NRF52840 USB CDC Serial is missing first character when SOF = 2 and QUEUE_EN = 0 only
The following code has been working fine since it was taken from the examples (NRF52840).
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
// #include "ble_hci.h"
// #include "ble_advdata.h"
// #include "ble_advertising.h"
// #include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
// #include "nrf_ble_gatt.h"
#include "app_timer.h"
// #include "ble_nus.h"
#include "app_uart.h"
//#include "bsp_btn_ble.h"
// #include "nrf_log.h"
// #include "nrf_log_ctrl.h"
// #include "nrf_log_default_backends.h"
#include "nrf_drv_usbd.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_drv_power.h"
#include "app_error.h"
#include "app_util.h"
#include "app_usbd_core.h"
#include "app_usbd.h"
#include "app_usbd_string_desc.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_serial_num.h"
//#define LED_BLE_NUS_CONN (BSP_BOARD_LED_0)
//#define LED_BLE_NUS_RX   (BSP_BOARD_LED_1)
//#define LED_CDC_ACM_CONN (BSP_BOARD_LED_2)
//#define LED_CDC_ACM_RX   (BSP_BOARD_LED_3)
#define RECV_BUF_LEN 256
//#define ENDLINE_STRING "\r\n"
// BLE DEFINES START
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump. Can be used to identify stack location on stack unwind. */
uint32_t buffer_available_idx = 0;
//#define LED_1          NRF_GPIO_PIN_MAP(0,13)
//#define LED_2          NRF_GPIO_PIN_MAP(0,14)
// USB DEFINES START
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                    app_usbd_cdc_acm_user_event_t event);
#define CDC_ACM_COMM_INTERFACE  0
#define CDC_ACM_COMM_EPIN       NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE  1
#define CDC_ACM_DATA_EPIN       NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT      NRF_DRV_USBD_EPOUT1
static char m_cdc_data_array[RECV_BUF_LEN] = {0};
/** @brief CDC_ACM class instance */
APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
                            cdc_acm_user_ev_handler,
                            CDC_ACM_COMM_INTERFACE,
                            CDC_ACM_DATA_INTERFACE,
                            CDC_ACM_COMM_EPIN,
                            CDC_ACM_DATA_EPIN,
                            CDC_ACM_DATA_EPOUT,
                            APP_USBD_CDC_COMM_PROTOCOL_AT_V250);
// USB DEFINES END
// USB CODE START
static bool m_usb_connected = false;
/** @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t */
    //app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
    switch (event)
        case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
            /*Set up the first transfer*/
            ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm, m_cdc_data_array, 1); // necessary it seems
        case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
            //NRF_LOG_INFO("CDC ACM port closed");
            //nrf_gpio_pin_write(LED_1,1);
        case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
            app_usbd_cdc_acm_read_any(&m_app_cdc_acm, m_cdc_data_array, 1);
        case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
            ret_code_t ret;
            do{
                    ret = app_usbd_cdc_acm_read(&m_app_cdc_acm, &m_cdc_data_array[buffer_available_idx++], 1);
            }while (ret == NRF_SUCCESS);
static void usbd_user_ev_handler(app_usbd_event_type_t event)
    switch (event)
        case APP_USBD_EVT_DRV_SUSPEND:
        case APP_USBD_EVT_DRV_RESUME:
        case APP_USBD_EVT_STARTED:
        case APP_USBD_EVT_STOPPED:
            app_usbd_disable();
        case APP_USBD_EVT_POWER_DETECTED:
            //NRF_LOG_INFO("USB power detected");
            if (!nrf_drv_usbd_is_enabled())
                app_usbd_enable();
        case APP_USBD_EVT_POWER_REMOVED:
            app_usbd_stop();
        case APP_USBD_EVT_POWER_READY:
            m_usb_connected = true;
            app_usbd_start();
void usb_cdc_write123(char *str, uint16_t len){
    ret_code_t ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, str,len);
void INIT_usb_cdc(){
    ret_code_t ret;
    static const app_usbd_config_t usbd_config = {
        .ev_state_proc = usbd_user_ev_handler
    app_usbd_serial_num_generate();
    ret = nrf_drv_clock_init();
    APP_ERROR_CHECK(ret);
    //NRF_LOG_INFO("USBD BLE UART example started.");
    ret = app_usbd_init(&usbd_config);
    app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
    ret = app_usbd_class_append(class_cdc_acm);
            // SOFT DEVICE SHIAT
            ret_code_t err_code;
            uint32_t ram_start = 0;
            // Enable BLE stack.
