How to send data to UART for the provisioner example of mesh sdk.
I am using nrf17.02 sdk and nrf mesh 5.0 sdk for nrf52832 dev kit.
1) I want to send the data to UART not on RTT while using the mesh example "provisioner" example of mesh sdk in place "meshsdk/example/provisioner". How to procees with it, can anyone help me?
2) I combined uart example of nrf 17.0 sdk with the provisioner example of mesh sdk but not able to receive the data over UART. Is this the right way to do, can i use uart example with the provisioner, if yes then can you please provide me the source code, as for me it is not working, i am not sure if having some issues in combining both the project of both sdks.
3) Can i use the provisioner code for dongle nrf52840(PCA10059) where i want to get data over USB, as it is mentioned in nordic infocenter that we can not. If we can then can you please provide me with required source code.
If anyone can help me, it is very helpful for me to proceed. Can anyone help me with high priority?
Thanks & Regards,
Ela
  • Hi Mttrinh,
    1) Yes i have copied the ble_app_uart_coexist folder into ble_peripheral folder and set the MESH_ROOT in global macros to the mesh sdk path.
    2) In UART example there is not uart_event_handle function. I have implemented the uart_event_handler as per my application, attaching that code :
    void uart_event_handler(app_uart_evt_t * p_event)
        static uint8_t data_array[244];
        static uint8_t index = 0;
       // static uint8_t val = 0;
        uint32_t       err_code;
         //printf("\r\nUART started uart event handler.\r\n");
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                printf("Data array in switch %c\r\n",data_array[index]);
                index++;
                 if ( data_array[index - 1] == '1')
                   printf("Sucess pressed 1 \r\n");
                   check_network_state();
                   index = 0;
                   memset(data_array[index], 0 , sizeof(data_array[index]));
                if ( data_array[index - 1] == '2')
                   printf("Sucess pressed 2\r\n");
                   provisioning_resume();
                   index = 0;
                 if ( data_array[index - 1] == '4')
                   printf("Sucess pressed 4 \r\n");
                     if (mesh_stack_is_device_provisioned())
                       /* Clear all the states to reset the node. */
                       provisioner_invalidate();
                       mesh_stack_config_clear();
                   node_reset();
                   index = 0;
                #if 0
                if ( data_array[index - 1] == ';')
                   printf("sucess \r\n");
                   index = 0;
            case APP_UART_FIFO_ERROR:
    Is this the right way to do this? As i am not able to get command response after sometime. If i am pressing 4 nothing is happening some random letter is getting printed. If i am pressing 2 not able to recive back any command. What i am missing here, can you please let me know?
    Thanks & Regards,
    Ela
  • Hi Mttrinh,
    Can you please provide the implementation code for using UART logging for provisioner example code in mesh sdk , so that we are able to provision the unprovisioned nodes.
    I have shared the implementation with you, but not able to achieve the desired result, not able to provision the unprovisioned nodes. I am attaching the main.c file what i have used for the UART logging and getting provision event handlers in uart_event_handler.
    It will be very helpful if i can get the quickest response as its been long raising this issue, causing delay for me, i hope you understand .
