How to access the TIMER3 in wireless timer sync?
I found this great blog entry about synchronizing timers on different devices: https://devzone.nordicsemi.com/nordic/short-range-guides/b/bluetooth-low-energy/posts/wireless-timer-synchronization-among-nrf5-devices
It works just fine on a nRF52840DK and a nRF52DK. Timers on multiple nRF5 devices are synced by one device (master) sending sync packets containing captured timer values to other devices (nodes). (TIMER3 is free running, TIMER2 counts TIMER3 overflows).
At the moment I am struggeling to access this synchronized TIMER3 on the two boards. I am familiar with setting up a TIMER without wireless timer sync.
So here are my questions:
1. How can I define CC, Prescaler, Mode, Bitmode, the interrupt handler and so forth when using wireless timer sync?
2. Can anybody provide me some advice how to access this synchronized TIMER3 properly?
Thank you very much in advance.
  • Hi again,
    I still see a corner case with this one.. rethinking the approach a bit now.
    Specifically I see corner cases around the time the timer wraps around (every 2.5 ms), or when the counter is cleared as part of the adjustment procedure on the receiver. The timer can just be sampled again when the corner case is adjusted and the new value captured, since this runs at 16 MHz and has no significant delay. One cannot wait for the counter in the same way, as this would incur a 2.5 ms delay. After some unsuccessful approaches to detect the counter corner case I'm trying to avoid clearing the counter altogether and keeping track of a diff instead of the transmitter counter total value. Will need to do some further testing to ensure no new issues have been introduced here.
    Audun
  • Hi
    I've been following this case lately since I've been experiencing similar issues as Michael01101 after upgrading my project to the new TimeSync version. This case has been very helpful so far, thanks!
    I'm looking forward to a solution.
    Jona
  • Hi Audun,
    sorry for my late reply. I was out of office for two days.
    Thank you for the two approaches of the timers_capture() function you sent and the effort you already put into this. Unfortunately, it looks like the problem is not solved at the moment, as you said.
    Hopefully we can still find a solution for this problem.
    I really appreciate your help. Thank you very much in advance.
    I am looking forward to hearing from you.
    Michael
  • Hi Michael,
    no worries, I'd very much like to get this fixed and update the repo accordingly.
    I've not been to the office yet to fully test my most recent code change. I have a simple setup with a logic analyzer right now that has been working fine for preliminary testing, but I'm not fully confident in the code yet. I'm attaching the most recent changes if you want to also do some testing on your end.
    Audun
    diff --git a/nRF5_SDK_16.0.0_98a08e2/examples/common/time_sync.c b/nRF5_SDK_16.0.0_98a08e2/examples/common/time_sync.c
    index b9e5477..2b9bfcd 100644
    --- a/nRF5_SDK_16.0.0_98a08e2/examples/common/time_sync.c
    +++ b/nRF5_SDK_16.0.0_98a08e2/examples/common/time_sync.c
    @@ -156,7 +156,7 @@ static nrf_atomic_flag_t m_invalid_tx_timing = false;
     static bool m_synchronized = false;
    -static nrf_atomic_u32_t  m_master_counter = 0;
    +static volatile int32_t  m_master_counter_diff = 0;
     static nrf_atomic_u32_t  m_rcv_count      = 0;
     static nrf_atomic_u32_t  mp_curr_adj_pkt;
    @@ -645,7 +645,7 @@ static void sync_timer_start(void)
         if (m_params.high_freq_timer[0] == NRF_TIMER3 || m_params.high_freq_timer[0] == NRF_TIMER4)
             // TIMERS 0,1, and 2 only have 4 compare registers
    -        m_params.high_freq_timer[0]->CC[4]   = TIME_SYNC_TIMER_MAX_VAL / 2; // Only used for debugging purposes such as pin toggling
    +        m_params.high_freq_timer[0]->CC[5]   = TIME_SYNC_TIMER_MAX_VAL / 2; // Only used for debugging purposes such as pin toggling
         m_params.high_freq_timer[0]->SHORTS      = TIMER_SHORTS_COMPARE0_CLEAR_Msk;
    @@ -694,10 +694,9 @@ uint32_t ts_set_trigger(uint32_t target_tick, uint32_t ppi_endpoint)
         m_trigger_evt.params.triggered.used_packet_count = 0;
         // TODO: is there a way to check if the target value is plausible?
