Creating NCS project for nRF5340
I have an NCS project compiling and running for nRF52840 (nrf52840-DK) and am attempting to transition this project to nRF5340 (nRF5340-DK).   (Prior to this, I tested the nRF5340 using the Heart Rate example, directly downloading the .hex files as supplied by Nordic.)
I'm using Segger Embedded Studio and nRF Connect SDK v1.5.0 (and tool version 1.5.0).   As mentioned above, when targeting nrf52840df_nrf52840 everything compiles and runs as expected.
To start transitioning to nRF5340, I closed the nrf52840 solution, then attempted to create a new project using Segger Embedded Solution (SES).     I pointed to the project directory and selected the board target as nrf5340dk_nrf5340_cpuappns.
SES reports that it "Cannot create project" with the message "create_nordic_project.py failed (1)."
A build directory is created (build_nrf5340dk_nrf5340_cpuappns) and populated.   i will attach the CMakeOutput and CMakeError files.
I updated both the SDK and Tools and tried again, with the same results.
Can you suggest what I'm doing wrong?
Compiling the C compiler identification source file "CMakeCCompilerId.c" failed.
Compiler: E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
Build flags:
Id flags:
The output was:
1
e:/additionalwindowstools/nordic/nrf_connect_sdk/v1.5.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: e:/additionalwindowstools/nordic/nrf_connect_sdk/v1.5.0/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/lib\libc.a(lib_a-exit.o): in function `exit':
exit.c:(.text.exit+0x2c): undefined reference to `_exit'
collect2.exe: error: ld returned 1 exit status
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
Build flags:
Id flags:
The output was:
1
The target system is: Generic - 2.4.99 - arm
The host system is: Windows - 10.0.18363 - AMD64
Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
Build flags:
Id flags: -c
The output was:
0
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.o"
The C compiler identification is GNU, found in "C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/CMakeFiles/3.17.3/CompilerIdC/CMakeCCompilerId.o"
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
Build flags:
Id flags: -c
The output was:
0
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.o"
The CXX compiler identification is GNU, found in "C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/CMakeFiles/3.17.3/CompilerIdCXX/CMakeCXXCompilerId.o"
Checking whether the ASM compiler is GNU using "--version" matched "(GNU assembler)|(GCC)|(Free Software Foundation)":
arm-none-eabi-gcc.exe (GNU Tools for Arm Embedded Processors 9-2019-q4-major) 9.2.1 20191025 (release) [ARM/arm-9-branch revision 277599]
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Determining if files stdatomic.h exist passed with the following output:
Change Dir: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/CMakeFiles/CMakeTmp
Run Build Command(s):E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/toolchain/opt/bin/ninja.exe cmTC_df50c && [1/2] Building C object CMakeFiles/cmTC_df50c.dir/HAVE_STDATOMIC_H.c.obj
[2/2] Linking C executable cmTC_df50c
arm-none-eabi-gcc.exe: warning: CMakeFiles/cmTC_df50c.dir/HAVE_STDATOMIC_H.c.obj: linker input file unused because linking not done
Determining if files fcntl.h exist passed with the following output:
Run Build Command(s):E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/toolchain/opt/bin/ninja.exe cmTC_a5f11 && [1/2] Building C object CMakeFiles/cmTC_a5f11.dir/HAVE_FCNTL_H.c.obj
[2/2] Linking C executable cmTC_a5f11
arm-none-eabi-gcc.exe: warning: CMakeFiles/cmTC_a5f11.dir/HAVE_FCNTL_H.c.obj: linker input file unused because linking not done
The console log is:
Creating solution RocketTelemetry.emProject
E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=nrf5340dk_nrf5340_cpuappns -DBOARD_DIR=E:\AdditionalWindowsTools\Nordic\nRF_Connect_SDK\v1.5.0\zephyr\boards\arm\nrf5340dk_nrf5340 -BC:\Users\hepler\Projects\RocketTelemetry\Software\Nordic\RocketTelemetry\build_nrf5340dk_nrf5340_cpuappns -SC:\Users\hepler\Projects\RocketTelemetry\Software\Nordic\RocketTelemetry -DNCS_TOOLCHAIN_VERSION=1.5.0 -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=E:\AdditionalWindowsTools\Nordic\nRF_Connect_SDK\v1.5.0\toolchain\segger_embedded_studio/html/configure_nordic_project_menuconfig.py
