configuring multiple saadc channels
I want to configure 2 channels of saadc in differential mode as follows:
void saadc_init(void) //ok
    ret_code_t err_code;
	nrf_saadc_channel_config_t channel_config1 =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_DIFFERENTIAL(NRF_SAADC_INPUT_AIN4,NRF_SAADC_INPUT_AIN6);
	nrf_saadc_channel_config_t channel_config2 =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_DIFFERENTIAL(NRF_SAADC_INPUT_AIN5,NRF_SAADC_INPUT_AIN7);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config1);
		err_code = nrf_drv_saadc_channel_init(1, &channel_config2);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
		nrf_saadc_continuous_mode_enable(800);
But when I received data, it seems that only the channel that its channel index is zero is enabled. may you help me to find the issue and configure this 2 channel in scan mode? i am working based on the saadc example in sk17.
