My configuration on SEGGER Embedded Studio for "Open nRF Connect SDK Project..." is the following:
- nRF Connect SDK Release: 1.5.0
- Projects: serial_lte_modem
- Board Name: nrf9160dk_nrf9160ns
Then, from Project -> Configure nRF Connect SDK Project... -> menuconfig, I load the here attached SLM_custom.config file and then Configure (whit this config file I expect to have all logging disabled).
Finally I build the solution and flash the target.
The issue is that during PSM inactive time, given AT#XSLEEP command, I measure around 60 uA while I'd expect a value at least lower than 10 uA. The only way to see less than 10 uA is sending the AT#XSLEEP=1 command, but this also triggers a de-attach and so it's not PSM anymore. Is there any way to see current consumption lower than 10 uA (declared floor current is 2.7 uA) with serial_lte_modem app? Am I missing something in the build configuration?
Thanks for your support.
# CONFIG_SPI is not set # CONFIG_I2C is not set # CONFIG_KSCAN is not set # CONFIG_WIFI is not set # CONFIG_NET_L2_ETHERNET is not set # CONFIG_MODEM is not set # CONFIG_UART_INTERRUPT_DRIVEN is not set CONFIG_NET_IPV6=y # CONFIG_NET_CONFIG_NEED_IPV6 is not set CONFIG_BOARD="nrf9160dk_nrf9160" CONFIG_FLASH_LOAD_SIZE=0x30000 CONFIG_FLASH_LOAD_OFFSET=0x50000 CONFIG_SOC="nRF9160_SICA" CONFIG_SOC_SERIES="nrf91" CONFIG_NUM_IRQS=65 CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768 # CONFIG_WATCHDOG is not set CONFIG_HEAP_MEM_POOL_SIZE=16384 # CONFIG_UART_NS16550 is not set CONFIG_GPIO=y CONFIG_PM=y # CONFIG_PM_DEEP_SLEEP_STATES is not set CONFIG_HAS_POWER_STATE_DEEP_SLEEP_1=y CONFIG_PM_DEVICE=y CONFIG_SOC_HAS_TIMING_FUNCTIONS=y CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y # CONFIG_CORTEX_M_SYSTICK is not set CONFIG_CLOCK_CONTROL=y CONFIG_NRF_RTC_TIMER=y CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768 CONFIG_BUILD_OUTPUT_HEX=y CONFIG_FPU=y CONFIG_ROM_START_OFFSET=0 CONFIG_FLASH_SIZE=1024 CONFIG_FLASH_BASE_ADDRESS=0x0 # CONFIG_GPIO_MCUX is not set # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set # CONFIG_TINYCRYPT is not set # CONFIG_NET_L2_IEEE802154 is not set CONFIG_SERIAL=y # CONFIG_UART_PL011 is not set # # Modules # # # Available modules. # # # nrf (/home/pgel/ncs/nrf) # # # Nordic nRF Connect # CONFIG_MAIN_STACK_SIZE=4096 CONFIG_PRIVILEGED_STACK_SIZE=1024 # CONFIG_NCS_SAMPLES_DEFAULTS is not set # # Bootloader # # CONFIG_BUILD_S1_VARIANT is not set # CONFIG_SECURE_BOOT is not set CONFIG_PM_PARTITION_SIZE_PROVISION=0x280 # CONFIG_B0_MIN_PARTITION_SIZE is not set CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000 # CONFIG_SECURE_BOOT_CRYPTO is not set # # Secure Boot firmware validation # CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483 CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1 CONFIG_SB_VALIDATION_INFO_VERSION=2 CONFIG_SB_VALIDATION_METADATA_OFFSET=0 CONFIG_SB_VALIDATE_FW_SIGNATURE=y # end of Secure Boot firmware validation # end of Bootloader # # Bluetooth Low Energy # CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 # end of Bluetooth Low Energy # # DFU # # # DFU # CONFIG_DFU_TARGET=y CONFIG_DFU_TARGET_MCUBOOT=y CONFIG_DFU_TARGET_STREAM=y # CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set CONFIG_DFU_TARGET_MODEM_DELTA=y CONFIG_DFU_TARGET_MODEM_TIMEOUT=60 # end of DFU # end of DFU # CONFIG_ESB is not set # # Peripheral CPU DFU (PCD) # # CONFIG_PCD is not set # end of Peripheral CPU DFU (PCD) # # Networking # # # Application protocols # # CONFIG_NRF_CLOUD is not set CONFIG_DOWNLOAD_CLIENT=y CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=2048 CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE=2048 CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_2048=y # CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024 is not set # CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_512 is not set # CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_256 is not set # # Thread and stack buffers # CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096 CONFIG_DOWNLOAD_CLIENT_MAX_HOSTNAME_SIZE=64 CONFIG_DOWNLOAD_CLIENT_MAX_FILENAME_SIZE=192 CONFIG_DOWNLOAD_CLIENT_TCP_SOCK_TIMEO_MS=30000 CONFIG_DOWNLOAD_CLIENT_UDP_SOCK_TIMEO_MS=4000 CONFIG_DOWNLOAD_CLIENT_RANGE_REQUESTS=y # CONFIG_DOWNLOAD_CLIENT_IPV6 is not set CONFIG_FOTA_DOWNLOAD=y CONFIG_FOTA_SOCKET_RETRIES=2 CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y CONFIG_FOTA_DOWNLOAD_MCUBOOT_FLASH_BUF_SZ=512 # CONFIG_AWS_IOT is not set # CONFIG_AWS_JOBS is not set # CONFIG_AZURE_IOT_HUB is not set # CONFIG_CLOUD_API is not set # # Self-Registration (Zi ZHu Ce) # # CONFIG_ZZHC is not set # end of Self-Registration (Zi ZHu Ce) # CONFIG_ICAL_PARSER is not set # CONFIG_FTP_CLIENT is not set # CONFIG_COAP_UTILS is not set # end of Application protocols # end of Networking # # NFC # # CONFIG_NFC_NDEF is not set # CONFIG_NFC_NDEF_PARSER is not set # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set # CONFIG_NFC_T2T_PARSER is not set # CONFIG_NFC_T4T_NDEF_FILE is not set # CONFIG_NFC_T4T_ISODEP is not set # CONFIG_NFC_T4T_APDU is not set # CONFIG_NFC_T4T_CC_FILE is not set # CONFIG_NFC_T4T_HL_PROCEDURE is not set # CONFIG_NFC_PLATFORM is not set # CONFIG_NFC_TNEP_TAG is not set # CONFIG_NFC_TNEP_POLLER is not set # CONFIG_NFC_TNEP_CH is not set # end of NFC # CONFIG_PROFILER is not set # # SPM # CONFIG_SPM=y # CONFIG_SPM_BUILD_STRATEGY_USE_HEX_FILE is not set # CONFIG_SPM_BUILD_STRATEGY_SKIP_BUILD is not set CONFIG_SPM_BUILD_STRATEGY_FROM_SOURCE=y # CONFIG_IS_SPM is not set CONFIG_SPM_SECURE_SERVICES=y CONFIG_SPM_SERVICE_RNG=y CONFIG_SPM_SERVICE_READ=y # CONFIG_SPM_SERVICE_REBOOT is not set CONFIG_SPM_SERVICE_FIND_FIRMWARE_INFO=y CONFIG_SPM_SERVICE_S0_ACTIVE=y # CONFIG_SPM_SERVICE_PREVALIDATE is not set # CONFIG_SPM_SERVICE_BUSY_WAIT is not set CONFIG_ARM_ENTRY_VENEERS_LIB_NAME="spm/libspmsecureentries.a" # end of SPM CONFIG_FW_INFO=y CONFIG_FW_INFO_OFFSET=0x200 CONFIG_FW_INFO_FIRMWARE_VERSION=1 CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea CONFIG_FW_INFO_HARDWARE_ID=91 CONFIG_FW_INFO_VERSION=2 CONFIG_FW_INFO_CRYPTO_ID=0 CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0 CONFIG_FW_INFO_MAGIC_LEN=12 CONFIG_FW_INFO_VALID_VAL=0x9102FFFF CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y # CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set # CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set # CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set # CONFIG_PPI_TRACE is not set # CONFIG_CPU_LOAD is not set # # Nordic MPSL # CONFIG_MPSL_THREAD_COOP_PRIO=8 CONFIG_MPSL_SIGNAL_STACK_SIZE=1024 CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0 # end of Nordic MPSL # # Partition Manager # CONFIG_PARTITION_MANAGER_ENABLED=y CONFIG_SRAM_SIZE=128 CONFIG_SRAM_BASE_ADDRESS=0x20020000 # # Zephyr subsystem configurations # # end of Zephyr subsystem configurations # # Zephyr samples configurations # # end of Zephyr samples configurations # # NCS subsystem configurations # # # NCS samples configurations # # end of NCS samples configurations # CONFIG_PM_SINGLE_IMAGE is not set # CONFIG_PM_EXTERNAL_FLASH is not set # CONFIG_BUILD_WITH_TFM is not set CONFIG_PM_SRAM_BASE=0x20000000 CONFIG_PM_SRAM_SIZE=0x40000 # end of Partition Manager # # nRF RPC (Remote Procedure Call) library # # end of nRF RPC (Remote Procedure Call) library # # Full Modem Firmware Update Management(FMFU) # # end of Full Modem Firmware Update Management(FMFU) CONFIG_SIGN_IMAGES=y CONFIG_TFM_BOARD="/home/pgel/ncs/nrf/modules/tfm/boards/nrf9160" # CONFIG_CDDL_GEN is not set # # Libraries # # CONFIG_AGPS is not set # # Binary libraries # # end of Binary libraries CONFIG_NRF_MODEM_LIB=y CONFIG_NRF_MODEM_LIB_SYS_INIT=y # CONFIG_NRF_MODEM_LIB_TRACE_ENABLED is not set # CONFIG_NRF91_SOCKET_SEND_SPLIT_LARGE_BLOCKS is not set CONFIG_NRF91_SOCKET_BLOCK_LIMIT=2048 CONFIG_NRF_MODEM_LIB_SENDMSG_BUF_SIZE=128 # # Heap and buffers # CONFIG_NRF_MODEM_LIB_HEAP_SIZE=512 CONFIG_NRF_MODEM_LIB_SHMEM_CTRL_SIZE=0x4e8 CONFIG_NRF_MODEM_LIB_SHMEM_TX_SIZE=8192 CONFIG_NRF_MODEM_LIB_SHMEM_RX_SIZE=8192 CONFIG_NRF_MODEM_LIB_SHMEM_TRACE_SIZE=0 # # Diagnostics # # CONFIG_NRF_MODEM_LIB_HEAP_DUMP_PERIODIC is not set # CONFIG_NRF_MODEM_LIB_SHM_TX_DUMP_PERIODIC is not set # end of Diagnostics # # BSD library (deprecated) # # # All the configs below are deprecated, please use NRF_MODEM_LIB equivalents instead # # CONFIG_BSD_LIBRARY is not set # end of BSD library (deprecated) # CONFIG_ADP536X is not set # # AT Command driver # CONFIG_AT_CMD=y CONFIG_AT_CMD_SYS_INIT=y CONFIG_AT_CMD_INIT_PRIORITY=40 CONFIG_AT_CMD_THREAD_PRIO=10 CONFIG_AT_CMD_THREAD_STACK_SIZE=1024 CONFIG_AT_CMD_QUEUE_LEN=16 CONFIG_AT_CMD_RESPONSE_MAX_LEN=2700 # end of AT Command driver CONFIG_LTE_LINK_CONTROL=y # CONFIG_LTE_AUTO_INIT_AND_CONNECT is not set # CONFIG_LTE_LOCK_BANDS is not set # CONFIG_LTE_LOCK_PLMN is not set # CONFIG_LTE_UNLOCK_PLMN is not set CONFIG_LTE_PSM_REQ_RPTAU="00000011" CONFIG_LTE_PSM_REQ_RAT="00100001" # CONFIG_LTE_EDRX_REQ is not set CONFIG_LTE_EDRX_REQ_VALUE="1001" CONFIG_LTE_PTW_VALUE="" # CONFIG_LTE_LEGACY_PCO_MODE is not set # CONFIG_LTE_PDP_CMD is not set # CONFIG_LTE_PDN_AUTH_CMD is not set CONFIG_LTE_NETWORK_MODE_LTE_M=y # CONFIG_LTE_NETWORK_MODE_LTE_M_GPS is not set # CONFIG_LTE_NETWORK_MODE_NBIOT is not set # CONFIG_LTE_NETWORK_MODE_NBIOT_GPS is not set CONFIG_LTE_RAI_REQ_VALUE="0" CONFIG_LTE_NETWORK_USE_FALLBACK=y CONFIG_LTE_NETWORK_TIMEOUT=600 # CONFIG_FPROTECT is not set CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000 CONFIG_FPROTECT_BLOCK_SIZE=0x8000 CONFIG_AT_NOTIF=y CONFIG_AT_NOTIF_SYS_INIT=y # # AT Host Library for nrf91 # # CONFIG_AT_HOST_LIBRARY is not set # end of AT Host Library for nrf91 # CONFIG_DK_LIBRARY is not set CONFIG_AT_CMD_PARSER=y # CONFIG_MODEM_INFO is not set # CONFIG_PDN_MANAGEMENT is not set CONFIG_RESET_ON_FATAL_ERROR=y # CONFIG_SMS is not set # CONFIG_MODEM_KEY_MGMT is not set # CONFIG_SUPL_CLIENT_LIB is not set # CONFIG_DATE_TIME is not set # CONFIG_RAM_POWER_DOWN_LIBRARY is not set # end of Libraries # # Device Drivers # # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set CONFIG_ENTROPY_CC3XX=y # CONFIG_ETH_RTT is not set # CONFIG_SENSOR is not set # # GPS Drivers # # CONFIG_GPS_SIM is not set # CONFIG_NRF9160_GPS is not set # end of GPS Drivers # CONFIG_NRF_SW_LPUART is not set # end of Device Drivers # # External libraries # # CONFIG_CJSON_LIB is not set # end of External libraries # CONFIG_UNITY is not set # end of Nordic nRF Connect CONFIG_ZEPHYR_NRF_MODULE=y # end of nrf (/home/pgel/ncs/nrf) # # mcuboot (/home/pgel/ncs/bootloader/mcuboot) # # # MCUboot # # CONFIG_MCUBOOT_BUILD_STRATEGY_USE_HEX_FILE is not set # CONFIG_MCUBOOT_BUILD_STRATEGY_SKIP_BUILD is not set CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y CONFIG_MCUBOOT_IMAGE_VERSION="0.0.0+0" CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4 CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4 # end of MCUboot CONFIG_ZEPHYR_MCUBOOT_MODULE=y # end of mcuboot (/home/pgel/ncs/bootloader/mcuboot) # # nrfxlib (/home/pgel/ncs/nrfxlib) # # # Nordic nrfxlib # CONFIG_NRF_MODEM=y CONFIG_NRF_MODEM_LINK_BINARY=y CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8 # CONFIG_NFC_T2T_NRFXLIB is not set # CONFIG_NFC_T4T_NRFXLIB is not set # # Crypto libraries for nRF5x SOCs. # # CONFIG_NRF_OBERON is not set # CONFIG_NRF_CC310_BL is not set # end of Crypto libraries for nRF5x SOCs. # # Nordic Security # # CONFIG_NORDIC_SECURITY_BACKEND is not set # end of Nordic Security # CONFIG_NRF_RPC is not set # # ZBOSS library configuration # CONFIG_ZIGBEE_LIBRARY_DEVELOPMENT=y CONFIG_ZIGBEE_LIBRARY_SOC=y # CONFIG_ZIGBEE_LIBRARY_NCP_DEV is not set # CONFIG_ZIGBEE_GP_NONE is not set CONFIG_ZIGBEE_GP_PB=y # CONFIG_ZIGBEE_GP_CB is not set # end of ZBOSS library configuration # end of Nordic nrfxlib CONFIG_ZEPHYR_NRFXLIB_MODULE=y # end of nrfxlib (/home/pgel/ncs/nrfxlib) # # cddl-gen (/home/pgel/ncs/modules/lib/cddl-gen) # CONFIG_ZEPHYR_CDDL_GEN_MODULE=y # end of cddl-gen (/home/pgel/ncs/modules/lib/cddl-gen) # # hal_nordic (/home/pgel/ncs/modules/hal/nordic) # CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y CONFIG_HAS_NRFX=y # # nrfx drivers # CONFIG_NRFX_CLOCK=y CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y CONFIG_NRFX_DPPI=y # CONFIG_NRFX_EGU is not set # CONFIG_NRFX_EGU0 is not set # CONFIG_NRFX_EGU1 is not set # CONFIG_NRFX_EGU2 is not set # CONFIG_NRFX_EGU3 is not set # CONFIG_NRFX_EGU4 is not set # CONFIG_NRFX_EGU5 is not set CONFIG_NRFX_GPIOTE=y # CONFIG_NRFX_I2S is not set CONFIG_NRFX_IPC=y CONFIG_NRFX_NVMC=y # CONFIG_NRFX_PDM is not set # CONFIG_NRFX_POWER is not set # CONFIG_NRFX_PWM is not set # CONFIG_NRFX_PWM0 is not set # CONFIG_NRFX_PWM1 is not set # CONFIG_NRFX_PWM2 is not set # CONFIG_NRFX_PWM3 is not set # CONFIG_NRFX_RTC is not set # CONFIG_NRFX_RTC0 is not set # CONFIG_NRFX_RTC1 is not set # CONFIG_NRFX_SAADC is not set # CONFIG_NRFX_SPIM is not set # CONFIG_NRFX_SPIM0 is not set # CONFIG_NRFX_SPIM1 is not set # CONFIG_NRFX_SPIM2 is not set # CONFIG_NRFX_SPIM3 is not set # CONFIG_NRFX_SPIS is not set # CONFIG_NRFX_SPIS0 is not set # CONFIG_NRFX_SPIS1 is not set # CONFIG_NRFX_SPIS2 is not set # CONFIG_NRFX_SPIS3 is not set # CONFIG_NRFX_SYSTICK is not set CONFIG_NRFX_TIMER=y # CONFIG_NRFX_TIMER0 is not set # CONFIG_NRFX_TIMER1 is not set CONFIG_NRFX_TIMER2=y # CONFIG_NRFX_TWIM is not set # CONFIG_NRFX_TWIM0 is not set # CONFIG_NRFX_TWIM1 is not set # CONFIG_NRFX_TWIM2 is not set # CONFIG_NRFX_TWIM3 is not set # CONFIG_NRFX_TWIS is not set # CONFIG_NRFX_TWIS0 is not set # CONFIG_NRFX_TWIS1 is not set # CONFIG_NRFX_TWIS2 is not set # CONFIG_NRFX_TWIS3 is not set # CONFIG_NRFX_UARTE is not set # CONFIG_NRFX_UARTE0 is not set # CONFIG_NRFX_UARTE1 is not set # CONFIG_NRFX_UARTE2 is not set # CONFIG_NRFX_UARTE3 is not set # CONFIG_NRFX_WDT is not set # CONFIG_NRFX_WDT0 is not set # CONFIG_NRFX_PRS is not set # CONFIG_NRFX_PRS_BOX_0 is not set # CONFIG_NRFX_PRS_BOX_1 is not set # CONFIG_NRFX_PRS_BOX_2 is not set # CONFIG_NRFX_PRS_BOX_3 is not set # CONFIG_NRFX_PRS_BOX_4 is not set # end of nrfx drivers # end of hal_nordic (/home/pgel/ncs/modules/hal/nordic) # # connectedhomeip (/home/pgel/ncs/modules/lib/connectedhomeip) # # CONFIG_CHIP is not set CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y # end of connectedhomeip (/home/pgel/ncs/modules/lib/connectedhomeip) # # Optional modules. Make sure they're installed, via the project manifest. # # CONFIG_CANOPENNODE is not set # CONFIG_CIVETWEB is not set CONFIG_HAS_CMSIS_CORE=y CONFIG_HAS_CMSIS_CORE_M=y # CONFIG_CMSIS_DSP is not set # CONFIG_LIBMETAL is not set # CONFIG_HAS_SEMTECH_LORAMAC is not set # CONFIG_HAS_SEMTECH_SOFT_SE is not set # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set # CONFIG_MBEDTLS is not set # CONFIG_HAS_MEC_HAL