Why is RTEComponents.h not updated correctly?
I have enabled a gpiote module, it does not set gpiote_enabled to 1. I have tried deleting the file in the RTE folder with no success. I have tried disabling and enabling that component. I have also tried deleting rte_components.h
As an aside, I tried to enable the TWI module and TWI_COUNT, etc. are not defined. I can only imagine they should be present in nrf_drv_config.h
The file defines this:
#define GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS=4>nrf_drv_gpiote
#define GPIOTE_ENABLED=1>.
    #define GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS=1>.
#define S110
#define SOFTDEVICE_PRESENT
#define SWI_DISABLE0
But nrf_drv_config.h defines this:
#define GPIOTE_ENABLED 0
#if (GPIOTE_ENABLED == 1)
#define GPIOTE_CONFIG_USE_SWI_EGU false
#define GPIOTE_CONFIG_IRQ_PRIORITY APP_IRQ_PRIORITY_HIGH
#define GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS 1
This looks like a bug
  • I am also having the same issue with GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS
    Is that a bug as well or we have to init GPIOTE in a different way in 8.1.1
    Is there a migration guide ?
  • I've hit the same problem with GPIOTE (I'm currently not using TWI).
    The first line in your example appears to be copied to RTE_Components.h from line 390 in version 3.0.0 of NordicSemiconductor.nRF_Libraries.pdsc file when app_button is selected.
    The second and third lines are similarly copied from lines 831 and 832 in version 3.0.0 of NordicSemiconductor.nRF_Drivers.pdsc file when nrf_drv_gpiote is selected.
    Either of these lead to a build failure caused by errors in the resulting macro definitions. This looks wrong. The only information I've found about the .pdsc file suggests that anything in the <RTE_Components_h> element is copied directly to the RTE_Components.h file, which is what seems to be happening. There are examples in several other .pdsc files which look like they will produce similar results.
