Generate package to migrate SD+BL+APP from SDK15 to SDK17
Hi all,
First I would like to notice that I did look into the forum and found this similar question which did not solve my problem:
https://devzone.nordicsemi.com/f/nordic-q-a/27862/update-sd-bl-app-from-sdk-v13-to-v14-via-dfu-fails
My problem:
  1. I have custom boards that have APP+SD+BL running based on nRF5_SDK_15.2.0 (sd_id 0xAF).
  2. I have an application project and a bootloader project that work with nRF5_SDK_17.0.2. If I merge the SD+BL+APP .hex files and program the custom board with the resulting .hex with a JLINK programmer the code runs as expected
  3. If I generate a DFU .zip with the same content the DFU fails (I am performing DFU over BLE with nRFConnect android APP).
    1. The DFU starts and does the first part (BL+SD?)
    2. Then the app disconnects and tries to connect again as expected for the second part of the DFU (right?)
    3. It stays like this for a while without being able to connect. Then it stops trying and the DFU is not completed.
This is what I have regarding the nrfutil package generation:
dfu_bootloader_sd_app:
	@nrfutil pkg generate --hw-version 52 --sd-req 0xAF,0x101 --application-version 5 --bootloader $(BOOTLOADER) --bootloader-version 0 --softdevice $(SOFTDEVICE) --sd-id 0x101 --application $(APPLICATION) --key-file $(KEY_FILE) $(OUTPUT_ZIP)
Can you please provide some insight?
Pedro
  • Hi Perdo,
    Have you made sure the start address of the 2 bootloaders are the same ? I had a quick check here with the bootloader _debug version, the one in SDK v15.2 start at address 0x72000 when the one in SDK v17.0.2 starts at address 0x71000.
    They should be the same.
    I attached here the file I used for testing (it worked fine).
    I used this script to generate the .zip file:
    nrfutil pkg generate --hw-version 52 --sd-req 0xAF --sd-id 0x0101 --softdevice s132_nrf52_7.2.0_softdevice.hex  --bootloader-version 2 --bootloader Bootloader_SDK17.hex --key-file private.key sd_bl.zip
    Please unzip this:
    DFU_SD_BL.zip
    indeed the variable FLASH_START=0x78000 was differing in both bootloader projects. Now, after DFU with Soft Device + Bootloader the device advertises as the bootloader!
    However, when performing DFU with full package the Application still does not start. Instead the bootloader starts.
    What could still be wrong?
    Pedro
  • Hi Pedro,
    If you do it manually (2 .zip files, one SD+BL and one APP) would it work  ?
    We need to look into why the DFU of the APP was not executed automatically.
    Please provide the log on the phone app and let us know the app version  you are using. Have you tried both nRF Toolbox and NRF Connect ?
  • Hi Hung,
    No, I have the same problem. BL+SD dfu returns success popup and advertises as bootloader. APP, DFU after BL+SD dfu returns success popup but the APP does not boot (stays in bootloader instead).
    Yes, tried with nRF Toolbox, same problem.
    Bellow you may find attached the log of NRF Connect after a DFU of BL+SD+APP.
    Log 2021-02-17 14_24_01.txt
    Edit:
    Just tried the following:
    1. Flashed SD+BL by merging hex files and using nrfjprog
    2. performed DFU with the same APP Zip generated earlier for the 2 zip test and worked correctly.
  • Hi Pedro,
    Please  try testing again using stock images (bootloader and apps)
    I tested here and  got no problem upgrade to SDK 17 app.
    You may want to try debugging  the bootloader to see if anything wrong.
    I attached here the file I used. My test's steps:
    1. Flash bootloader+SDK v15.2
    2. DFU update app_SDK15.zip
    3. DFU update sd_bl_SDK17.zip
    4. DFU update app_SDK17.zip
    After step 4 the device works as expected.
    DFU_SD_BL_18Feb.zip
