How to generate firmware's hash.
Hello Everyone,
I am a beginner
I am working on a project which requires authentication of the firmware , for this purpose i want to generate the hash of the firmware .
So while searching i cam across this function--> nrf_crypto_hash_calculate()  which uses source address and length, can anyone help me were i can find my firmware start and size of it,
nrf_crypto_hash_calculate(&hash_context,
&g_nrf_crypto_hash_sha256_info,
(uint8_t*)src_addr,
data_len,
m_fw_hash,
&hash_len);
  •  size_t hash_len = NRF_CRYPTO_HASH_SIZE_SHA256;
            nrf_crypto_hash_context_t hash_context = {0};
           // uint32_t src_addr = CODE_START, data_len = CODE_SIZE;
            crypto_init();
            ret_code_t err_code;
            err_code = nrf_crypto_hash_calculate(&hash_context,
                             (uint8_t*)challenge_no,
                             32,
                             temp1,
                             &hash_len);
            sha256_Raw(&challenge_no,32,temp2);
    I tried to check if nrf_crypto_hash work or not for that i passed random no to it and also to sha256_Raw .     After running both temp1 and temp2 value is equal , so don't think there's a issue in the initialization or working of it
        Thanks and Regard,
    Andhakanoon
  • Are you checking all error return codes from the functions?
    andhakanoon said:
    but its going into SaSi_HalWaitInterrupt after nrf_crypto_hash_update and not coming back
    Does it enter SaSi_HalWaitInterrupt inside or after nrf_crypto_hash_update? This function is inside the CC310 library, so I'm not sure where that is called from. I cannot see any calls to it in our SDK (v17.0.2).
  • Does it enter SaSi_HalWaitInterrupt inside or after nrf_crypto_hash_update?
     its enters Sasi_HalWaitInterrupt insed nrf_crypto_hash_update , also nrf_crypto_hash_calculate works properly if data_len is less , but when i try to give large length it goes into Sasi_HalWaitInterrupt , Also i tried another hash_calculate function from another library and it is working , So is there anyway to crosscheck the hash generated .
    thank you for helping and replying to my queries , very much appreciated
  • Looks like the CC310 does not support hashing directly from Flash, so you need to copy pieces of the FW to RAM before hashing.
    I was able to correctly calculate the SHA256 Hash using the following code in the nrf_crypto_hash example:
    // Initialize the hash context
    err_code = nrf_crypto_hash_init(&hash_context, &g_nrf_crypto_hash_sha256_info);
    // Run the update function (this can be run multiples of time if the data is accessible
    // in smaller chunks, e.g. when received on-air.
    uint32_t fw_start_addr = CODE_START;
    uint32_t fw_size = CODE_SIZE;
    uint32_t fw_piece_size = 0x1000;
    static uint8_t fw_piece[0x1000];
    NRF_LOG_INFO("FW Start address: %x", fw_start_addr);
    NRF_LOG_INFO("FW size: %x", fw_size);
    NRF_LOG_INFO("Hash piece size: %x", fw_piece_size);
    for(int fw_hash_start_addr = fw_start_addr; fw_hash_start_addr < (fw_start_addr + fw_size); fw_hash_start_addr+=fw_piece_size)
        if((fw_hash_start_addr + fw_piece_size) > (fw_start_addr + fw_size))
            fw_piece_size = fw_size - fw_hash_start_addr;
        memcpy(fw_piece, (uint8_t *)(fw_start_addr+fw_hash_start_addr), fw_piece_size);
        err_code = nrf_crypto_hash_update(&hash_context, fw_piece, fw_piece_size);
        NRF_LOG_INFO("Current last hashed address: %x", fw_hash_start_addr + fw_piece_size);
    // Run the finalize when all data has been fed to the update function.
    // this gives you the result
    err_code = nrf_crypto_hash_finalize(&hash_context, m_digest, &digest_len);
    Note that I have not tested this with a lot of FW sizes or start addresses, so there may be some edge-cases that are not handled.
  • Thank you for your help and co-ordination and also sharing your code with few modification that worked for me.
    void fw_hash_calculate(uint8_t * m_digest){
        ret_code_t err_code = nrf_crypto_hash_init(&hash_context, &g_nrf_crypto_hash_sha256_info);
        uint32_t fw_piece_size = 32;
        uint32_t end = CODE_END;
        static uint8_t fw_piece[32];
        printf("FW Start address: %x\n", fw_start_addr);
        printf("FW size: %x\n", fw_size);
        printf("FW end: %x\n", end);
        printf("Hash piece size: %x\n", fw_piece_size);
                fw_piece_size = fw_start_addr + fw_size - fw_hash_start_addr;
            memcpy(fw_piece, (uint8_t *)(fw_hash_start_addr), fw_piece_size);
            printf("Current last hashed address: %x\n", fw_hash_start_addr + fw_piece_size);
        err_code = nrf_crypto_hash_finalize(&hash_context, m_digest, &hash_len);