    /* Copyright (c) 2010 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    #include "nrf_delay.h"
    #include "simple_hal.h"
    #include "app_timer.h"
    /* Core */
    #include "nrf_mesh.h"
    #include "nrf_mesh_events.h"
    #include "nrf_mesh_assert.h"
    #include "access_config.h"
    #include "device_state_manager.h"
    #include "mesh_stack.h"
    #include "net_state.h"
    #include "mesh_opt_provisioner.h"
    #include "mesh_config_entry.h"
    #include "mesh_opt.h"
    /* Provisioning and configuration */
    #include "provisioner_helper.h"
    #include "node_setup.h"
    #include "mesh_app_utils.h"
    /* Models */
    #include "config_client.h"
    #include "config_server.h"
    #include "health_client.h"
    /* Logging and RTT */
    #include "rtt_input.h"
    #include "log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_uart.h"
    #include "app_uart.h"
    //#include "nrf_log_backend_interface.h"
    /* Example specific includes */
    #include "example_network_config.h"
    #include "nrf_mesh_config_examples.h"
    #include "ble_softdevice_support.h"
    #include "example_common.h"
     * Definitions
    #define APP_PROVISIONING_LED            BSP_LED_0
    #define APP_CONFIGURATION_LED           BSP_LED_1
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    static bool m_device_provisioned;
     * Forward declaration of static functions
    static uint32_t provisioner_setter(mesh_config_entry_id_t id, const void * p_entry);
    static void provisioner_getter(mesh_config_entry_id_t id, void * p_entry);
    static void provisioner_deleter(mesh_config_entry_id_t id);
    static void app_health_event_cb(const health_client_t * p_client, const health_client_evt_t * p_event);
    static void app_config_successful_cb(void);
    static void app_config_failed_cb(void);
    static void app_mesh_core_event_cb (const nrf_mesh_evt_t * p_evt);
    static void app_start(void);
     * Static variables
    /* Required for the provisioner helper module */
    static network_dsm_handles_data_volatile_t m_dev_handles;
    static network_stats_data_stored_t m_nw_state;
    static bool m_node_prov_setup_started;
    static nrf_mesh_evt_handler_t m_mesh_core_event_handler = { .evt_cb = app_mesh_core_event_cb };
    NRF_MESH_STATIC_ASSERT(MESH_OPT_FIRST_FREE_ID <= MESH_APP_FILE_ID);
    MESH_CONFIG_FILE(m_provisioner_file, MESH_APP_FILE_ID, MESH_CONFIG_STRATEGY_CONTINUOUS);
    MESH_CONFIG_ENTRY(provisioner,
                      PROVISIONER_ENTRY_ID,
                      1,
                      sizeof(network_stats_data_stored_t),
                      provisioner_setter,
                      provisioner_getter,
                      provisioner_deleter,
                      false);
        __LOG(LOG_SRC_APP, LOG_LEVEL_DBG1, "Provisioner setter ...\n");
        NRF_MESH_ASSERT_DEBUG(PROVISIONER_RECORD == id.record);
        network_stats_data_stored_t * p_nsds = (network_stats_data_stored_t *) p_entry;
        memcpy(&m_nw_state, p_nsds, sizeof(network_stats_data_stored_t));
        return NRF_SUCCESS;
        __LOG(LOG_SRC_APP, LOG_LEVEL_DBG1, "Provisioner getter ...\n");
        network_stats_data_stored_t * p_nw_state = (network_stats_data_stored_t *) p_entry;
        memcpy(p_nw_state, &m_nw_state, sizeof(m_nw_state));
        __LOG(LOG_SRC_APP, LOG_LEVEL_DBG1, "Provisioner deleter ...\n");
        /* Clear and set default values. */
        memset(&m_nw_state, 0x00, sizeof(m_nw_state));
    static void provisioner_store(void)
        printf("store \r\n");
        mesh_config_entry_id_t id = PROVISIONER_ENTRY_ID;
        NRF_MESH_ERROR_CHECK(mesh_config_entry_set(id, &m_nw_state));
    static void provisioner_invalidate(void)
        /* Stop scanner. */
        prov_helper_scan_stop();
        /* Delete all old values and remove from mesh config. */
        (void)mesh_config_entry_delete(PROVISIONER_ENTRY_ID);
    static void app_data_store_cb(void)
        provisioner_store();
    /**** Configuration process related callbacks ****/
         printf("config \r\n");
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Configuration of device %u successful\n", m_nw_state.configured_devices);
        hal_led_pin_set(APP_CONFIGURATION_LED, 0);
        hal_led_pin_set(APP_PROVISIONING_LED, 1);
        m_nw_state.configured_devices++;
        prov_helper_provision_next_device();
        prov_helper_scan_start();
        printf(" main .c file scan done \r\n");
          printf(" main.c file app_config failed \r\n");
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Configuration of device %u failed.\n", m_nw_state.configured_devices);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Press Button/RTT 1 to retry configuration.\n");
