after migrating functional project to latest ncs version v1.5.0 I managed to build and flash it to nrf52840 board without problems. However if I enable MCUboot option with
CONFIG_BOOTLOADER_MCUBOOT=y
the build fails with the following error:
Including boilerplate (Zephyr base): C:/Users/Eva/ncs/v1.5.0/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/Users/Eva/Desktop/testf
-- Using NCS Toolchain 1.5.0 for building. (C:/Users/Eva/ncs/v1.5.0/toolchain/cmake)
-- Zephyr version: 2.4.99 (C:/Users/Eva/ncs/v1.5.0/zephyr)
-- Found Python3: C:/Users/Eva/ncs/v1.5.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
-- Board: elephantedge_nrf52840
-- Cache files will be written to: C:/Users/Eva/ncs/v1.5.0/zephyr/.cache
-- Found dtc: C:/Users/Eva/ncs/v1.5.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/Users/Eva/ncs/v1.5.0/toolchain/opt)
-- Found BOARD.dts: C:/Users/Eva/Desktop/testf/boards/arm/elephantedge_nrf52840/elephantedge_nrf52840.dts
warning: 'has-be32k' is marked as deprecated in 'properties:' in C:/Users/Eva/ncs/v1.5.0/zephyr/dts/bindings\mtd\jedec,spi-nor.yaml for node /soc/spi@40023000/is25lq040b@0.
-- Generated zephyr.dts: C:/Users/Eva/Desktop/testf/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Eva/Desktop/testf/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Eva/Desktop/testf/build/zephyr/include/generated/device_extern.h
warning: SERIAL (defined at soc/arm/nxp_lpc/lpc55xxx\Kconfig.defconfig.lpc55S69_cpu1:22,
drivers/serial/Kconfig:6) was assigned the value 'n' but got the value 'y'. See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_SERIAL.html and/or look up SERIAL in
the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
warning: BT_CTLR_ADVANCED_FEATURES (defined at subsys/bluetooth/controller/Kconfig.ll_sw_split:106)
was assigned the value 'y' but got the value 'n'. Check these unsatisfied dependencies:
BT_LL_SW_SPLIT (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_CTLR_ADVANCED_FEATURES.html and/or
look up BT_CTLR_ADVANCED_FEATURES in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
warning: LOG_IParsing C:/Users/Eva/Desktop/testf/Kconfig
Loaded configuration 'C:/Users/Eva/Desktop/testf/boards/arm/elephantedge_nrf52840/elephantedge_nrf52840_defconfig'
Merged configuration 'C:/Users/Eva/Desktop/testf/prj.conf'
Configuration saved to 'C:/Users/Eva/Desktop/testf/build/zephyr/.config'
Kconfig header saved to 'C:/Users/Eva/Desktop/testf/build/zephyr/include/generated/autoconf.h'
MMEDIATE (defined at subsys/logging/Kconfig:120) was assigned the value 'y' but got
the value 'n'. Check these unsatisfied dependencies: (!LOG_MINIMAL) (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LOG_IMMEDIATE.html and/or look up
LOG_IMMEDIATE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/Users/Eva/ncs/v1.5.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
=== child image mcuboot - begin ===
-- Application: C:/Users/Eva/ncs/v1.5.0/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: C:/Users/Eva/Desktop/testf/mcuboot.overlay
-- Found devicetree overlay: C:/Users/Eva/ncs/v1.5.0/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: C:/Users/Eva/Desktop/testf/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Eva/Desktop/testf/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Eva/Desktop/testf/build/mcuboot/zephyr/include/generated/device_extern.h
warning: FLASH_JESD216_API (defined at drivers/flash/Kconfig:26) was assigned the value 'y' but got
the value 'n'. Check these unsatisfied dependencies: FLASH_JESD216 (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_FLASH_JESD216_API.html and/or look up
FLASH_JESD216_API in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
warning: SPI_NOR (defined at drivers/flash/Kconfig.nor:4) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: SPI (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_SPI_NOR.html and/or look up SPI_NOR in
warning: SPI_NOR_IDLE_IN_DPD (defined at drivers/flash/Kconfig.nor:64) wasParsing C:/Users/Eva/ncs/v1.5.0/bootloader/mcuboot/boot/zephyr/Kconfig
but got the value 'n'. Check these unsatisfied dependencies: SPI_NOR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_SPI_NOR_IDLE_IN_DPD.html and/or look
up SPI_NOR_IDLE_IN_DPD in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: LIS2DH (defined at drivers/sensor/lis2dh/Kconfig:6) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: (I2C || SPI) (=n), SENSOR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LIS2DH.html and/or look up LIS2DH in
Merged configuration 'C:/Users/Eva/ncs/v1.5.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/Users/Eva/ncs/v1.5.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Configuration saved to 'C:/Users/Eva/Desktop/testf/build/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/Users/Eva/Desktop/testf/build/mcuboot/zephyr/include/generated/autoconf.h'
warning: LIS2DW12 (defined at drivers/sensor/lis2dw12/Kconfig:6) was assigned the value 'y' but got
the value 'n'. Check these unsatisfied dependencies: (I2C || SPI) (=n), SENSOR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LIS2DW12.html and/or look up LIS2DW12
in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
warning: LIS2DW12_POWER_MODE (defined at drivers/sensor/lis2dw12/Kconfig:215) was assigned the value
'3' but got the value ''. Check these unsatisfied dependencies: LIS2DW12 (=n), SENSOR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LIS2DW12_POWER_MODE.html and/or look
up LIS2DW12_POWER_MODE in the menuconfig/guiconfig interface. The Application Development Primer,
helpful too.