is not set # CONFIG_OPENAMP is not set # CONFIG_SOF is not set # CONFIG_MIPI_SYST_LIB is not set CONFIG_NUM_PREEMPT_PRIORITIES=15 # CONFIG_TINYCBOR is not set CONFIG_MCUBOOT_BOOTUTIL_LIB=y CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y # # Unavailable modules, please install those via the project manifest. # # end of Modules # CONFIG_BOARD_NRF9160DK_NRF9160 is not set CONFIG_BOARD_NRF9160DK_NRF9160NS=y # # Board Options # # end of Board Options # CONFIG_SOC_SERIES_BEETLE is not set # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set # CONFIG_SOC_SERIES_MPS2 is not set # CONFIG_SOC_SERIES_MUSCA is not set # CONFIG_SOC_SERIES_MUSCA_B1 is not set # CONFIG_SOC_SERIES_MUSCA_S1 is not set # CONFIG_SOC_SERIES_SAM3X is not set # CONFIG_SOC_SERIES_SAM4E is not set # CONFIG_SOC_SERIES_SAM4L is not set # CONFIG_SOC_SERIES_SAM4S is not set # CONFIG_SOC_SERIES_SAME70 is not set # CONFIG_SOC_SERIES_SAMV71 is not set # CONFIG_SOC_SERIES_SAMD20 is not set # CONFIG_SOC_SERIES_SAMD21 is not set # CONFIG_SOC_SERIES_SAMD51 is not set # CONFIG_SOC_SERIES_SAME51 is not set # CONFIG_SOC_SERIES_SAME53 is not set # CONFIG_SOC_SERIES_SAME54 is not set # CONFIG_SOC_SERIES_SAMR21 is not set # CONFIG_SOC_SERIES_VALKYRIE is not set # CONFIG_SOC_SERIES_VIPER is not set # CONFIG_SOC_SERIES_PSOC62 is not set # CONFIG_SOC_SERIES_PSOC63 is not set # CONFIG_SOC_SERIES_XMC_4XXX is not set # CONFIG_SOC_SERIES_MEC1501X is not set # CONFIG_SOC_SERIES_MEC1701X is not set # CONFIG_SOC_SERIES_NRF51X is not set # CONFIG_SOC_SERIES_NRF52X is not set # CONFIG_SOC_SERIES_NRF53X is not set CONFIG_SOC_SERIES_NRF91X=y # CONFIG_SOC_SERIES_M48X is not set # CONFIG_SOC_SERIES_NPCX7 is not set # CONFIG_SOC_SERIES_IMX_6X_M4 is not set # CONFIG_SOC_SERIES_IMX7_M4 is not set # CONFIG_SOC_SERIES_IMX8MM_M4 is not set # CONFIG_SOC_SERIES_IMX_RT is not set # CONFIG_SOC_SERIES_IMX_RT6XX is not set # CONFIG_SOC_SERIES_KINETIS_K2X is not set # CONFIG_SOC_SERIES_KINETIS_K6X is not set # CONFIG_SOC_SERIES_KINETIS_K8X is not set # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set # CONFIG_SOC_SERIES_KINETIS_KL2X is not set # CONFIG_SOC_SERIES_KINETIS_KV5X is not set # CONFIG_SOC_SERIES_KINETIS_KWX is not set # CONFIG_SOC_SERIES_LPC11U6X is not set # CONFIG_SOC_SERIES_LPC54XXX is not set # CONFIG_SOC_SERIES_LPC55XXX is not set # CONFIG_SOC_QEMU_CORTEX_A53 is not set # CONFIG_SOC_EOS_S3 is not set # CONFIG_SOC_SERIES_EFM32GG11B is not set # CONFIG_SOC_SERIES_EFM32HG is not set # CONFIG_SOC_SERIES_EFM32JG12B is not set # CONFIG_SOC_SERIES_EFM32PG12B is not set # CONFIG_SOC_SERIES_EFM32PG1B is not set # CONFIG_SOC_SERIES_EFM32WG is not set # CONFIG_SOC_SERIES_EFR32BG13P is not set # CONFIG_SOC_SERIES_EFR32FG1P is not set # CONFIG_SOC_SERIES_EFR32MG12P is not set # CONFIG_SOC_SERIES_EFR32MG21 is not set # CONFIG_SOC_SERIES_STM32F0X is not set # CONFIG_SOC_SERIES_STM32F1X is not set # CONFIG_SOC_SERIES_STM32F2X is not set # CONFIG_SOC_SERIES_STM32F3X is not set # CONFIG_SOC_SERIES_STM32F4X is not set # CONFIG_SOC_SERIES_STM32F7X is not set # CONFIG_SOC_SERIES_STM32G0X is not set # CONFIG_SOC_SERIES_STM32G4X is not set # CONFIG_SOC_SERIES_STM32H7X is not set # CONFIG_SOC_SERIES_STM32L0X is not set # CONFIG_SOC_SERIES_STM32L1X is not set # CONFIG_SOC_SERIES_STM32L4X is not set # CONFIG_SOC_SERIES_STM32L5X is not set # CONFIG_SOC_SERIES_STM32MP1X is not set # CONFIG_SOC_SERIES_STM32WBX is not set # CONFIG_SOC_TI_LM3S6965 is not set # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set # CONFIG_SOC_SERIES_CC32XX is not set # CONFIG_SOC_SERIES_MSP432P4XX is not set # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set # # Hardware Configuration # CONFIG_CPU_HAS_ARM_MPU=y CONFIG_CPU_HAS_NRF_IDAU=y CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000 CONFIG_SOC_FAMILY="nordic_nrf" CONFIG_SOC_FAMILY_NRF=y CONFIG_HAS_HW_NRF_CC310=y CONFIG_HAS_HW_NRF_CLOCK=y CONFIG_HAS_HW_NRF_DPPIC=y CONFIG_HAS_HW_NRF_EGU0=y CONFIG_HAS_HW_NRF_EGU1=y CONFIG_HAS_HW_NRF_EGU2=y CONFIG_HAS_HW_NRF_EGU3=y CONFIG_HAS_HW_NRF_EGU4=y CONFIG_HAS_HW_NRF_EGU5=y CONFIG_HAS_HW_NRF_GPIO0=y CONFIG_HAS_HW_NRF_GPIOTE=y CONFIG_HAS_HW_NRF_I2S=y CONFIG_HAS_HW_NRF_IPC=y CONFIG_HAS_HW_NRF_NVMC_PE=y CONFIG_HAS_HW_NRF_PDM=y CONFIG_HAS_HW_NRF_POWER=y CONFIG_HAS_HW_NRF_PWM0=y CONFIG_HAS_HW_NRF_PWM1=y CONFIG_HAS_HW_NRF_PWM2=y CONFIG_HAS_HW_NRF_PWM3=y CONFIG_HAS_HW_NRF_RTC0=y CONFIG_HAS_HW_NRF_RTC1=y CONFIG_HAS_HW_NRF_SAADC=y CONFIG_HAS_HW_NRF_SPIM0=y CONFIG_HAS_HW_NRF_SPIM1=y CONFIG_HAS_HW_NRF_SPIM2=y CONFIG_HAS_HW_NRF_SPIM3=y CONFIG_HAS_HW_NRF_SPIS0=y CONFIG_HAS_HW_NRF_SPIS1=y CONFIG_HAS_HW_NRF_SPIS2=y CONFIG_HAS_HW_NRF_SPIS3=y CONFIG_HAS_HW_NRF_SPU=y CONFIG_HAS_HW_NRF_TIMER0=y CONFIG_HAS_HW_NRF_TIMER1=y CONFIG_HAS_HW_NRF_TIMER2=y CONFIG_HAS_HW_NRF_TWIM0=y CONFIG_HAS_HW_NRF_TWIM1=y CONFIG_HAS_HW_NRF_TWIM2=y CONFIG_HAS_HW_NRF_TWIM3=y CONFIG_HAS_HW_NRF_TWIS0=y CONFIG_HAS_HW_NRF_TWIS1=y CONFIG_HAS_HW_NRF_TWIS2=y CONFIG_HAS_HW_NRF_TWIS3=y