A few asset tracker questions
Hi all,
Just have a few Asset tracker questions if anyone knows the answer:
1) If using the nRF Cloud, and a custom env_sensor, what's the maximum length databuf that can be posted in one go?
struct cloud_data {
    char *buf;
    size_t len;
2) If a cloud post fails because it can't connect or no signal, does it queue the data for retry or just drops it?
3) Is it using the SAADC to monitor the battery anywhere?
Thanks in advance for any help
Billy
  • Hi Markus,
    Of course,
    The setup process on the cloud side was considerable, the main points which hit me included:
    1) Had to use Linux
    It's not that I'm afraid of Linux, its simply down to knowing that when I deploy the project to the maintainers, I need to deploy multiple OS's for them, we use SES on windows for the firmware devel, our current windows versions don't support the windows app store distros.  All in all its a pain to have to include another OS in the support requirements.
    2) AWS
    Its big, bulky, massively involved, loads of restrictions (ie supported region selections), more financial commitment on top of SIMs.  The dependencies and install process wasn't simple at all, your documentation is good but does not cover everything I had to do to get the AWS part working with all the dependencies it needed, how it works, what relies on what, etc
    For me, I had never used AWS before, but I have been developing for years.  When I have finished this project I need to hand this over to someone, which would suggest that I have to add Linux and AWS skills to their skillsets.
    When Amazon change things in the future, I can see frequent maintenance requirements to fix things that may get broken, which would again involve confident Linux and AWS skills for whoever is employed to support it.
    When I compare this to running the Asset_Tracker using the nRFCloud, there is no contest - it was so easy, quick and fluid to set up, no additional OS needed, no AWS learning curve, I literally had it up and running in minutes, it looks nice, it works, it ticks the boxes with far far less commitment and time.
    So it's hard to justify.  I feel more exposed to future support and maintenance requirements potentially needed when using AWS.
    In fact, Nordic has done a stunning job with the nRFCloud offering, if the nRFCloud worked with the Asset Tracker 2, I think I would already be steaming down that path.
    These points are solely based on evaluating the two Asset_Tracker apps, so it was a good experience for me to see the differences involved.  I'm not saying I wouldn't choose AWS for a different project in the future, it's just the effort to get it working in this case, for this project, was much greater then I had imagined. I hope Asset_tracker 2 gets a few alternative choices in the future, just for that reason, choice.
    All that said, its clear a lot of work has been put into this, and the end-user result is very nice.
    I am always open to suggestions and welcome your comments if you think I have missed something or done something wrong.
  • In addition, I am very open to you suggesting a way to satisfy my client's requirements using an AWS solution if you feel its the best way.  I am happy to revisit if the potential is there.
  • Hei Billy,
    thanks so much for the detailed response!
    1) Had to use Linux
    it is mentioned in the System Requirements that you can use Windows, and all the tools mentioned (Node.js, AWS CLI, Segger) in use should be working fine under native Windows, too. It's just that we currently have no automated tests to ensure that everything works under Windows. I've linked your feedback to the thread about Windows support and I will keep an eye on feedback around that. However, I think it will be clear with my next comment, why this was not an immediate concern.
    2) AWS
    I realized that we do not mention in the documentation that the nRF Asset Tracker project expects some prior experience with AWS and developing solutions on AWS; after all it is designed for developers who want a headstart on how to set up their AWS account for our devices, but then want to modify the solution to their needs.
    And this is where the documentation failed you, we should be clearer on what to expect from nRF Asset Tracker.
    After all, if you want a turn-key solution, with no additional costs and no maintenance effort, nRF Connect for Cloud is absolutely the better choice. And the asset_tracker application offers the optimal implementation of their API and their advanced features, like A-GPS and FOTA v2.
  • Hi Markus,
    This statement has been the clearest pointer of all for me so far and certainly clarifies the offerings, it also ties up with my own experience of evaluating the options.
    If I had read that at the beginning, for this project I would not have needed to consider it.