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Press Button/RTT 2 to start provisioning new nodes.\n");
        m_node_prov_setup_started = false;
    static void app_prov_success_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Provisioning successful\n");
        hal_led_pin_set(APP_PROVISIONING_LED, 0);
        hal_led_pin_set(APP_CONFIGURATION_LED, 1);
    static void app_prov_failed_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Provisioning failed. Press Button 1 to retry.\n");
    /**** Model related callbacks ****/
        switch (p_event->type)
            case HEALTH_CLIENT_EVT_TYPE_CURRENT_STATUS_RECEIVED:
                __LOG(LOG_SRC_APP,
                      LOG_LEVEL_INFO,
                      "Node 0x%04x alive with %u active fault(s), RSSI: %d\n",
                      p_event->p_meta_data->src.value,
                      p_event->data.fault_status.fault_array_length,
                      ((p_event->p_meta_data->p_core_metadata->source == NRF_MESH_RX_SOURCE_SCANNER)
                           ? p_event->p_meta_data->p_core_metadata->params.scanner.rssi
                           : 0));
    static void app_config_server_event_cb(const config_server_evt_t * p_evt)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "config_server Event %d.\n", p_evt->type);
        if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
            /* This should never return */
            hal_device_reset(0);
    static void app_config_client_event_cb(config_client_event_type_t event_type, const config_client_event_t * p_event, uint16_t length)
        /* USER_NOTE: Do additional processing of config client events here if required */
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Config client event\n");
        /* Pass events to the node setup helper module for further processing */
        node_setup_config_client_event_process(event_type, p_event, length);
    static void provisioning_start(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Start provisioning procedure ...\n");
    static void provisioning_resume(void)
        if (!m_node_prov_setup_started)
            /* If previously provisioned device is not configured. */
            if (m_nw_state.configured_devices < m_nw_state.provisioned_devices)
                m_nw_state.provisioned_devices--;
                provisioning_start();
                m_node_prov_setup_started = true;
    /** Check if all devices have been provisioned. If not, provision remaining devices.
     *  Check if all devices have been configured. If not, start configuring them.
    static void check_network_state(void)
       printf(" check \r\n");
            /* If previously provisioned device is not configured, start node setup procedure. */
                /* Execute configuration */
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Waiting for provisioned node to be configured ...\n");
                node_setup_start(m_nw_state.last_device_address, PROVISIONER_RETRY_COUNT,
                                m_nw_state.appkey, APPKEY_INDEX, NETKEY_INDEX, m_nw_state.current_uri);
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Waiting for previous procedure to finish ...\n");
        /* USER_NOTE: User can insert mesh core event processing here */
        switch(p_evt->type)
            /* Start user application specific functions only when stack is enabled */
            case NRF_MESH_EVT_ENABLED:
                __LOG(LOG_SRC_APP, LOG_LEVEL_DBG1, "Mesh evt: NRF_MESH_EVT_ENABLED\n");
    #if (PERSISTENT_STORAGE)
                /* Mesh stack initialization has been completed */
                app_start();
            case NRF_MESH_EVT_CONFIG_LOAD_FAILURE:
                if (p_evt->params.config_load_failure.id.file == MESH_APP_FILE_ID)
                    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Persistent provisioner data was corrupted. Set default values. \n");
    /* Binds the local models correctly with the desired keys */
    void app_default_models_bind_setup(void)
        /* Bind health client to App key, and configure publication key */
        ERROR_CHECK(access_model_application_bind(m_dev_handles.m_health_client_instance.model_handle, m_dev_handles.m_appkey_handle));
        ERROR_CHECK(access_model_publish_application_set(m_dev_handles.m_health_client_instance.model_handle, m_dev_handles.m_appkey_handle));
        /* Bind self-config server to the self device key */
        ERROR_CHECK(config_server_bind(m_dev_handles.m_self_devkey_handle));
    static void node_reset(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
        hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