CONFIG_HAS_HW_NRF_UARTE0=y CONFIG_HAS_HW_NRF_UARTE1=y CONFIG_HAS_HW_NRF_UARTE2=y CONFIG_HAS_HW_NRF_UARTE3=y CONFIG_HAS_HW_NRF_WDT=y CONFIG_NRF_HW_RTC1_RESERVED=y CONFIG_NRF_ENABLE_ICACHE=y CONFIG_SOC_NRF9160=y CONFIG_SOC_NRF9160_SICA=y # end of Hardware Configuration CONFIG_SOC_COMPATIBLE_NRF=y # # ARM Options # CONFIG_ARCH="arm" CONFIG_CPU_CORTEX=y CONFIG_CPU_CORTEX_M=y CONFIG_ISA_THUMB2=y CONFIG_ASSEMBLER_ISA_THUMB2=y CONFIG_COMPILER_ISA_THUMB2=y CONFIG_STACK_ALIGN_DOUBLE_WORD=y # CONFIG_RUNTIME_NMI is not set CONFIG_PLATFORM_SPECIFIC_INIT=y CONFIG_FAULT_DUMP=2 CONFIG_BUILTIN_STACK_GUARD=y CONFIG_ARM_STACK_PROTECTION=y CONFIG_ARM_NONSECURE_FIRMWARE=y CONFIG_FP_HARDABI=y # CONFIG_FP_SOFTABI is not set CONFIG_CPU_CORTEX_M33=y CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y CONFIG_CPU_CORTEX_M_HAS_DWT=y CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y CONFIG_CPU_CORTEX_M_HAS_VTOR=y CONFIG_CPU_CORTEX_M_HAS_SPLIM=y CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y CONFIG_CPU_CORTEX_M_HAS_CMSE=y CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_SE=y CONFIG_ARMV7_M_ARMV8_M_FP=y CONFIG_ARMV8_M_DSP=y # # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options # CONFIG_GEN_ISR_TABLES=y # CONFIG_ZERO_LATENCY_IRQS is not set # CONFIG_SW_VECTOR_RELAY is not set # CONFIG_CORTEX_M_DWT is not set # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options CONFIG_ARM_MPU=y CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32 # CONFIG_MPU_STACK_GUARD is not set CONFIG_MPU_ALLOW_FLASH_WRITE=y # CONFIG_CUSTOM_SECTION_ALIGN is not set CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32 CONFIG_ARM_TRUSTZONE_M=y # # ARM TrustZone-M Options # # # Non-secure firmware # CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS=y # end of ARM TrustZone-M Options CONFIG_GEN_IRQ_VECTOR_TABLE=y CONFIG_IDLE_STACK_SIZE=320 CONFIG_ISR_STACK_SIZE=2048 CONFIG_TEST_EXTRA_STACKSIZE=0 # end of ARM Options CONFIG_ARM=y CONFIG_ARCH_IS_SET=y # # General Architecture Options # # CONFIG_TRUSTED_EXECUTION_SECURE is not set CONFIG_TRUSTED_EXECUTION_NONSECURE=y CONFIG_HW_STACK_PROTECTION=y # CONFIG_USERSPACE is not set CONFIG_KOBJECT_TEXT_AREA=256 CONFIG_GEN_PRIV_STACKS=y # CONFIG_STACK_GROWS_UP is not set # # Interrupt Configuration # # CONFIG_DYNAMIC_INTERRUPTS is not set CONFIG_GEN_SW_ISR_TABLE=y CONFIG_ARCH_SW_ISR_TABLE_ALIGN=0 CONFIG_GEN_IRQ_START_VECTOR=0 # CONFIG_EXTRA_EXCEPTION_INFO is not set # end of Interrupt Configuration CONFIG_INIT_ARCH_HW_AT_BOOT=y # end of General Architecture Options CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y CONFIG_ARCH_HAS_STACK_PROTECTION=y CONFIG_ARCH_HAS_USERSPACE=y CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y CONFIG_ARCH_SUPPORTS_COREDUMP=y CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y CONFIG_ARCH_HAS_THREAD_ABORT=y CONFIG_CPU_HAS_TEE=y CONFIG_CPU_HAS_FPU=y CONFIG_CPU_HAS_MPU=y CONFIG_MPU=y CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y CONFIG_MPU_GAP_FILLING=y CONFIG_SRAM_REGION_PERMISSIONS=y # # Floating Point Options # CONFIG_FPU_SHARING=y # end of Floating Point Options # # Cache Options # # CONFIG_CACHE_MANAGEMENT is not set # end of Cache Options # # General Kernel Options # CONFIG_MULTITHREADING=y CONFIG_NUM_COOP_PRIORITIES=16 CONFIG_MAIN_THREAD_PRIORITY=0 CONFIG_COOP_ENABLED=y CONFIG_PREEMPT_ENABLED=y CONFIG_PRIORITY_CEILING=0 CONFIG_NUM_METAIRQ_PRIORITIES=0 # CONFIG_SCHED_DEADLINE is not set # CONFIG_SCHED_CPU_MASK is not set CONFIG_THREAD_STACK_INFO=y # CONFIG_THREAD_CUSTOM_DATA is not set CONFIG_ERRNO=y CONFIG_SCHED_DUMB=y # CONFIG_SCHED_SCALABLE is not set # CONFIG_SCHED_MULTIQ is not set # CONFIG_WAITQ_SCALABLE is not set CONFIG_WAITQ_DUMB=y # # Kernel Debugging and Metrics # # CONFIG_INIT_STACKS is not set CONFIG_BOOT_DELAY=0 # CONFIG_THREAD_MONITOR is not set # CONFIG_THREAD_NAME is not set # CONFIG_THREAD_RUNTIME_STATS is not set # end of Kernel Debugging and Metrics # # Work Queue Options # CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1 # end of Work Queue Options # # Atomic Operations # CONFIG_ATOMIC_OPERATIONS_BUILTIN=y # end of Atomic Operations # # Timer API Options # CONFIG_TIMESLICING=y CONFIG_TIMESLICE_SIZE=0 CONFIG_TIMESLICE_PRIORITY=0 CONFIG_POLL=y # end of Timer API Options # # Other Kernel Object Options # # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set CONFIG_NUM_MBOX_ASYNC_MSGS=10 CONFIG_NUM_PIPE_ASYNC_MSGS=10 CONFIG_KERNEL_MEM_POOL=y # end of Other Kernel Object Options CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y CONFIG_SWAP_NONATOMIC=y CONFIG_SYS_CLOCK_EXISTS=y CONFIG_TIMEOUT_64BIT=y CONFIG_XIP=y # # Initialization Priorities # CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30 CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40 CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50 CONFIG_APPLICATION_INIT_PRIORITY=90 # end of Initialization Priorities # # Security Options # # CONFIG_STACK_CANARIES is