Custom PCB nRF9160 Link monitor ports
Hi, We have a custom design using an nRF9160.
We can connect and program the device using a jLink though the debug port.
How can we connect the LTE link monitor to the board to transfer AT commands?
Currently our PCB only has access to P0.18 and P0.19 for debug (this can be modified in the next PCB revision).
Can these be re-programmed or are they part of the soft device?
Thanks
  • Hi Håkon,
    For now I'm assuming there is something funny going on with the LTE Link monitor and we can deal with this seperatly.
    All we need to do is get the unit in for test on Friday morning.
    For this I don't need to upload certs etc. I only need to start it up AT+CFUN=1.
    So I have moved over to our hardware and modified the TX/RX ports to 18 and 19.
    When the boards start up all I get is this (below) and there is no response to my AT commands.
    *** Booting Zephyr OS build v2.4.99-ncs1 ***
    The AT host sample started
    I think these just printk debug outputs and we're not connected to the AT command interface?
    Is UART 0 the correct port?
    Maybe my setup is incorrect?
    Are there conflicting ports?
    Project is attached...
    Any ideas please.
    P.S. Can you please give this your top priority as this goes into testing Friday morning.
    Thanks Ianat_client.zip
  • Looking at other cases there seemed to be need to set the appropriate overlay in the SPM (secure boot) project.
    I also tried that and it did not solve things, files attached.
    I also tried a second PCB it has the same error and I have scoped the signal to the nRF9160 so I think hardware is not the issue.
    Ian
    nrf9160dk_nrf9160.overlay
  • Hi Ian,
    As the other terminal options work as expected, I think you have all the hardware and firmware related setup correct, and this looks like an issue with LTE Link monitor wrt. this specific USB-UART adapter.
    If you have scoped the pins, tested other terminals and all looks to be working at that point; everything points to an issue on our PC software, which I must apologize for.
    Is it a possibility to use another terminal than LTE Link monitor for tomorrows purpose?
    Håkon
  • Hi Hakon,
    I think your getting a bit confused by the issues, just to clarify...
    I am using our custom PCB with the at_client application installed.
    The application starts and outputs:
    I am using another terminal, not LTE link monitor and AT commands are getting to the nRF
    The problem is the nRF is not responding to AT commands.
    I have modified: nrf9160_nrf9160ns.overlay, CMakeLists.txt, spm.conf and nrf9160_nrf9160.overlay in /nrf/samples/spm
    Please see attached, also attached is our project.
    Thanks
    Ian
    at_client (2).zip
    0066.nrf9160dk_nrf9160.overlay
    # Copyright (c) 2018 Nordic Semiconductor
    cmake_minimum_required(VERSION 3.13.1)
    if (EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/spm.conf")
      set(spm_CONF_FILE
        prj.conf
        ${CMAKE_CURRENT_LIST_DIR}/spm.conf
    endif()
    if (EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/mcuboot.conf")
      set(mcuboot_CONF_FILE
        prj.conf
        ${CMAKE_CURRENT_LIST_DIR}/mcuboot.conf
    endif()
    if (EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/${BOARD}.overlay")
      set(mcuboot_DTC_OVERLAY_FILE "${CMAKE_CURRENT_SOURCE_DIR}/${BOARD}.overlay")
      set(spm_DTC_OVERLAY_FILE "${CMAKE_CURRENT_SOURCE_DIR}/${BOARD}.overlay")
    endif()
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(NONE)
    # NORDIC SDK APP START
    target_sources(app PRIVATE src/main.c)
    # NORDIC SDK APP END
    spm.conf7652.nrf9160dk_nrf9160ns.overlay
  • Hi Ian,
    My apologies for misunderstanding.
    I tested at_client (2).zip, with the merged.hex located in the build-folder (ie. the same .hex as you're currently using).
    I can confirm that I am able to get an output on P0.19 (TXD seen from nRF) and I am also able to send AT commands via a terminal on GPIO P0.18 (RXD, seen from nRF)
    I tested this by manually connecting P0.19/P0.18 to the nRF9160-DKs SEGGER ICs host UART pins.
    Here's my output from when issuing "AT+CLAC" to list all available AT commands (no echo in the terminal):
    AT+CFUN
    AT+COPS
    AT%COPS
    AT+CGDCONT
    AT+CGACT
    AT+CEMODE
    AT+CGATT
    AT+CGEQOSRDP
    AT+CPINR
    AT+CPIN
    AT+CPSMS
    AT+CEDRXS
    AT%XPTW
    AT+CEDRXRDP
    AT+CEREG
    AT%XNEWCID
    AT%XGETPDNID
    AT+CLAC
    AT+CMEE
    AT+CGMI
    AT+CGMM
    AT+CGMR
    AT+CGSN
    AT+CIMI
    AT+CSCON
    AT+CMGS
    AT+CNMA
    AT+CNMI
    AT+CMGF
    AT+CPMS
    AT+CGSMS
    AT%XSMMA
    AT%CMNG
    AT+CNEC
    AT+CGEREP
    AT%CESQ
    AT%XPCO
    AT+CESQ
    AT%XSIM
    AT%XBANDLOCK
    AT+CGPIAF
    AT+CPAS
    AT+COPN
    AT+CSQ
    AT+CEER
    AT+CNUM
    AT+CRSM
    AT+CIND
    AT+CLCK
    AT+CPWD
    AT%XCBAND
    AT+CGPADDR
    AT+CGCONTRDP
    AT%NBRGRSRP
    AT+CSIM
    AT%XOPNAME
    AT%XTIME
    AT%XRAI
    AT%XCONNSTAT
    AT+CEPPI
    AT%XDATAPRFL
    AT%XMAGPIO
    AT%XANTDETMAGPIO
    AT%XMIPIRFFEDEV
    AT%XMIPIRFFECTRL
    AT%XCOEX0
    AT%XANTCFG
    AT%XEMPR
    AT%XSUDO
    AT%XPMNG
    AT%XRFTEST
    AT%XAPNCLASS
    AT%XTEMPHIGHLVL
    AT%XTEMP
    AT%XPRODDONE
    AT%XMODEMTRACE
    AT%XEPCO
    AT%XVBATLOWLVL
    AT%XVBATLVL
    AT%XVBAT
    AT+CCLK
    AT%CCLK
    AT%XIPV6FAIL
    AT%XUSIMLCK
    AT%XOPERID
    AT%XSMSFALLBACK
    AT%XSYSTEMMODE
    AT%XSNRSQ
    AT+CGAUTH
    AT%XMONITOR
    AT%SHORTSWVER
    AT%HWVERSION
    AT%XMODEMUUID
    AT%XICCID
    AT+ODISNTF
    AT+ODIS
    AT%ODIS
    AT%XNETTIME
    AT%XDEEPSEARCH
    AT%XFILEWRITE
    AT+CEINFO
    AT%XPDNCFG
    AT+CSODCP
    AT%XDATASTOP
    AT%XAPNSTATUS
    AT%XPOFWARN
    OK
    The firmware itself seems to run as-expected wrt. using UART with P0.18 and P0.19.
    What is the VDD_GPIO level on your custom board? Could it be that there is a mismatch between the voltage levels on your USB/UART and the nRF?
    Håkon