-- Application: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry
-- Zephyr version: 2.4.99 (E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr)
-- Found Python3: E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
-- Board: nrf5340dk_nrf5340_cpuappns
-- Cache files will be written to: E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/.cache
-- Found dtc: E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/toolchain/opt)
-- Found BOARD.dts: E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuappns.dts
-- Found devicetree overlay: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/boards/nrf5340dk_nrf5340_cpuappns.overlay
-- Generated zephyr.dts: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/zephyr/include/generated/device_extern.h
Parsing E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/Kconfig
Loaded configuration 'E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuappns_defconfig'
Merged configuration 'C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/prj.conf'
Configuration saved to 'C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/zephyr/.config'
Kconfig header saved to 'C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
-- Application: E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/nrf/samples/spm
-- Found BOARD.dts: E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/spm/zephyr/include/generated/device_extern.h
Loaded configuration 'E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/nrf/samples/spm/prj.conf'
Merged configuration 'E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/spm/zephyr/.config'
Kconfig header saved to 'C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/spm/zephyr/include/generated/autoconf.h'
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/spm
-- Application: E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/samples/bluetooth/hci_rpmsg
-- Board: nrf5340dk_nrf5340_cpunet
-- Found BOARD.dts: E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts
-- Generated zephyr.dts: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/hci_rpmsg/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/hci_rpmsg/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/hci_rpmsg/zephyr/include/generated/device_extern.h
Loaded configuration 'E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet_defconfig'
Merged configuration 'E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/samples/bluetooth/hci_rpmsg/prj.conf'
Merged configuration 'E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/nrf/subsys/bluetooth/controller/bt_ll_softdevice_hci_rpmsg.conf'
Configuration saved to 'C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/hci_rpmsg/zephyr/.config'
Kconfig header saved to 'C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/hci_rpmsg/zephyr/include/generated/autoconf.h'
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/hepler/Projects/RocketTelemetry/Software/Nordic/RocketTelemetry/build_nrf5340dk_nrf5340_cpuappns/hci_rpmsg
-- Configuring done
Including boilerplate (Zephyr base): E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/cmake/app/boilerplate.cmake
-- Using NCS Toolchain 1.5.0 for building. (E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/toolchain/cmake)
warning: BT_CTLR_RX_BUFFERS (defined at subsys/bluetooth/controller/Kconfig:166) was assigned the
value '2' but got the value ''. Check these unsatisfied dependencies: BT_CTLR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_CTLR_RX_BUFFERS.html and/or look up
BT_CTLR_RX_BUFFERS in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: BT_CTLR_TX_BUFFERS (defined at subsys/bluetooth/controller/Kconfig:176) was assigned the
value '8' but got the value ''. Check these unsatisfied dependencies: BT_CTLR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_CTLR_TX_BUFFERS.html and/or look up
BT_CTLR_TX_BUFFERS in the menuconfig/guiconfig interface. The Application Development Primer,
helpful too.
warning: BT_CTLR_TX_BUFFER_SIZE (defined at subsys/bluetooth/controller/Kconfig:187) was assigned
the value '251' but got the value ''. Check these unsatisfied dependencies: BT_CTLR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_CTLR_TX_BUFFER_SIZE.html and/or
look up BT_CTLR_TX_BUFFER_SIZE in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
might be helpful too.