not set CONFIG_STACK_POINTER_RANDOM=0 # end of Security Options # # SMP Options # CONFIG_MP_NUM_CPUS=1 # end of SMP Options CONFIG_TICKLESS_IDLE=y CONFIG_TICKLESS_IDLE_THRESH=3 CONFIG_TICKLESS_KERNEL=y # end of General Kernel Options CONFIG_HAS_DTS=y CONFIG_HAS_DTS_GPIO=y # # Device Drivers # # CONFIG_IEEE802154 is not set # CONFIG_LORA is not set # CONFIG_CONSOLE is not set CONFIG_HAS_SEGGER_RTT=y # CONFIG_USE_SEGGER_RTT is not set # CONFIG_EC_HOST_CMD_PERIPH is not set # CONFIG_NET_LOOPBACK is not set # # Capabilities # CONFIG_SERIAL_HAS_DRIVER=y CONFIG_SERIAL_SUPPORT_ASYNC=y CONFIG_SERIAL_SUPPORT_INTERRUPT=y CONFIG_UART_ASYNC_API=y # CONFIG_UART_LINE_CTRL is not set # CONFIG_UART_DRV_CMD is not set # # Serial Drivers # CONFIG_UART_NRFX=y CONFIG_UART_0_NRF_UARTE=y CONFIG_UART_0_ENHANCED_POLL_OUT=y CONFIG_UART_0_ASYNC=y # CONFIG_UART_0_NRF_PARITY_BIT is not set CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32 CONFIG_UART_0_NRF_HW_ASYNC=y CONFIG_UART_0_NRF_HW_ASYNC_TIMER=2 CONFIG_UART_0_GPIO_MANAGEMENT=y CONFIG_UART_1_NRF_UARTE=y CONFIG_UART_1_ASYNC=y CONFIG_UART_1_ENHANCED_POLL_OUT=y # CONFIG_UART_1_NRF_PARITY_BIT is not set # CONFIG_UART_1_NRF_HW_ASYNC is not set CONFIG_UART_1_GPIO_MANAGEMENT=y CONFIG_UART_2_NRF_UARTE=y CONFIG_UART_2_ASYNC=y CONFIG_UART_2_ENHANCED_POLL_OUT=y # CONFIG_UART_2_NRF_PARITY_BIT is not set CONFIG_UART_2_NRF_TX_BUFFER_SIZE=32 # CONFIG_UART_2_NRF_HW_ASYNC is not set CONFIG_UART_2_GPIO_MANAGEMENT=y CONFIG_UARTE_NRF_HW_ASYNC=y CONFIG_NRF_UARTE_PERIPHERAL=y # CONFIG_UART_ALTERA_JTAG is not set # CONFIG_UART_XLNX_UARTLITE is not set # # Interrupt Controllers # # CONFIG_SWERV_PIC is not set # CONFIG_MULTI_LEVEL_INTERRUPTS is not set # end of Interrupt Controllers # # Timer Drivers # CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0 # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y CONFIG_SYSTEM_CLOCK_DISABLE=y # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0 CONFIG_TICKLESS_CAPABLE=y # end of Timer Drivers CONFIG_ENTROPY_GENERATOR=y CONFIG_ENTROPY_HAS_DRIVER=y # CONFIG_PCIE is not set # CONFIG_PCIE_ENDPOINT is not set # CONFIG_GPIO_DW is not set CONFIG_GPIO_NRFX=y CONFIG_GPIO_NRF_INIT_PRIORITY=40 CONFIG_GPIO_NRF_P0=y # CONFIG_GPIO_ITE_IT8XXX2 is not set # CONFIG_GPIO_INTEL_APL is not set # CONFIG_GPIO_XLNX_AXI is not set # CONFIG_GPIO_EMUL is not set # CONFIG_SHARED_IRQ is not set # CONFIG_I2S is not set # CONFIG_PWM is not set # CONFIG_PINMUX is not set # CONFIG_ADC is not set # CONFIG_DAC is not set CONFIG_CLOCK_CONTROL_NRF=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y CONFIG_CLOCK_CONTROL_NRF_ACCURACY=20 # CONFIG_PTP_CLOCK is not set # CONFIG_IPM is not set CONFIG_FLASH_HAS_DRIVER_ENABLED=y CONFIG_FLASH_HAS_PAGE_LAYOUT=y CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_SOC_FLASH_NRF=y CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set # CONFIG_FLASH_SIMULATOR is not set # CONFIG_COUNTER is not set # CONFIG_DMA is not set # CONFIG_USB is not set # CONFIG_CRYPTO is not set # CONFIG_DISPLAY is not set # CONFIG_LED_STRIP is not set # CONFIG_LED is not set # CONFIG_CAN is not set # CONFIG_AUDIO is not set # CONFIG_NEURAL_NET_ACCEL is not set # CONFIG_HWINFO is not set # CONFIG_ESPI is not set # CONFIG_PS2 is not set # CONFIG_VIDEO is not set # CONFIG_EEPROM is not set # CONFIG_PECI is not set # CONFIG_PECI_INTERRUPT_DRIVEN is not set # CONFIG_REGULATOR is not set # CONFIG_MEMC is not set # CONFIG_VIRTUALIZATION is not set # end of Device Drivers # # C Library # # CONFIG_MINIMAL_LIBC is not set CONFIG_NEWLIB_LIBC=y # CONFIG_EXTERNAL_LIBC is not set CONFIG_HAS_NEWLIB_LIBC_NANO=y CONFIG_NEWLIB_LIBC_NANO=y CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y # CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set # end of C Library # # Additional libraries # # CONFIG_FNMATCH is not set # CONFIG_LVGL is not set # # OS Support Library # # CONFIG_JSON_LIBRARY is not set CONFIG_RING_BUFFER=y # CONFIG_BASE64 is not set # CONFIG_SYS_HEAP_VALIDATE is not set CONFIG_SYS_HEAP_ALLOC_LOOPS=3 # CONFIG_PRINTK64 is not set # CONFIG_PRINTK_SYNC is not set CONFIG_CBPRINTF_COMPLETE=y # CONFIG_CBPRINTF_NANO is not set CONFIG_CBPRINTF_FULL_INTEGRAL=y # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set CONFIG_CBPRINTF_FP_SUPPORT=y # CONFIG_CBPRINTF_FP_A_SUPPORT is not set # CONFIG_CBPRINTF_FP_ALWAYS_A is not set CONFIG_CBPRINTF_N_SPECIFIER=y # CONFIG_CBPRINTF_LIBC_SUBSTS is not set # end of OS Support Library CONFIG_POSIX_MAX_FDS=8 # CONFIG_POSIX_API is not set # CONFIG_PTHREAD_IPC is not set # CONFIG_POSIX_CLOCK is not set CONFIG_MAX_TIMER_COUNT=5 # CONFIG_POSIX_MQUEUE is not set # CONFIG_EVENTFD is not set # CONFIG_OPENAMP_RSC_TABLE is not set # end of Additional libraries # # Sub Systems and OS Services # # CONFIG_BT is not set # # Controller Area Network (CAN) bus subsystem # # CONFIG_ISOTP is not set # end of Controller Area Network (CAN) bus subsystem # CONFIG_CONSOLE_SUBSYS is not