NRF51 DK - Not recognized/not Blinking/Error on drag and drop
Currently I work on an NRF51 DK, by mistake I replace my bootloader by and .hex or .bin file with a drag and drop.
The LED 5 don't blinking and my computer don't detect the device but I have a voltage on VDD. When I want to do --eraseall, the computer says "There is no debugger connected to the pc".
Someone have an idea to fix this ?
Téo DHIEN-FANE
  • Yes the card is well supplied and switched on, I tested with another cable and it is the same and I have no LED on.
    I have another DK I tried the previous manipulation and it works fine.
    Before having the problem I did a bad manipulation I managed to display Bootloader in the file explorer and I drag and drop a .hex file and I think that's what put it in a weird state.
    I did not connect any equipment besides only the usb cable.
    It's possible to do a hard factory reset ?
    If the firmware on the interface MCU is corrupted and it is no longer possible to put it in DFU mode, then I do not see any other way to recover than to hook it up to an external debugger. There is no header for that on the DK though so it might be a bit difficult. Perhaps it would be best to just scrap the board. It is interesting though, I do not recall ever seeing such an issue before, and it is a bit odd that you were able to break it by copying a .hex onto it.