        /* This function may return if there are ongoing flash operations. */
        mesh_stack_device_reset();
    #if NRF_MESH_LOG_ENABLE
    static const char m_usage_string[] =
        "\n"
        "\t\t--------------------------------------------------------------------------------\n"
        "\t\t Button/RTT 1) Initiate provisioning and configuration of unprovisioned devices.\n"
        "\t\t Button/RTT 4) Clear all the states to reset the node.\n"
        "\t\t--------------------------------------------------------------------------------\n";
    static void button_event_handler(uint32_t button_number)
        /* Increase button number because the buttons on the board is marked with 1 to 4 */
        button_number++;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
        switch (button_number)
            case 1:
                /* Check if all devices have been provisioned or not */
            case 2:
            /* Initiate node reset */
            case 4:
                node_reset();
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, m_usage_string);
    //#if 0
    static void app_rtt_input_handler(int key)
        if (key >= '1' && key <= '4')
            uint32_t button_number = key - '1';
            button_event_handler(button_number);
    //#endif
    #if 0
    static void app_uart_input_handler(int key)
           // uint32_t button_number = key - '1';
            uart_event_handler(key);
    void models_init_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
        m_dev_handles.m_netkey_handle = DSM_HANDLE_INVALID;
        m_dev_handles.m_appkey_handle = DSM_HANDLE_INVALID;
        m_dev_handles.m_self_devkey_handle = DSM_HANDLE_INVALID;
        /* This app requires following models :
         * config client : To be able to configure other devices
         * health client : To be able to interact with other health servers */
        ERROR_CHECK(config_client_init(app_config_client_event_cb));
        ERROR_CHECK(health_client_init(&m_dev_handles.m_health_client_instance, 0, app_health_event_cb));
    static void mesh_init(void)
        bool device_provisioned;
        mesh_stack_init_params_t init_params =
            .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
            .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
            .models.models_init_cb   = models_init_cb,
            .models.config_server_cb = app_config_server_event_cb
        nrf_mesh_evt_handler_add(&m_mesh_core_event_handler);
        uint32_t status = mesh_stack_init(&init_params, &device_provisioned);
        switch (status)
            case NRF_ERROR_INVALID_DATA:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data in the persistent memory was corrupted.\n");
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reboot device before starting of the provisioning process.\n");
            case NRF_SUCCESS:
                ERROR_CHECK(status);
        if (status == NRF_SUCCESS)
            /* Initialize the provisioner */
            mesh_provisioner_init_params_t m_prov_helper_init_info =
                .p_dev_data = &m_dev_handles,
                .p_nw_data = &m_nw_state,
                .netkey_idx = NETKEY_INDEX,
                .attention_duration_s = ATTENTION_DURATION_S,
                .p_data_store_cb  = app_data_store_cb,
                .p_prov_success_cb = app_prov_success_cb,
                .p_prov_failed_cb = app_prov_failed_cb
            prov_helper_init(&m_prov_helper_init_info);
            if (!device_provisioned)
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setup defaults: Adding keys, addresses, and bindings \n");
                prov_helper_provision_self();
                app_default_models_bind_setup();
                app_data_store_cb();
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Restored: Handles \n");
                prov_helper_device_handles_load();
            node_setup_cb_set(app_config_successful_cb, app_config_failed_cb);
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        uint32_t       err_code;
                index++;
                   index = 0;
                   index = 0;
                   node_reset();
                   index = 0;
                #if 0
                   index = 0;
    #if 0
      //   printf("\r\nUART started uart event handler provisioner code .\r\n");
           while (true)
            uint8_t cr;
            while (app_uart_get(&cr) != NRF_SUCCESS);
            printf("\r\n cr \r\n %d",cr);
            while (app_uart_put(cr) != NRF_SUCCESS);
            if (cr == '1')
                printf(" \r\n 1 pressed \r\n");
                while (true)
                    // Do nothing.
