BLE OTS object transfer service throughput
hello
I'm currently developing a system that requires a nrf5280 to transfer data to an android phone through ble.
I've based my application on the Object transfer service example in NRF5 sdk ,which is working well when transfering 912 bytes every 500ms.
I now need to double this data rate somehow
Ive attempted increasing the SDU size to 1824 in order to send data in bigger chunks but this caused the nrf52840 to crash.
Ive also attempted to send 912 bytes every 250ms instead, which kinda worked however in about 20% of the transfers the data was not ready to be read from the l2cap channel after the read OP code was sent. This lead to data being skipped.
is it possible to icrease the SDU size beyond the standard 1024 bytes?
does anyone have much experiece getting high throughput using an nrf52840? Am I missing a trick here?
Thanks
  • hello,
    no I sadly couldn't find one so I had to make an andoid application in andoid studio.
    To read from a perpheral nrf device running OTS you need to connect to GATT then setup an l2cap channel using
    BluetoothSocket.createL2capChannel (int psm) with a psm of 25
    then send an OP code to the devices OACP characteristic using indication to request data to be sent over l2cap.
    finally read from the l2cap channel and repeat.
    one issue with this is that BluetoothSocket.createL2capChannel (int psm) is only available in android 10 or newer.
    that's why ive switched to something based on nordic uart service instead.
