I managed to compile and run(?) my first two programs for nrf51 dongle on Keil uVision, however while i think they run I cannot make the debugger work and see what they do.
The UART outputs is emply, both in the uVision and when I try the Termite terminal. Well on termite I can get some garbage, but no matter what settings I use there I cannot get it to show anything human readable. Then I found the J-link web control panel. And on there is subpage showing log. Most of the log, while the application is running looks like this:
T4DC0 443:948.711 JLINK_IsHalted() T4DC0 443:949.376 - 0.675ms returns FALSE T4DC0 444:050.450 JLINK_HasError() T4DC0 444:050.530 JLINK_IsHalted() T4DC0 444:051.235 - 0.796ms returns FALSE T4DC0 444:152.242 JLINK_HasError() T4DC0 444:152.319 JLINK_IsHalted() T4DC0 444:153.129 - 0.849ms returns FALSE T4DC0 444:253.916 JLINK_HasError() T4DC0 444:254.008 JLINK_IsHalted() T4DC0 444:254.879 - 0.910ms returns FALSE T4DC0 444:355.449 JLINK_HasError() T4DC0 444:355.820 JLINK_IsHalted()How can I fix this? Thanks
Make sure that you have this in sdk_config.h
#define NRF_LOG_ENABLED 1
Take a look at how it's done in the pca10031(nRF51 dongle) RNG example project, in folder SDK_12\examples\peripheral\rng\pca10031…
For the teminal software I'm using "Termite". The nrfjprog --eraseall has helped!!! It works now. I can see a series of messages: APP:INFO:FE F8 4C 29 99 31 12 71 D1 98 F2 96 E0 DB AB 15 þøL).1.q..ò.à.«.APP:INFO:APP:INFO:Random Vector:APP:INFO:98 7B 3B 28 9D 99 A0 97 6F 73 ED F0 AD 36 23 AF .{;(.. .osíð.6#¯APP:INFO:
Wow, Can you please explain what was actually wrong?
Also, is it maybe possible to see the debug messages inside the uVision IDE? There is a window for it but it's always empty.
dragilla said:It works now.
Great!
dragilla said:Wow, Can you please explain what was actually wrong?
Could have been some bootloader or other code on the device that stopped your app from running.
dragilla said:is it maybe possible to see the debug messages inside the uVision IDE? There is a window for it but it's always empty.
I have not used that before, I think it requires Trace, and that is not supported by the nRF51.(might require a debugger with ETM support as well).