    ret = app_usbd_power_events_enable();
uint32_t usb_cdc_available(){
    return buffer_available_idx;
uint8_t usb_cdc_read(){
        char temp_buf[RECV_BUF_LEN] = {0};
        uint8_t bytey = m_cdc_data_array[0]; // if empty it will be \0
        memcpy(temp_buf, (m_cdc_data_array+1), RECV_BUF_LEN-1);
        memcpy(m_cdc_data_array, temp_buf, RECV_BUF_LEN);
        if (buffer_available_idx > 0)
            buffer_available_idx--;
        if (buffer_available_idx == 0)
            memset(m_cdc_data_array, 0, RECV_BUF_LEN);
        return bytey;
void SVC_usb_cdc(){
        // removed since we are using the interrupt method now
        // //while (app_usbd_event_queue_process())
        //     /* Nothing to do */
We wanted to remove the  app_usbd_event_queue_process() so we enabled these 2 options in the sdk_config.h (config file was also from the example)
APP_USBD_CONFIG_EVENT_QUEUE_ENABLE = 0
APP_USBD_CONFIG_SOF_HANDLING_MODE = 2
We now have 2 issues with the above code:
- One appeared immediately after turning ON the interrupt mode 2 and queue = 0. The first character was being lost on any size transmission. We tried many solutions but no result. The first received character always gets eaten.
- The second issue is that some characters are being lost on more frequent, repetitive prints. We are happy to do more analysis for the second issue. We hope we can start by fixing issue 1.
Finally should we want to return back to using app_usbd_event_queue_process() if there is no solution, what are the implications when we want to go to sleep? Can we get awaken by a USB event and then service the queue? Any caveats? Is the interrupt way with no queue, better?
Thanks!
    I spent some time looking into your example today. I think I found the root cause of all issues, but I do not have a good solution for all:
    1. Initially, the first missing character is caused by how you call app_usbd_cdc_acm_read(). This function will only provide a buffer to the USBD library, which will be filled when data is coming in over USB. When the port is opened, you provide the first byte of the buffer as the initial buffer to the library. When the first byte is received, you provide the same byte of the buffer to the library (since buffer_available_idx is 0). You can resolve this by also incrementing buffer_available_idx in APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN, and wait until buffer_available_idx > 1 before writing back the data in main().
    2. When you write back the data in main(), you do not check the return codes of the calls to app_usbd_cdc_acm_write(). This function will return an error if another write operation is ongoing. You need to wait for the APP_USBD_CDC_ACM_USER_EVT_TX_DONE event before starting a new transfer. You can resolve this by setting a flag in the event handler and wait for this before starting the next transfer.
    3. When you are done writing the data back, you reset buffer_available_idx to 0, but you do still have 1 byte buffer passed to the library from the latest call to app_usbd_cdc_acm_read(). When you send the second string from the terminal, the first byte will be store at the last buffer_available_idx, while subsequent bytes will be stored from 0 and upwards. This will possibly overwrite the first byte (if the string is longer than the previous). I cannot see any API to cancel a buffer, so this issue I do not have a good solution to at the moment.
    4. One final issue is that the USB running at interrupt may preempt the execution of the main loop while writing the data. If data is received between the second call to app_usbd_cdc_acm_write and the reset of the buffer_available_idx variable, you may also lose these bytes.