    -    m_trigger_evt.params.triggered.tick_start = ts_timestamp_get_ticks_u64() / TIME_SYNC_TIMER_MAX_VAL;
    +    // m_trigger_evt.params.triggered.tick_start = ts_timestamp_get_ticks_u64() / TIME_SYNC_TIMER_MAX_VAL;
    -    // set capture to new target: (target - local_counter) + (local_counter - m_master_counter)
    -    m_params.high_freq_timer[1]->CC[4] = target_tick - m_master_counter;
    +    m_params.high_freq_timer[1]->CC[4] = target_tick - m_master_counter_diff;
         m_trigger_evt.params.triggered.tick_target = target_tick;
         nrf_ppi_channel_enable(m_params.ppi_chns[4]); // activate trigger
         return NRF_SUCCESS;
    @@ -707,16 +706,17 @@ void SWI3_EGU3_IRQHandler(void)
         if (NRF_EGU3->EVENTS_TRIGGERED[0] != 0)
    -        NRF_EGU3->EVENTS_TRIGGERED[0] = 0;
    -        nrf_atomic_u32_fetch_store(&m_master_counter, ((sync_pkt_t *) mp_curr_adj_pkt)->counter_val);
    -        m_params.high_freq_timer[1]->CC[4] = m_trigger_evt.params.triggered.tick_target - m_master_counter;	// calculate new capture
    +        m_master_counter_diff = ((sync_pkt_t *) mp_curr_adj_pkt)->counter_val - m_params.high_freq_timer[1]->CC[1];
    +        m_params.high_freq_timer[1]->CC[4] = m_trigger_evt.params.triggered.tick_target - m_master_counter_diff;	// calculate new capture
             m_trigger_evt.params.triggered.used_packet_count++;
    -        m_trigger_evt.params.triggered.last_sync = m_master_counter;
    +        m_trigger_evt.params.triggered.last_sync = m_params.high_freq_timer[1]->CC[1] - m_master_counter_diff;
             nrf_atomic_flag_clear(&m_timer_update_in_progress);
    +        NRF_EGU3->EVENTS_TRIGGERED[0] = 0;
             if (!m_synchronized)
                 m_synchronized = true;
    @@ -836,11 +836,6 @@ static inline bool sync_timer_offset_compensate(sync_pkt_t * p_pkt)
             m_params.high_freq_timer[0]->CC[2] = (TIME_SYNC_TIMER_MAX_VAL - timer_offset);
    -     * This is necessary, because the following timer reset will not be counted as step
    -    p_pkt->counter_val++;
         // resetting the timer to the trigger target will skip the trigger -> avoid this
         if (p_pkt->counter_val == m_trigger_evt.params.triggered.tick_target)
    @@ -869,7 +864,7 @@ static void ppi_sync_timer_adjust_configure(void)
         NRF_PPI->CHENCLR        = (1 << chn0);
         NRF_PPI->CH[chn0].EEP   = (uint32_t) &m_params.high_freq_timer[0]->EVENTS_COMPARE[2];
         NRF_PPI->CH[chn0].TEP   = (uint32_t) &m_params.high_freq_timer[0]->TASKS_CLEAR;
    -    NRF_PPI->FORK[chn0].TEP = (uint32_t) &m_params.high_freq_timer[1]->TASKS_CLEAR;
    +    NRF_PPI->FORK[chn0].TEP = 0;//(uint32_t) &m_params.high_freq_timer[1]->TASKS_CLEAR;
         // PPI channel 1: disable PPI channel 0 such that the timer is only reset once, and trigger software interrupt
         NRF_PPI->CHENCLR        = (1 << chn1);
    @@ -889,7 +884,7 @@ static void ppi_radio_rx_configure(void)
         NRF_PPI->CH[chn].EEP   = (uint32_t) &NRF_RADIO->EVENTS_ADDRESS;
         NRF_PPI->CH[chn].TEP   = (uint32_t) &m_params.high_freq_timer[0]->TASKS_CAPTURE[1];
    -    NRF_PPI->FORK[chn].TEP = 0;
    +    NRF_PPI->FORK[chn].TEP = (uint32_t) &m_params.high_freq_timer[1]->TASKS_CAPTURE[1];
         NRF_PPI->CHENSET       = (1 << chn);
    @@ -966,12 +961,11 @@ uint32_t ppi_sync_trigger_configure(uint32_t ppi_endpoint)
         return nrfx_ppi_channel_fork_assign(m_params.ppi_chns[4], (uint32_t) &m_params.egu->TASKS_TRIGGER[2]);
