Simple thermistor ADC reading
First off, forgive me for being a newbie at ARM programming in general. In AVR this was straight forward.
Simple thermistor
I have a circuit connected like this to the ADC (P0.01 = AnalogInput2) .
I read sensible values from the thermistor if I have this ADC setup:
NRF_ADC->INTENSET = ADC_INTENSET_END_Msk;
sd_nvic_SetPriority(ADC_IRQn, NRF_APP_PRIORITY_LOW);
sd_nvic_EnableIRQ(ADC_IRQn);
NRF_ADC->CONFIG = (ADC_CONFIG_EXTREFSEL_None << ADC_CONFIG_EXTREFSEL_Pos)
	| (ADC_CONFIG_PSEL_AnalogInput2 << ADC_CONFIG_PSEL_Pos)
	| (ADC_CONFIG_REFSEL_SupplyOneThirdPrescaling << ADC_CONFIG_REFSEL_Pos)
	| (ADC_CONFIG_INPSEL_AnalogInputOneThirdPrescaling <<  ADC_CONFIG_INPSEL_Pos)
	| (ADC_CONFIG_RES_10bit << ADC_CONFIG_RES_Pos);
NRF_ADC->ENABLE = ADC_ENABLE_ENABLE_Enabled;
Could someone explain me why this just works? I thought I had to use "ADC_CONFIG_REFSEL_SupplyOneHalfPrescaling" and "ADC_CONFIG_INPSEL_AnalogInputNoPrescaling", since the divider would be half of the supply since 10kohm resistor and 1kohm thermistor would divide the voltage in half.
  • Yeah, I was just curious about what kind of resistance that is too much.
    Thanks again for your help!
  • I guess as long as the ratio between the thermistor and resistor stays the same you will be fine. I.e. that the maximum resistance in the thermistor is equal to the resistor value. Also, if you are going to have a high sample rate then you should pay some attention to the resitances and also add in a capacitor like discussed in this thread.
  • Thanks! The sample rate will be low, so not an issue. Thanks for clearing all of this up! I will check out the reference, blog and the thread. :)
1 2
