How to set tx_power using sd_ble_gap_tx_power_set() on nrf52832?
Hi Everyone,
I am working on nrf52832, I am using sdk15.0.0 ble_peripheral /ble_app_beacon as reference.
I want to set TX_POWER using sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV,m_adv_handle,RADIO_TXPOWER_TXPOWER_Pos4dBm);
  m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;
when I called this function after the ble_advertising function,err_code return 12292.
actually i am not understood BLE_GAP_ADV_SET_HANDLE_NOT_SET=0xFF.
Initially tx_power set to 4dbm but when softdevice enable getting error (code stuck at blx ,r3).
I am also trying using NRF_RADIO->TX_POWER=RADIO_TXPOWER_TXPOWER_Pos4dBm;
Register initially set to 4dbm but after call ble_stack_init() it set to 0dbm.When you change txpower, you need to update this value of the advertising data, it doesn't get updated automatically by the softdevice.
 I think I forgot some configuration in my code, Can you suggest a proper solution to see the changes in TXPOWER.
thanks.
  • thanks for reply,
    after above setting err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params); err_code return 6.
    please help me for setting tx_power using default  gap function.
    I did not intend to suggest that you make any changes in your call to sd_ble_gap_adv_set_configure().  The point is just that you take the advertising handle you get from there (or even 0 as that is what it will be), and use that in the call to sd_ble_gap_tx_power_set(). Regarding the error 6 is NRF_ERROR_NOT_SUPPORTED, which means that the configuration or length you provide is invalid. If this was working in your code before, then just keep what you had.
    The default (and only) function to set the Tx power is sd_ble_gap_tx_power_set(), and to set the Tx power for advertising you use it as shown in my previous post.
  • hi,
    i am trying to set tx_power through scan response parameter,
    Tx power set through that but not continuosly it gives me one time 0 and one time 4dbm.
    srdata.p_tx_power_level = &m_tx_power;
    printf("after memset_srdata %d\t",&srdata);
    this parameter set in advertising_init() function.
    when data is update that time  err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params); return invalid state error.
    but i need to set tx_power continuously not need to change.
    I am trying to provide new array in advertising_upadate() but not set continuosly .
    please check the log file attached it. Mac_id of my device is Address: e9:98:e4:e3:ad:b1
    15:45:38.965 -> Advertised Device: Name: , Address: e9:98:e4:e3:ad:b1, manufacturer data: 59000215454d422d3101000001f410000020001cdc00000000
    15:45:38.965 ->  RSSI: -49 TxPower: 0
    15:45:39.287 -> Devices found: 2
    15:45:39.287 -> Scan done!
    15:45:39.407 -> Advertised Device: Name: , Address: 47:af:bd:6d:6b:cf, manufacturer data: 0600010920026c3227c22cdd301dc276a5350e365f64a95c4923e9cda2
    15:45:39.407 ->  RSSI: -83 TxPower: 0
    15:45:40.007 -> Advertised Device: Name: , Address: e9:98:e4:e3:ad:b1, manufacturer data: 59000215454d422d3101000001f510000020001cdc00000000, txPower: 4
    15:45:40.007 ->  RSSI: -49 TxPower: 4
    15:45:40.287 -> Devices found: 2
    15:45:40.287 -> Scan done!
    15:45:40.407 -> Advertised Device: Name: , Address: 47:af:bd:6d:6b:cf, manufacturer data: 0600010920026c3227c22cdd301dc276a5350e365f64a95c4923e9cda2
    15:45:40.407 ->  RSSI: -83 TxPower: 0
    15:45:41.007 -> Advertised Device: Name: , Address: e9:98:e4:e3:ad:b1, manufacturer data: 59000215454d422d3101000001f610000020001cdc00000000
    15:45:41.007 ->  RSSI: -49 TxPower: 0
    15:45:41.287 -> Devices found: 2
    15:45:41.287 -> Scan done!
    15:45:41.407 -> Advertised Device: Name: , Address: 47:af:bd:6d:6b:cf, manufacturer data: 0600010920026c3227c22cdd301dc276a5350e365f64a95c4923e9cda2
    15:45:41.407 ->  RSSI: -82 TxPower: 0
    15:45:42.007 -> Advertised Device: Name: , Address: e9:98:e4:e3:ad:b1, manufacturer data: 59000215454d422d3101000001f810000020001cdc00000000, txPower: 4
    15:45:42.007 ->  RSSI: -49 TxPower: 4
    15:45:42.287 -> Devices found: 2
    15:45:42.287 -> Scan done!
    15:45:42.418 -> Advertised Device: Name: , Address: 47:af:bd:6d:6b:cf, manufacturer data: 0600010920026c3227c22cdd301dc276a5350e365f64a95c4923e9cda2
    15:45:42.418 ->  RSSI: -86 TxPower: 0
    15:45:42.983 -> Advertised Device: Name: , Address: e9:98:e4:e3:ad:b1, manufacturer data: 59000215454d422d3101000001f910000020001cdc00000000
    15:45:42.983 ->  RSSI: -49 TxPower: 0
    15:45:43.303 -> Devices found: 2
    15:45:43.303 -> Scan done!
