Device restarting for no obvious reason
When I connect my device to an external power supply, it restarts randomly. It sometimes happens once every minute, sometimes once every 10 minutes. I couldn't find a pattern.
Is there a way to figure out the reason somewhere in the software? I'm almost sure this is not a 100% HW issue, I changed a lot of things today in the SW only, and yesterday the device was not restarting :( However, when I just power it from the USB it does not restart.
Please, give me some advice. I will try to change the power supply but for now I only have one.
Thanks
  • You need to increase the SWI interrupt priority, as this is the one handling the operation queue:
    #define SWI_IRQ_PRI             APP_IRQ_PRIORITY_LOWEST                        /**< Priority of the SWI  interrupt (used for updating the timer list). */
    RTC1 should probably run at the same priority as SWI if you change this.
    Note that app_timer uses its own internal driver for RTC1, it does not use the RTC driver in the SDK, which is enabled by RTC1_ENABLED.