set # CONFIG_CPLUSPLUS is not set # # System Monitoring Options # # CONFIG_BOOT_TIME_MEASUREMENT is not set # CONFIG_THREAD_ANALYZER is not set # end of System Monitoring Options # # Debugging Options # # CONFIG_DEBUG is not set # CONFIG_STACK_USAGE is not set CONFIG_STACK_SENTINEL=y CONFIG_PRINTK=y CONFIG_EARLY_CONSOLE=y # CONFIG_ASSERT is not set # CONFIG_FORCE_NO_ASSERT is not set CONFIG_ASSERT_VERBOSE=y # CONFIG_ASSERT_NO_FILE_INFO is not set # CONFIG_ASSERT_NO_COND_INFO is not set # CONFIG_ASSERT_NO_MSG_INFO is not set # CONFIG_OBJECT_TRACING is not set # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set # CONFIG_DEBUG_INFO is not set # CONFIG_OPENOCD_SUPPORT is not set # CONFIG_DEBUG_COREDUMP is not set # end of Debugging Options # CONFIG_DISK_ACCESS is not set # CONFIG_EMUL is not set # CONFIG_CHARACTER_FRAMEBUFFER is not set # # File Systems # # CONFIG_FILE_SYSTEM is not set # CONFIG_FCB is not set # CONFIG_NVS is not set # end of File Systems # # Inter Processor Communication # # CONFIG_RPMSG_SERVICE is not set # end of Inter Processor Communication # CONFIG_JWT is not set # CONFIG_LOG is not set # # Device Management # # # Host command handler subsystem # # CONFIG_EC_HOST_CMD is not set # end of Host command handler subsystem # CONFIG_MCUMGR is not set # CONFIG_HAWKBIT is not set # CONFIG_UPDATEHUB is not set # CONFIG_OSDP is not set # end of Device Management # # Networking # CONFIG_NET_BUF=y CONFIG_NET_BUF_USER_DATA_SIZE=4 # CONFIG_NET_BUF_LOG is not set # CONFIG_NET_BUF_POOL_USAGE is not set CONFIG_NETWORKING=y # CONFIG_NET_HOSTNAME_ENABLE is not set # # Link layer options # # CONFIG_NET_L2_DUMMY is not set # CONFIG_NET_L2_BT_SHELL is not set # CONFIG_NET_L2_PPP is not set # CONFIG_NET_L2_OPENTHREAD is not set # CONFIG_NET_L2_CANBUS_RAW is not set # CONFIG_NET_L2_ZIGBEE is not set # CONFIG_NET_L2_WIFI_MGMT is not set # CONFIG_NET_L2_WIFI_SHELL is not set # end of Link layer options # # IP stack # # CONFIG_NET_NATIVE is not set # CONFIG_NET_OFFLOAD is not set CONFIG_NET_INIT_PRIO=90 CONFIG_NET_IF_MAX_IPV6_COUNT=1 CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=2 CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=3 CONFIG_NET_IF_IPV6_PREFIX_COUNT=2 CONFIG_NET_INITIAL_HOP_LIMIT=64 CONFIG_NET_IPV6_MAX_NEIGHBORS=8 # CONFIG_NET_IPV6_FRAGMENT is not set CONFIG_NET_IPV6_MLD=y CONFIG_NET_IPV6_NBR_CACHE=y CONFIG_NET_IPV6_ND=y CONFIG_NET_IPV6_DAD=y CONFIG_NET_IPV6_RA_RDNSS=y # CONFIG_NET_6LO is not set CONFIG_NET_IPV6_LOG_LEVEL=0 CONFIG_NET_ICMPV6_LOG_LEVEL=0 CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL=0 # CONFIG_NET_IPV4 is not set # CONFIG_NET_SHELL is not set CONFIG_NET_TC_TX_COUNT=1 CONFIG_NET_TC_RX_COUNT=1 CONFIG_NET_TC_THREAD_COOPERATIVE=y # CONFIG_NET_TC_THREAD_PREEMPTIVE is not set CONFIG_NET_TC_NUM_PRIORITIES=16 CONFIG_NET_TC_MAPPING_STRICT=y CONFIG_NET_TX_DEFAULT_PRIORITY=1 CONFIG_NET_RX_DEFAULT_PRIORITY=0 CONFIG_NET_IP_ADDR_CHECK=y CONFIG_NET_MAX_ROUTERS=1 CONFIG_NET_ROUTE=y CONFIG_NET_MAX_ROUTES=8 CONFIG_NET_MAX_NEXTHOPS=8 # CONFIG_NET_ROUTE_MCAST is not set # CONFIG_NET_TCP is not set # CONFIG_NET_TEST_PROTOCOL is not set CONFIG_NET_UDP=y CONFIG_NET_UDP_CHECKSUM=y CONFIG_NET_UDP_LOG_LEVEL=0 CONFIG_NET_MAX_CONN=4 CONFIG_NET_MAX_CONTEXTS=6 # CONFIG_NET_CONTEXT_NET_PKT_POOL is not set CONFIG_NET_CONTEXT_SYNC_RECV=y CONFIG_NET_CONTEXT_CHECK=y # CONFIG_NET_CONTEXT_PRIORITY is not set # CONFIG_NET_CONTEXT_TIMESTAMP is not set # CONFIG_NET_CONTEXT_TXTIME is not set # CONFIG_NET_CONTEXT_RCVTIMEO is not set # CONFIG_NET_TEST is not set # CONFIG_NET_TRICKLE is not set CONFIG_NET_PKT_RX_COUNT=4 CONFIG_NET_PKT_TX_COUNT=4 CONFIG_NET_BUF_RX_COUNT=16 CONFIG_NET_BUF_TX_COUNT=16 CONFIG_NET_BUF_FIXED_DATA_SIZE=y # CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set CONFIG_NET_BUF_DATA_SIZE=128 CONFIG_NET_DEFAULT_IF_FIRST=y # CONFIG_NET_PKT_TIMESTAMP is not set # CONFIG_NET_PKT_TXTIME is not set # CONFIG_NET_PROMISCUOUS_MODE is not set # # Stack usage # CONFIG_NET_TX_STACK_SIZE=1200 CONFIG_NET_RX_STACK_SIZE=1500 # end of Stack usage # CONFIG_NET_MGMT is not set # CONFIG_NET_STATISTICS is not set # CONFIG_NET_LOG is not set CONFIG_NET_PKT_LOG_LEVEL=0 # CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0 # CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set CONFIG_NET_CORE_LOG_LEVEL=0 CONFIG_NET_IF_LOG_LEVEL=0 CONFIG_NET_TC_LOG_LEVEL=0 CONFIG_NET_UTILS_LOG_LEVEL=0 CONFIG_NET_CONTEXT_LOG_LEVEL=0 CONFIG_NET_CONN_LOG_LEVEL=0 CONFIG_NET_ROUTE_LOG_LEVEL=0 # end of IP stack # # Network Protocols # # CONFIG_COAP is not set # CONFIG_DNS_RESOLVER is not set # CONFIG_DNS_SD is not set # CONFIG_MQTT_LIB is not set # CONFIG_TFTP_LIB is not set # CONFIG_HTTP_PARSER is not set CONFIG_HTTP_PARSER_URL=y # CONFIG_HTTP_PARSER_STRICT is not set # CONFIG_HTTP_CLIENT is not set CONFIG_NET_HTTP_LOG_LEVEL=0 # CONFIG_WEBSOCKET_CLIENT is not set # CONFIG_LWM2M is not set # CONFIG_SOCKS is not set # CONFIG_SNTP is not set # end of