    15:45:43.417 -> Advertised Device: Name: , Address: 47:af:bd:6d:6b:cf, manufacturer data: 0600010920026c3227c22cdd301dc276a5350e365f64a95c4923e9cda2
    15:45:43.417 ->  RSSI: -85 TxPower: 0
    15:45:44.020 -> Advertised Device: Name: , Address: e9:98:e4:e3:ad:b1, manufacturer data: 59000215454d422d3101000001f910000020001cdc00000000, txPower: 4
    15:45:44.020 ->  RSSI: -50 TxPower: 4
    I am not sure I understand. Do you mean set the actual Tx power or some data in the scan response packet that indicate the Tx power (typically measured at a specific distance)? Please elaborate.
    If you try to change the configuration of a currently active advertiser, you will get invalid state. In this case, you should stop advertising and start again. This is not the way to change Tx power though, so I am not sure what you want to do. If you are having a different problem now, then please backtrack and explain in detail from the beginning.
    Can you explain more? Do you want to set it once, or do you want to set it repeatedly? In any case, to change the Tx power you use sd_ble_gap_tx_power_set() as we have discussed before and as described in the API documentation.
  • thanks for reply,
    1)i am trying to set tx_power through scan response parameter
    firstly i am setting tx_power through sd_ble_gap_tx_power_set() but not set it gives always 0dbm. another way i tried to set tx power through scan response paramter.
    first change the structure member ,
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata[0],
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = m_enc_srdata[0],
    after that this setting in advertising_init function()
     //// Build and set scan response data.
        memset(&srdata, 0, sizeof(srdata));
        printf("\n/#/#/#   D   #/#/#/\n");
        // Initialize advertising parameters (used when starting advertising).
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        //printf("\n/#/#/#   E   #/#/#/\n");
        //printf("after memset_adv_param %d\t",&m_adv_params);
        // printf("after memset_adv_param %d\n",m_adv_params);
        m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED; //Beacon needs to be scannable to receive scan response
        m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
        m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
        m_adv_params.duration        = 0;       // Never time out.
        //m_adv_params.primary_phy     = BLE_GAP_PHY_CODED;
        //m_adv_params.secondary_phy   = BLE_GAP_PHY_CODED;
       //printf("\n/#/#/#   F   #/#/#/\n");
       err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        printf("err_code_encode : %d\n",err_code);
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
       //printf("\n/#/#/#   G   #/#/#/\n");
       //printf("\n/#/#/#   H   #/#/#/\n");
    while set the advertising_update() return err_code invalid state .please help me for solved this problem.
       //printf("\n/#/#/#   b   #/#/#/\n");
        manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info1;
        manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
        //printf("address of array %d\n",&m_beacon_info1);
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        //printf("\n/#/#/#   c   #/#/#/\n");
        //int8_t tx_power                 = 4;
        //advdata.p_tx_power_level        = &tx_power;
        //advdata.name_type             = BLE_ADVDATA_SHORT_NAME;
        //  advdata.short_name_len          = 5;
        advdata.flags                 = flags;
        advdata.p_manuf_specific_data = &manuf_specific_data;
        //memset(&srdata, 0, sizeof(srdata));
        //printf("\n/#/#/#   D   #/#/#/\n");
        //srdata.p_tx_power_level = &m_tx_power;
        //printf("after memset_srdata %d\t",&srdata);
        //printf("after memset_srdata %d\n",srdata);
        //srdata.name_type             = BLE_ADVDATA_FULL_NAME;
     /*swap adv data buffer - from API doc: "In order to update advertising
        data while advertising,new advertising buffers must be provided"*/
        //m_adv_data.adv_data.p_data = (m_adv_data.adv_data.p_data == m_enc_advdata[0])
         //                             ? m_enc_advdata[1] : m_enc_advdata[0];
        //adv_data_buf_swap();
         m_adv_data.adv_data.p_data = (m_adv_data.adv_data.p_data == m_enc_srdata[0])
                                      ? m_enc_srdata[1] : m_enc_srdata[0];
       printf("advertising new array data %d\n",m_adv_data.adv_data.p_data == m_enc_advdata[0]);
       printf("flag = %d\n",falling_edge_detect);
       //sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV , m_adv_handle,m_tx_power);
       //APP_ERROR_CHECK(err_code);
        //printf("\n/#/#/#   d   #/#/#/\n");
        // err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
      err_code = sd_ble_gap_adv_set_configure(&(m_adv_handle), &m_adv_data,NULL);
      printf("et_error_cde %d\n",err_code);