    Attaching my main.c which works apart from the missing first byte of second and subsequent strings:
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "nrfx.h"
    volatile uint32_t buffer_available_idx = 0;
    static bool usbd_tx_done = true;
                                CDC_ACM_COMM_EPIN,
                                CDC_ACM_DATA_EPIN,
                                CDC_ACM_DATA_EPOUT,
        switch (event)
                //ret_code_t ret =
                app_usbd_cdc_acm_read(&m_app_cdc_acm, &m_cdc_data_array[buffer_available_idx++], 1);  // necessary it seems
                //app_usbd_cdc_acm_read_any(&m_app_cdc_acm, m_cdc_data_array, 1);
                //app_usbd_cdc_acm_read(&m_app_cdc_acm, &m_cdc_data_array[0], 1);
                ret_code_t ret;
                //if (app_usbd_cdc_acm_bytes_stored(&m_app_cdc_acm) > 0){
                //ret = app_usbd_cdc_acm_read(&m_app_cdc_acm, &m_cdc_data_array[buffer_available_idx++], 1);
                do{
        switch (event)
                app_usbd_disable();
                    app_usbd_enable();
                app_usbd_stop();
                app_usbd_start();
        ret_code_t ret;
        ret = nrf_sdh_enable_request();
    int main(void){
        INIT_usb_cdc();
        ret_code_t ret;
        while(1)
            if (buffer_available_idx>1){
                while(usbd_tx_done == false);
                usbd_tx_done = false;
                ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, ">> ", 3);
                if(ret == NRF_SUCCESS)
                    ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_cdc_data_array, buffer_available_idx-1);
                        buffer_available_idx=0;
    Jørgen
  • Thanks so much for looking at it Jorgen!
    Adding a delay of 100uS or a while(flag) check, after the app_usbd_cdc_acm_write also fixes the loss of any TX data (my original issue no2). I have confirmed that with my larger codebase and this example. I dont see any loss when transmitting in bursts anymore. I think it solves the same issue as the usbd_tx_done flag does in your code above.
    Regarding the missing first character during RX, I tried improving the code as per your suggestions but I cant get it to go away either. Only the first string is received well.
    - Do you think its something related to the CDC APP? Shall I start poking in app_usbd_cdc_acm.c?
    - Shall I try a different SDK?
    I am basically a little unclear as to what I should try next. Any pointers would be welcome!
    It is related to how the API works and how you are using it. Like I said, the problem is that the app_usbd_cdc_acm_read() function only provides a buffer to the CDC ACM library, that will be filled with received data sometime in the future. This means that when you reset the pointer to start receiving bytes at the start of the buffer again, there will already be one byte later in the buffer that is already provided to the library. You can work around this by copying the last byte into the first index when you have preformed the write operation:
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "nrfx.h"
    volatile uint32_t last_buffer_idx = 0;
                                CDC_ACM_COMM_EPIN,
                                CDC_ACM_DATA_EPIN,
                                CDC_ACM_DATA_EPOUT,
        switch (event)
                //ret_code_t ret =
                ret_code_t ret;
                if(last_buffer_idx != 0)
                    memcpy(&m_cdc_data_array[buffer_available_idx], &m_cdc_data_array[last_buffer_idx], 1);
                    buffer_available_idx++;
                do{
        switch (event)
                app_usbd_disable();
                    app_usbd_enable();
                app_usbd_stop();
                app_usbd_start();
        ret_code_t ret;
    int main(void){
        INIT_usb_cdc();
        ret_code_t ret;
        while(1)
                        last_buffer_idx = buffer_available_idx - 1;
    You may also use a similar approach to store multiple bytes received during the write in main (as I described in point 4 above).
    Another solution would be to use a ring buffer, instead of resetting the index to the start of the buffer after every read. This will allow you to store the current read and write index of the buffer, to always be able to write the last read bytes. See Ring buffer library in the SDK.
  • Just wanted to come back to this and say that everything is working well. Your initial code helped me understand the way the SDK code was triggering on new data and work from there.
    Had some timing issues when a lot of data was flowing between the USB and UARTs but that was solved with a nice circ buffer.
    Thanks for taking the time to help me and sorry for replying late.
