NFC initialization fails with voltage measure error.
I'm using the NFC 52840DK. When I try to run any of the NFC examples, I get the following error:
*** Booting Zephyr OS build v2.4.0-ncs2  ***
NFC TNEP Poller sample started.
[00:00:02.374,786] [1;31m st25r3911b: Voltage measure failed[0m
[00:00:02.374,816] [1;31m st25r3911b: st25r3911b initialization failed[0m
NFCA initialization failed err: -6.
It gives this error wether the NFC antenna (supplied with the DK) is connected or not. I tried both directions of the antenna, but that does not make a difference. The antenna itself is pushed all the way into the connector. When the NFC antenna is connected, it looks the same as the images I can find online.
Are there any measurements I can do to rule out a hardware issue?
    The same issue even I am also facing for the last 15 days, in the logic analyzer i didn't see any clock cycles simply its low, and in st25's expansion dev kit there is no pinout for spi .
    we need to take pinouts from the register which are connected to the spi pins of the st25 chip.
    and i have doubt here for nrf52840 dev kit device tree spi0 is not possible to use please confirm this.
    can you help me to resolve this issue?
    Thank You.