            if (cr == '2')
            printf("\r\n 2 pressed ");
             while (true)
                    // Do nothing.
            if (cr == '4')
                printf("\r\n 4 pressed \r\n");
                node_reset();
                 while (true)
                    // Do nothing.
            printf("\r\n else\r\n");
    #if 0
        uint32_t i;
        switch(i)
        case 1:
         printf("\r\n Pressing 1 for scanning the unprovisioned nodes Uart event handler provisioner code .\r\n");
        case 2:
        case 4:
                printf("\r\n Pressing 4 for resetting the provisioned nodes Uart event handler provisioner code .\r\n");
                node_reset();
    #endif // for uart event handler
    #if 0
     //printf("\r\nUART started uart event handler provisioner code .\r\n");
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
    #if defined (UART_PRESENT)
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handler,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    static void initialize(void)
          uart_init();
       // __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_FRIEND, LOG_LEVEL_DBG1, log_callback_rtt);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Static Provisioner Demo -----\n");
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
    #if BUTTON_BOARD
        ERROR_CHECK(hal_buttons_init(button_event_handler));
        ble_stack_init();
        mesh_init();
        node_setup_uri_check();
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Starting application ...\n");
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Provisioned Nodes: %d, Configured Nodes: %d\n",
              m_nw_state.provisioned_devices, m_nw_state.configured_devices);
        __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Dev key ", m_nw_state.self_devkey, NRF_MESH_KEY_SIZE);
        __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Net key ", m_nw_state.netkey, NRF_MESH_KEY_SIZE);
        __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "App key ", m_nw_state.appkey, NRF_MESH_KEY_SIZE);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Press Button/RTT 1 to start provisioning and configuration process. \n");
    static void start(void)
        rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
       // rtt_input_enable(app_uart_input_handler, RTT_INPUT_POLL_PERIOD_MS);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "<start> \n");
        ERROR_CHECK(mesh_stack_start());
    #if (!PERSISTENT_STORAGE)
        app_start();
        hal_led_mask_set(HAL_LED_MASK, LED_MASK_STATE_OFF);
        hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
     #if 0
    static void log1_init(void)
    #if 0
    void my_uart_callback(nrfx_uarte_event_t const * p_event,
                          void *                     p_context)
        //TODO: Handle 'p_event'
       // nrfx_uarte_t m_uart = NRFX_UARTE_INSTANCE(0);
        //nrfx_uarte_config_t m_uart_config = NRFX_UARTE_DEFAULT_CONFIG;
       // nrfx_uarte_init(&m_uart, &m_uart_config, my_uart_callback);
        // uart_init();
         //log1_init();
     //   ret_code_t err_code = NRF_LOG_INIT(NULL);
      //  APP_ERROR_CHECK(err_code);
        // NRF_LOG_DEFAULT_BACKENDS_INIT();
        initialize();
        printf("\r\nUART started main provisioner code .\r\n");
        start();
        for (;;)
            (void)sd_app_evt_wait();
    Thanks & Regards,
    Ela
  • Hi Mttrinh,
    It will be very helpful if a working code can be provided as reference for the desired output.
    Thanks & Regards,
    Ela
  • Hi Mttrinh,
    Thanks & Regards,
    Ela
    This is strange, I would suggest you try download a fresh copy of the SDKs and see if that helpes solve this.
    As for the implementation, unfortunately we don't have an exact example to show you how to do this. Your implementation of your uart handler seems correct. Have you tried debugging through the code to see what happens? Does the code enter the uart handler when you send the commands?
    It looks like in your main that you don't call uart_init()?