warning: BT_CTLR_DATA_LENGTH_MAX (defined at subsys/bluetooth/controller/Kconfig:345) was assigned
the value '251' but got the value ''. Check these unsatisfied dependencies: BT_CTLR_DATA_LENGTH
(=n), BT_CTLR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_CTLR_DATA_LENGTH_MAX.html and/or
look up BT_CTLR_DATA_LENGTH_MAX in the menuconfig/guiconfig interface. The Application Development
warning: BT_CTLR_PHY_2M (defined at subsys/bluetooth/controller/Kconfig:424) was assigned the value
'y' but got the value 'n'. Check these unsatisfied dependencies: (BT_CTLR_PHY || BT_CTLR_ADV_EXT)
(=n), BT_CTLR_PHY_2M_SUPPORT (=n), BT_CTLR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_CTLR_PHY_2M.html and/or look up
BT_CTLR_PHY_2M in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
Changed board to secure nrf5340dk_nrf5340_cpuapp (NOT NS)
=== child image spm -  begin ===
=== child image spm -  end ===
Adding 'hci_rpmsg' firmware as child image since CONFIG_BT_RPMSG_NRF53 is set to 'y'
=== child image hci_rpmsg - CPUNET begin ===
-- Build type:
-- Host:    Windows/AMD64
-- Target:  Generic/arm
-- Machine: cortexm
-- Machine: cortexm
-- C_FLAGS :  -Wall -Wextra
CMake Warning at ../../../CMakeLists.txt:1357 (message):
=== child image hci_rpmsg - CPUNET end ===
-- Build type:
-- Machine: cortexm
-- Machine: cortexm
CMake Error at E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/cmake/extensions.cmake:416 (add_library):
  No SOURCES given to target: drivers__spi
  E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/cmake/extensions.cmake:393 (zephyr_library_named)
  E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/zephyr/drivers/spi/CMakeLists.txt:3 (zephyr_library)
CMake Generate step failed.  Build files cannot be regenerated correctly.
error: cmake failed
It appears to not be able to find SPI drivers??
Thanks!
  • Yes, the nrf5340dk_nrf5340_cpuappns project loads.
    Note that my project loads when I target nrf5340dk_nrf5340_cpuapp, but not when targeting nrf5340dk_nrf5340_cpuappns.  When it fails, the console log seems to indicate that it couldn't find source for "drivers__spi".   I haven't looked at the code (cmake) that creates the project, but could there be a typo there that puts in two '_' characters between "drivers" and "spi" when targeting the _cpuappns version for nrf5340?   The prj.conf file is the same for both versions (cpuapp and cpuappns) and there are two .overlay files (_cpuapp and _cpuappns versions) that have the same contents.   So the only difference I can see is the version of the target (_cpuapp vs _cpuappns) I point to...
    Thanks...
  • The best would probably be if you could send me the project that doesn't compile, or if you don't want to share the project you can send me another project that fails for the same reason. Then I can try to reproduce it.
  • OK, here is a .zip of the project directory.   It contains a small  main program and a couple of tasks that I've been using to perform some tests.    Using version 1.5.0 of nRF Connect SDK, it will generate a project if I target nrf52840dk_nrf52840, or nrf5340dk_nrf5340_cpuapp, but fails to generate a project if I target nrf5340dk_nrf5340_cpuappns.   (It seems to complain that it can't find source for spi.)
    Note that to compile for nrf52840, a few changes are needed to the source and header files (commenting out/enabling slight changes needed between the two device versions).
    In all cases I point to the directory represented by the .zip file.   I also select the appropriate board as the target.    The appropriate .overlay files are in the boards directory.   Both nRF5340 board overlays are the same.
    I have gotten things to run on both devices, but since the recommendation is to use _cpuappns, I figured I should...   But have problems generating the project...
    Thanks...
    nrf5340_TestCase.zip
  • The project builds for me after I put the line
    in the overlay for spi2.
    It should look like this;
    &spi2 {
            status = "okay";
            sck-pin =  <42>;   /* P1, Pin10 */
            mosi-pin = <43>;   /* P1, Pin11 */
            miso-pin = <44>;   /* P1, Pin12 */
            cs-gpios = <&gpio1 13 GPIO_ACTIVE_LOW>;   /* P1 Pin5 Pin13 */
            clock-frequency = <8000000>;
            sdhc0: sdhc@0 {
                    compatible = "zephyr,mmc-spi-slot";
                    reg = <0>;
                    status = "okay";
                    label = "SDHC0";
                    spi-max-frequency = <8000000>;
  • OK, great!   Thanks!
    I wonder why the "cpuapp" version created a project, while the "cpuappns" version didn't??
    Thanks again!