Network Protocols # # Network Libraries # CONFIG_NET_CONFIG_AUTO_INIT=y CONFIG_NET_CONFIG_INIT_PRIO=95 CONFIG_NET_CONFIG_INIT_TIMEOUT=30 # CONFIG_NET_CONFIG_NEED_IPV6_ROUTER is not set # CONFIG_NET_CONFIG_NEED_IPV4 is not set CONFIG_NET_CONFIG_LOG_LEVEL=0 # CONFIG_NET_CONFIG_SETTINGS is not set CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y CONFIG_NET_SOCKETS_POLL_MAX=3 CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000 # CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS_OFFLOAD_TLS=y # CONFIG_NET_SOCKETS_CAN is not set # CONFIG_NET_SOCKETPAIR is not set CONFIG_NET_SOCKETS_LOG_LEVEL=0 # CONFIG_TLS_CREDENTIALS is not set # end of Network Libraries # # Network additional services # # CONFIG_NET_CONNECTION_MANAGER is not set # end of Network additional services # end of Networking # # Power Management # # CONFIG_SYS_POWER_MANAGEMENT is not set # CONFIG_PM_STATE_LOCK is not set # CONFIG_PM_DIRECT_FORCE_MODE is not set # CONFIG_PM_DEBUG is not set CONFIG_PM_POLICY_RESIDENCY=y # CONFIG_PM_POLICY_DUMMY is not set # CONFIG_PM_POLICY_APP is not set CONFIG_PM_POLICY_RESIDENCY_DEFAULT=y CONFIG_PM_MIN_RESIDENCY_DEEP_SLEEP_1=60000 CONFIG_DEVICE_POWER_MANAGEMENT=y CONFIG_PM_MAX_DEVICES=15 # CONFIG_PM_DEVICE_IDLE is not set # end of Power Management # CONFIG_SHELL is not set # CONFIG_STATS is not set CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y CONFIG_IMG_BLOCK_BUF_SIZE=512 CONFIG_IMG_ERASE_PROGRESSIVELY=y # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set # # Random Number Generators # CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y # CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set CONFIG_CSPRING_ENABLED=y CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y # end of Random Number Generators # # Storage # CONFIG_FLASH_MAP=y # CONFIG_FLASH_MAP_CUSTOM is not set # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set CONFIG_STREAM_FLASH=y CONFIG_STREAM_FLASH_ERASE=y # end of Storage # CONFIG_SETTINGS is not set # # Testing # # CONFIG_ZTEST is not set # CONFIG_ZTEST_MOCKING is not set # CONFIG_TEST is not set # CONFIG_TEST_USERSPACE is not set CONFIG_TEST_ARM_CORTEX_M=y # end of Testing # CONFIG_TIMING_FUNCTIONS is not set # CONFIG_TRACING is not set # end of Sub Systems and OS Services CONFIG_TOOLCHAIN_GNUARMEMB=y # # Build and Link Features # # # Linker Options # # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set CONFIG_LINKER_ORPHAN_SECTION_WARN=y # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set # CONFIG_CODE_DATA_RELOCATION is not set CONFIG_HAS_FLASH_LOAD_OFFSET=y CONFIG_USE_DT_CODE_PARTITION=y # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set CONFIG_KERNEL_ENTRY="__start" CONFIG_LINKER_SORT_BY_ALIGNMENT=y # end of Linker Options # # Compiler Options # # CONFIG_CODING_GUIDELINE_CHECK is not set # CONFIG_NATIVE_APPLICATION is not set CONFIG_SIZE_OPTIMIZATIONS=y # CONFIG_SPEED_OPTIMIZATIONS is not set # CONFIG_DEBUG_OPTIMIZATIONS is not set # CONFIG_NO_OPTIMIZATIONS is not set CONFIG_COMPILER_OPT="" # end of Compiler Options # CONFIG_ASSERT_ON_ERRORS is not set # CONFIG_NO_RUNTIME_CHECKS is not set CONFIG_RUNTIME_ERROR_CHECKS=y # # Build Options # CONFIG_KERNEL_BIN_NAME="zephyr" CONFIG_OUTPUT_STAT=y CONFIG_OUTPUT_DISASSEMBLY=y # CONFIG_OUTPUT_DISASSEMBLE_ALL is not set CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set # CONFIG_BUILD_NO_GAP_FILL is not set CONFIG_BUILD_OUTPUT_BIN=y # CONFIG_BUILD_OUTPUT_EXE is not set # CONFIG_BUILD_OUTPUT_S19 is not set # CONFIG_BUILD_OUTPUT_STRIPPED is not set # CONFIG_APPLICATION_DEFINED_SYSCALL is not set # CONFIG_MAKEFILE_EXPORTS is not set # CONFIG_DEPRECATED_ZEPHYR_INT_TYPES is not set # end of Build Options # end of Build and Link Features # # Boot Options # # CONFIG_IS_BOOTLOADER is not set CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="" CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS="" # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set CONFIG_REBOOT=y # CONFIG_MISRA_SANE is not set # end of Boot Options # # Compatibility # CONFIG_COMPAT_INCLUDES=y # end of Compatibility # # Nordic Serial LTE Modem # CONFIG_SLM_AT_MODE=y CONFIG_SLM_AT_MAX_PARAM=9 # CONFIG_SLM_NATIVE_TLS is not set # CONFIG_SLM_EXTERNAL_XTAL is not set CONFIG_SLM_CONNECT_UART_0=y # CONFIG_SLM_CONNECT_UART_2 is not set # CONFIG_SLM_NULL_TERMINATION is not set CONFIG_SLM_CR_TERMINATION=y # CONFIG_SLM_LF_TERMINATION is not set # CONFIG_SLM_CR_LF_TERMINATION is not set CONFIG_SLM_AT_HOST_TERMINATION=1 CONFIG_SLM_GPIO_WAKEUP=y CONFIG_SLM_INTERFACE_PIN=6 CONFIG_SLM_SOCKET_RX_MAX=576 CONFIG_SLM_TCP_FILTER_SIZE=6 CONFIG_SLM_TCP_POLL_TIME=10 CONFIG_SLM_UDP_POLL_TIME=10 CONFIG_SLM_TCP_CONN_TIME=60 # CONFIG_SLM_DATAMODE_HWFC is not set CONFIG_SLM_DATAMODE_TERMINATOR="+++" CONFIG_SLM_DATAMODE_SILENCE=1 # CONFIG_SLM_GPS is not set # CONFIG_SLM_FTPC is not set # CONFIG_SLM_MQTTC is not set # CONFIG_SLM_HTTPC is not set # end of Nordic Serial LTE Modem