    -static void timers_capture(uint32_t * p_sync_timer_val, uint32_t * p_count_timer_val, uint32_t * p_peer_counter)
    +static void timers_capture(uint32_t * p_sync_timer_val, uint32_t * p_count_timer_val, int32_t * p_peer_counter)
         static nrf_atomic_flag_t m_timestamp_capture_flag = 0;
    -    uint32_t peer_counter;
    -    bool     timeslot_active;
    +    volatile int32_t peer_counter_diff;
         if (nrf_atomic_flag_set_fetch(&m_timestamp_capture_flag) != 0)
    @@ -981,48 +975,45 @@ static void timers_capture(uint32_t * p_sync_timer_val, uint32_t * p_count_timer
         nrf_ppi_channel_t ppi_chn;
         nrfx_err_t ret = nrfx_ppi_channel_alloc(&ppi_chn);
    -    ASSERT(ret == NRFX_SUCCESS);
    +    APP_ERROR_CHECK_BOOL(ret == NRFX_SUCCESS);
         ppi_counter_timer_capture_configure(ppi_chn);
    -    // Use loop in case radio state changes from inactive to active during value copy
    -    // Value copy needs to be atomic to get accurate timestamp
    +    NVIC_DisableIRQ(m_params.egu_irq_type);
    +    bool counter_adjustment_triggered;
    +    // Loop if adjustment procedure happened close to timer capture
         do
    -        if (m_radio_state == RADIO_STATE_IDLE)
    -            timeslot_active = false;
    -        else
    +        counter_adjustment_triggered = m_params.egu->EVENTS_TRIGGERED[0];
    +        m_params.egu->EVENTS_TRIGGERED[1] = 0;
    +        m_params.egu->TASKS_TRIGGER[1] = 1;
    +        while (m_params.egu->EVENTS_TRIGGERED[1] == 0)
    -            timeslot_active =  true;
    +            __NOP();
    -        if (timeslot_active)
    +        if (counter_adjustment_triggered)
    -            // Do critical section during timeslot
    -            NVIC_DisableIRQ(RADIO_IRQn);
    -            m_params.egu->TASKS_TRIGGER[1] = 1;
    -            (void) m_params.egu->EVENTS_TRIGGERED[1];
    -            peer_counter = m_master_counter;
    -            NVIC_EnableIRQ(RADIO_IRQn);
    +            peer_counter_diff = ((sync_pkt_t *) mp_curr_adj_pkt)->counter_val - m_params.high_freq_timer[1]->CC[1];
    -            // Critical section not needed outside of timeslot
    +            peer_counter_diff = m_master_counter_diff;
    +    } while (counter_adjustment_triggered != m_params.egu->EVENTS_TRIGGERED[0] ||
    +             m_params.high_freq_timer[0]->CC[3] < 2);
    -    } while (!timeslot_active && (m_radio_state != RADIO_STATE_IDLE));
    +    NVIC_EnableIRQ(m_params.egu_irq_type);
         ppi_counter_timer_capture_disable(ppi_chn);
         nrfx_ppi_channel_free(ppi_chn);
         *p_sync_timer_val  = m_params.high_freq_timer[0]->CC[3];
         *p_count_timer_val = (m_params.high_freq_timer[1]->CC[0]);
    -    *p_peer_counter    = peer_counter;
    +    *p_peer_counter    = peer_counter_diff;
         nrf_atomic_flag_clear(&m_timestamp_capture_flag);
    @@ -1217,7 +1208,7 @@ uint32_t ts_timestamp_get_ticks_u32(void)
         uint32_t sync_timer_val;
         uint32_t count_timer_val;
    -    uint32_t peer_count;
    +    int32_t peer_count;
         timers_capture(&sync_timer_val, &count_timer_val, &peer_count);
    @@ -1229,7 +1220,7 @@ uint64_t ts_timestamp_get_ticks_u64(void)
         uint64_t timestamp;
  • Hello Audun,
    thank you for your reply. That sounds very promising.
    Please let me know when you have validated and verified your code changes.
    Michael
