncs/zephyr)
-- Found west (found suitable version "0.8.0", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160ns
-- Cache files will be written to: /home/kadal/.cache/zephyr
-- Found dtc: /usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/home/kadal/Nordic-Tools/GNUarm9)
-- Found BOARD.dts: /home/kadal/Nordic-Tools/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts
-- Found devicetree overlay: /home/kadal/Nordic-Tools/projects/microphone/nrf9160dk_nrf9160ns.overlay
-- Generated zephyr.dts: /home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/zephyr/include/generated/devicetree_unfixed.h
Parsing /home/kadal/Nordic-Tools/ncs/zephyr/Kconfig
Loaded configuration '/home/kadal/Nordic-Tools/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig'
Merged configuration '/home/kadal/Nordic-Tools/projects/microphone/prj.conf'
Configuration saved to '/home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/zephyr/.config'
Kconfig header saved to '/home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/zephyr/include/generated/autoconf.h'
-- Application: /home/kadal/Nordic-Tools/ncs/nrf/samples/spm
-- Found BOARD.dts: /home/kadal/Nordic-Tools/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Found devicetree overlay: /home/kadal/Nordic-Tools/ncs/nrf/samples/spm/nrf9160dk_nrf9160.overlay
-- Generated zephyr.dts: /home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/spm/zephyr/include/generated/devicetree_unfixed.h
Loaded configuration '/home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/spm/zephyr/.config'
No change to configuration in '/home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/spm/zephyr/.config'
No change to Kconfig header in '/home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/spm/zephyr/include/generated/autoconf.h'
-- Configuring done
-- Generating done
-- Build files have been written to: /home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/spm
Loaded configuration '/home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/zephyr/.config'
See also "/home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/CMakeFiles/CMakeOutput.log".
See also "/home/kadal/Nordic-Tools/projects/microphone/build_nrf9160dk_nrf9160ns/CMakeFiles/CMakeError.log".
nrf9160dk_nrf9160ns.dts.pre.tmp:357.32-361.5: Warning (simple_bus_reg): /soc/cryptocell-sw: missing or empty reg/ranges property
nrf9160dk_nrf9160ns.dts.pre.tmp:56.42-68.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
nrf9160dk_nrf9160ns.dts.pre.tmp:305.19-311.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image spm - begin ===
Including boilerplate (Zephyr base (cached)): /home/kadal/Nordic-Tools/ncs/zephyr/cmake/app/boilerplate.cmake
nrf9160dk_nrf9160.dts.pre.tmp:56.42-68.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@50000000/kmu@39000)
nrf9160dk_nrf9160.dts.pre.tmp:305.19-311.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@50000000/power@5000)
=== child image spm - end ===
CMake Error at /home/kadal/Nordic-Tools/ncs/zephyr/cmake/app/boilerplate.cmake:76 (add_custom_target):
add_custom_target cannot create target "code_data_relocation_target"
because another target with the same name already exists. The existing
target is a custom target created in source directory
"/home/kadal/Nordic-Tools/projects/microphone". See documentation for
policy CMP0002 for more details.
/home/kadal/Nordic-Tools/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
/home/kadal/Nordic-Tools/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
CMakeLists.txt:9 (find_package)
CMake Error at /home/kadal/Nordic-Tools/ncs/zephyr/cmake/app/boilerplate.cmake:97 (add_custom_target):
add_custom_target cannot create target "runners_yaml_props_target" because
another target with the same name already exists. The existing target is a
CMake Error at /home/kadal/Nordic-Tools/ncs/zephyr/cmake/app/boilerplate.cmake:158 (add_custom_target):
add_custom_target cannot create target "pristine" because another target
with the same name already exists. The existing target is a custom target
created in source directory "/home/kadal/Nordic-Tools/projects/microphone".
See documentation for policy CMP0002 for more details.
CMake Error at /home/kadal/Nordic-Tools/ncs/zephyr/cmake/kconfig.cmake:110 (add_custom_target):
add_custom_target cannot create target "menuconfig" because another target
/home/kadal/Nordic-Tools/ncs/zephyr/cmake/app/boilerplate.cmake:591 (include)
add_custom_target cannot create target "guiconfig" because another target
add_custom_target cannot create target "hardenconfig" because another
target with the same name already exists. The existing target is a custom
add_custom_target cannot create target "menuconfig_ses" because another
error: SB_VALIDATION_INFO_CRYPTO_ID (defined at /home/kadal/Nordic-
Tools/ncs/nrf/subsys/bootloader/bl_validation/Kconfig:28) is assigned in a configuration file, but
is not directly user-configurable (has no prompt). It gets its value indirectly from other symbols.
See http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_SB_VALIDATION_INFO_CRYPTO_ID.html
and/or look up SB_VALIDATION_INFO_CRYPTO_ID in the menuconfig/guiconfig interface. The Application
Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
the manual might be helpful too.
CMake Error at /home/kadal/Nordic-Tools/ncs/zephyr/cmake/kconfig.cmake:239 (message):
command failed with return code: 1
error: cmake failed
create_nordic_project.py failed (1)I am not able to find what is causing the error. Kindly check and guide me to solve the errors and also help me to specify pins as per my circuit for microphone give me syntex to define i2s pins in overlay file.
