WakeUp from sleep mode
we try to get the NRF52840 to sleep and then wake up from an GPIO interrupt.
We try it in debug mode which should give a emulated sleep mode. So we stop all processing and at a while(1) loop after calling sd_power_system_off.
The wakeup pin is configured as followed:
	nrf_gpio_cfg_input(IMU_INT2, NRF_GPIO_PIN_NOPULL);
	nrf_gpio_cfg_sense_set(IMU_INT2, NRF_GPIO_PIN_SENSE_HIGH);
Prior to setting the nrf to sleep the interrupt is firing and working as expected. And I can see the interrupt going high and low again when the nrf should be in sleep
but it does not produce a reset. Some other information the device is running with USB powered and usb_handling enabled and debugger disconnected.
I've already tried to uncomment the USB stuff and run it without USB but still no progress.
Help is appreciated ;-).
C.W.
PS: SDK is 17.0.0
