libuarte init with ANT softdevice ?
Dear Members,
I want to use libuarte with ANT and softdevice,
When I initialize libuarte,
The app keeps restarting by itself.
/**********init from libuarte*****/
			 //err_code=nrf_drv_clock_init();
			 //APP_ERROR_CHECK(err_code);
			// NRF_LOG_INFO("Err_code nrf_drv_clk %u",err_code);
			  //nrf_drv_clock_lfclk_request(NULL);
				nrf_libuarte_async_config_t nrf_libuarte_async_config1 = {
            .tx_pin     = SER_APP_TX_PIN,
            .rx_pin     = SER_APP_RX_PIN,
            .baudrate   = NRF_UARTE_BAUDRATE_9600,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 1000,
            .int_prio   = APP_IRQ_PRIORITY_LOW
		err_code=nrf_libuarte_async_init(&libuarte1, &nrf_libuarte_async_config1, uart_event_handler1, (void *)&libuarte1);
		NRF_LOG_INFO("Err_code libuarte_init libuarte1 %u",err_code);
  	nrf_libuarte_async_enable(&libuarte1);
    GPS_Init();
I commented out
//nrf_libuarte_async_enable(&libuarte1);
to stabilize the application,
libuarte setting :
NRF_LIBUARTE_ASYNC_DEFINE(libuarte1, 1, 2, 2, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3); //timer0 id =2, rtc1 id =2
what do I miss here ? is it related with my app timer conflicting with libuarte timer ?
I get this in my log  :
<error> hardfault: HARD FAULT at 0x00017FB8
<error> hardfault:   R0:  0x20001064  R1:  0x39000000  R2:  0x00000010  R3:  0x0000000F
<error> hardfault:   R12: 0x20000E08  LR:  0x0001E39F  PSR: 0x21000029
<error> hardfault: Cause: Data bus error (PC value stacked for the exception return points to the instruction that caused the fault).
<error> hardfault: Bus Fault Address: 0x39000000
Is
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
conflicting with my current UART setting for NRF_LOG in softdevice ? it's using the same port UART0
Thanks
    It is not clear to me how your application looks, so it is difficult to suggest much.
    I noticed this though:
    I commented out
    The first two is not directly related to the libuarte, and if you use a SoftDevice the LFCKL is allready started, so it does not matter if you use it or not. However, you need to call nrf_libuarte_async_enable() before using it. To be honest it is not so reassuring if you comment out blindly in order to attempt to stabilize the application. May I suggest you refer to the libuarte example in the SDK? That shows you how to use it.
    Once you understand the example you can copy it to your application and make necessary adjustments, where we come to this:
    Is
    Yes, you cannot use the same peripheral for two things (at the same time). The libuarte is quite resource intensive, and needs a UARTE instance two timers and and RTC, as you can see from the API doc of NRF_LIBUARTE_ASYNC_DEFINE. You need to ensure that there are no overlaps. When doing so, keep in mind that the SoftDevice use TIMER0 and RTC0. So that cannot be used. The app_timer use RTC1, which you typically want to use, so that should also be avoided.
  • it works well when I implement from the libuarte example, but when I merge with ANT and softdevice, it's stop working....
  • I'm using libuarte for UART1 only now,
    and the app gives me  :
    rror> app: Fatal error
    arning> app: System reset
  • rror> hardfault: HARD FAULT at 0x00017FB8
    0000F