warning: LIS2MDL (defined at drivers/sensor/lis2mdl/Kconfig:4) was assigned the value 'y' but got
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LIS2MDL.html and/or look up LIS2MDL in
warning: LSM6DSL (defined at drivers/sensor/lsm6dsl/Kconfig:7) was assigned the value 'y' but got
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LSM6DSL.html and/or look up LSM6DSL in
warning: The choice symbol LIS2DW12_ACCEL_RANGE_8G (defined at drivers/sensor/lis2dw12/Kconfig:172)
was selected (set =y), but no symbol ended up as the choice selection. See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LIS2DW12_ACCEL_RANGE_8G.html and/or
look up LIS2DW12_ACCEL_RANGE_8G in the menuconfig/guiconfig interface. The Application Development
warning: The choice symbol LIS2MDL_TRIGGER_NONE (defined at drivers/sensor/lis2mdl/Kconfig:20) was
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LIS2MDL_TRIGGER_NONE.html and/or look
up LIS2MDL_TRIGGER_NONE in the menuconfig/guiconfig interface. The Application Development Primer,
helpful too.
CMake Warning at C:/Users/Eva/ncs/v1.5.0/nrf/lib/flash_patch/CMakeLists.txt:9 (message):
--- WARNING: To maintain the integrity of secure boot, ---
--- enable CONFIG_DISABLE_FLASH_PATCH in production. ---
CMake Warning at C:/Users/Eva/ncs/v1.5.0/zephyr/kernel/CMakeLists.txt:59 (message):
Single threaded mode (CONFIG_MULTITHREADING=n) is deprecated
MCUBoot bootloader key file: C:/Users/Eva/ncs/v1.5.0/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Eva/Desktop/testf/build/mcuboot
=== child image mcuboot - end ===
CMake Error at C:/Program Files/CMake/share/cmake-3.17/Modules/ExternalProject.cmake:3012 (configure_file):
configure_file Problem configuring file
C:/Program Files/CMake/share/cmake-3.17/Modules/ExternalProject.cmake:3270 (_ep_add_configure_command)
C:/Users/Eva/ncs/v1.5.0/nrf/cmake/multi_image.cmake:308 (ExternalProject_Add)
C:/Users/Eva/ncs/v1.5.0/nrf/cmake/multi_image.cmake:84 (add_child_image_from_source)
C:/Users/Eva/ncs/v1.5.0/nrf/modules/mcuboot/CMakeLists.txt:112 (add_child_image)
CMake Warning at C:/Users/Eva/ncs/v1.5.0/nrf/modules/mcuboot/CMakeLists.txt:151 (message):
--- WARNING: Using default MCUBoot key, it should not ---
--- be used for production. ---
CMake Warning at C:/Users/Eva/ncs/v1.5.0/zephyr/CMakeLists.txt:1357 (message):
See also "C:/Users/Eva/Desktop/testf/build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/Eva/Desktop/testf/build/CMakeFiles/CMakeError.log".
FATAL ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' '-DWEST_PYTHON=c:\python38\python.exe' '-BC:\Users\Eva\Desktop\testf\build' '-SC:\Users\Eva\Desktop\testf' -GNinja -DBOARD=elephantedge_nrf52840
Let me know if you have an idea what could cause that behaviour.
Best, Eva
